Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
My printer couldn't detect the black colour ink
How to solve this? any kind person can help??
    New Friend:
It need to replace the ink sensor.
Posted on Jan 21, 2014
alphacheese
  • 68 Answers
SOURCE: BROTHER MFC-210 PRINTING IN BLACK INK POOR QUALITY
Try cleaning the black printer heads several times in a row, at least 5 times then print a black document with best quality setting.
Press the ink button, then down to select select cleaning and then press menu/set and menu/set again to select black.
Posted on Jan 08, 2010
Sebin
  • 712 Answers
SOURCE: black ink will not print. Colours ok
Get a syringe, remove the needle, remove the ink cartridge and use the syringe to blow air GENTLY through the hole the cartridge connects to. Make sure you have a cleaning cloth to remove ink dislodged from pipe connected at the print head, do this gently to remove any obstruction and there should not be too much mess and can easily be cleaned up.
Posted on Feb 04, 2010
raman_jhanje
  • 27 Answers
SOURCE: My printer Brother DCP 165C cannot print in black ink.
Your black printhead is blocked.
The printhead is deep inside the printer and has to be taken out by the expert and cleaned with the help of 'steam' and hot water. This is because not using the printer for a long time. or using low grade refill inks.
Please select new cartridge only if you are inserting a new cartridge or fully refilled cartridge. Otherwise use old cartridge option. Brother printer has a mechanical sensor and not the electronic chip in the ink cartridges.
After inserting the old used cartridge if you choose 'new cart' option it will show the "Full" ink. You can still print from the exhausted ink cart after covering the sensor in the middle by a piece of paper in emergency.
Posted on Mar 05, 2010
SOURCE: Brother MFC-260C no black ink
Check this link. Will save you all a lot of money.
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Posted on Mar 24, 2010
SOURCE: I cann't just print black with my Brother DCP-130C
I can't just print black with my Brother DCP-130C printer when one colour runs out of ink the printer wont work. Can anyone help me thanks Stan
Posted on Dec 25, 2010
Can I use prodot black colour to my canon ink tank instead of esyink black colour
One can never recommend using non genuine printer ink as many are watered down and tend to splash around the printer . This can cause more problems in the long run. Pro dot is just a trade name. You can take the chance and you may be lucky. Its really a personal thing. I use Sainsbury's ink and have had no problems with it. It's up to you.
Dec 08, 2016 | Canon Office Equipment & Supplies
Why won't my printer print out the black
Usually this is just a case of the black ink being empty while the others are ok. Also a good idea to perform any nozzle cleaning and testing functions your printer has incase it's just blocked. Other poosibilities are that a new cartridge is not detected. Might even be software related. This kind of question needs a bit more information - what kind of printer? Which OS? How long since new ink/toner? How old is the printer?
Aug 19, 2014 | Office Equipment & Supplies
My ink cartridge manager tells me that both the black and colour cartridges are full, yet documents will not print in black at all and even those in full colour only print in light blue
apply the following; after you done pressing into the PRINT button click first the MAINTENANCE button then click again the PRINT TEST PAGE button, then kindly and patiently do the procedures over and over again until the test print paper will resume to its normal color and functions..in that way the black and color cartridges will be recognize in that kind of procedures..in that way your problem has been solved already...
Mar 09, 2011 | HP PSC 1315 All-in-One Printer...
I have error 0xc18a0206 HP Photosmart D7163 Printer i am not solve problem i need help me
Check out for the black sartridge and colour cartridge and face on the small circuit on it. Run smoothly with a piece of paper and also rub off the ink paste on the circuit. Then place it again on to the printer. Close the door tray. The printer will detected as normal.
Nov 22, 2010 | HP Photosmart D7160 InkJet Printer
My printer will not print black but is printing all other colours ok
Possible that the B/W cartridge is not contacting or is blocked. remove and fit back. Now remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Nov 02, 2010 | Brother DCP-385C Stylish Colour Inkjet...
Black colour is not printing
When you print in color is does it show black ink?
Sep 23, 2010 | Office Equipment & Supplies
I cant find the manual to canon pixma mp150.
Hi Irene
You solve the problem by replacing the empty ink cartridge.
Most printers (not just Canon) are designed to stop working if an ink cartridge is empty. This is to prevent the nozzles for the empty colour overheating and destroying themselves - the ink passing through acts as the coolant.
Dec 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I replaced a new black ink catridge, the black is
For that problem kindly try doing the ff:
  • Re-seat the inks both color and black then try printing
  • Re-seat the Printhead of the printer then print again
  • Try changing the print quality to best then try printing
  • if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Sep 23, 2009 | Kodak ESP 5 Printer
How can i let my printer to detect and accept the ink?
I have the same problem. According to another site I visited you will not be able to solve your problem by refilling the 28 cartridge (black ink). You will need to purchase a 28A ink cartridge which is refillable.
Jul 21, 2008 | Lexmark X2550 All-In-One Printer
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
54 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
