Question about Lands Phones
Panasonic kx tga641
How to use for DTMF method of caller ID
SOURCE: Dialing mode option change.
Program --> Auto --> ** --> Program (Pulse to DTMF)
Program --> Auto --> ## --> Program (DTMF to Pulse)
Posted on Dec 22, 2007
SOURCE: Caller ID is not working in India.
For people who have purchased cordless phone in usa and caller id is not working they should purchase fsk to dtmf converter at any local phone shop and caller id will start working.
Here is the article on various frequency used by various countries for caller id.
Hope this will help you out.
Detailed Product Description
There are 3 major caller ID specifications in the world: DTMF, ETSI FSK and Bellcore FSK. When users buy a foreign telephone devices(such as cordless phone, fax machine or computer telephony interface), may encounter the problems of non-match for caller ID standard. This will cause the device unable to display the caller ID. EX220 can solve this problem easily. This product can receive all 3 kinds of caller ID format, and convert to FSK(Bellcore or ETSI selectable) to match foreign telephone's standard.
EX220 has a rechargeable battery inside the device, during idle status, it gets power from the telephone line and recharge the battery, so no need to use or replace battery. Just plug one end to telephone line, and the other to the telephone device.
For example, if you live in Netherlands, Saudi or India, the caller ID standard is DTMF. You purchased a cordless caller ID phone from US(which uses Bellcore FSK standard), or from Germany(which uses ETSI FSK standard). You won't be able to use the caller ID feature. In this case, just get one EX220 and connect it between the telephone line and the cordless phone, your cordless caller ID phone will display the caller's number immediately.
Remark:
1. Telephone sets for UK and Japan standard are not applicable.
2. In some countries, users must subscribe to Telecom for caller ID service
Feature List
Caller ID Format Conversion --- Convert 3 kinds of caller ID(DTMF, Bellcore FSK or ETSI FSK) to ETSI FSK or Bellcore FSK(selectable)
Date/Time Stamp --- The DTMF caller ID doesn't content date/time stamp. User can set up clock of EX201, so each call will be sent with actual date and time stamp
Area Code Setting --- User can set up the area code, so the dial back feature can easily applied
Rechargeable battery powered by line --- Just connect to the telephone line, the built-in rechargeable battery can get power from the telephone line, no need any external battery nor power supply
News
Now, Multi-Line caller ID converter is available.
Posted on Jan 08, 2008
zowl
  • 15 Answers
SOURCE: Caller ID not working
I don't think the problem is the FSK vs. DTMF. The manual even states that the caller ID is generally received after the second ring. This is true in America. I lived in India for four months and I never ran into the problem there so... I just can't say how your provider sends the caller ID. It may be that the line is being interfered with. Do you have a DSL line attached to the same device. If so make sure that there is a filter between you phone and its connection.
I am assuming that you tested your line with the other equipment connected to the same location. You may want to reduce the problem to the simplest configuration by connecting directly to the line only no other equipment. If it works add the other equipment until the caller ID stops again. Then you know what is interfering. If you have a monitor set you could listen to the DTMF being sent make sure it is coming between the first and second ring. It is audible if it is there. If you are answering on the first ring you will not see caller ID you have to wait till after the second ring then you should see it, If BSNL is sending the same as American systems. Good luck Z
Posted on Mar 12, 2008
SOURCE: Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
Posted on Mar 24, 2008
  • 30 Answers
SOURCE: How do you turn on caller ID on a Panasonic KX TGA181AL
Is your phone operated off a panasonic system? is so you need a caller id card. if not then you would need to inform your phone service provider that you need caller id. if you have caller id and you do have the caller id card you would need to get a hold of a panasonic tech who could turn on your c.id as long as it is being provided from your phone service and the card is installed.
Posted on Feb 21, 2009
Caller ID is not working in India - KX-TG4022.
Did you buy an FSK CID unit for India's DTMF CID? There's an adapter or you need the right unit.
http://indiashopping.weav.in/a/searchresults.do/queryString-Dtmf+to+fsk+converter
Carl
Feb 13, 2011 | Panasonic KX TG4021 Cordless Phone
I have purchased KX-TG5622 from singapore and ins...
Only stupids buy cordless phone from Singapore. India uses ETSI DTMF standard for Caller ID which is not supported by any cordless phone sold in Singapore. It is about time you trash your worthless instrument in the dumpster.
May 20, 2010 | Panasonic KX-TG5622M Twin Cordless Phone
Caller ID/CLIP) not working in Panasonic cordless
Well if the phone has been bought abroad and being used in India you will face this problem. this is because of the format of transmitting the caller id info being different. In USA it is STF and in India it is DTMF. You need a convertor in the phone line which is DTMF to STF. IF you find onw in Delhi pl let me also know.
Aug 19, 2009 | Panasonic KX-TH111S 2.4 GHz Cordless Phone
HOW TO ACTIVATE MY CALLER ID
Go to phone menu find, caller id heading, there is an option for FSK & DTMF , if you are in india Select DTMF, if it doesn't work ask telephone seller to provide you with Fintel FSK to DTMF convertor.
thnks
Jul 08, 2009 | Panasonic KX-TG2620 Cordless Phone
The id caller is not working in that cordless phone
Any Caller Id phone bought in USA will not show the id as the Caller id format in USA is FSK and in India it is DTMF. You need a caller id converter from DTMF to FSK. It is available online on www.ebay.in Just type DTMF to FSK converter and the item will be displayed. Right now it is avilable only with a seller in Bangalore and the price is Rs.589/- per piece. I bought it and it is working fine.
Aug 24, 2008 | Panasonic KX-TG1100 Cordless Phone
Mar 12, 2008 | Panasonic (KX-TG1032S) Phone
Caller id not working
US phones use Bellcore FSK caller id. India uses DTMF caller id. Buy a DTMF- FSK converter at a telecom shop.
Jan 05, 2008 | Motorola Mobility 5.8 GHz Digital Cordless...
Remark:
Feature List
News
Dec 09, 2007 | Motorola Mobility 5.8 GHz Digital Cordless...
CALLER ID NOT WORKING
not only Panasonic, most other brand phones imported from other countries wont work in in India ( caller ID). Panasonic phones of Panasonic India, will work.I think panasonic has to explain this. if there are networks which does not support this equipment, atleast they should mention this is their booklets, to avoid users roam around telecom offices. To my understanding, all the land phones of BSNL through out India are caller ID enabled by default and is free!.
Aug 19, 2007 | Panasonic KX-TG2632W Phone
Lands Phones Logo
57 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
