Question about Brookstone Rover App-controlled Spy Tank With Night Vision
We got a Rover 2.0 from Brookstone and it worked perfectly for about 20 minutes and then stopped working altogether. The light on the top doesn't even turn on. We didn't hit it or anything. It just st
Had no problems connecting the device in the beginning but now that the Rover 2.0 doesnt even turn on, obviously there is no wifi either.
Our brookstone rover'wifi is not working it's blue light is not blinking
Most likely your batteries are dying. We had this same problem and changed the batteries now it works fine.
Sep 11, 2012 | Brookstone Rover App-controlled Spy Tank...
Westinghouse 662 oven doesn't totally turn off,
We have had the same issue, it drove me crazy.... Ours has just stopped working altogether now.
Sep 13, 2011 | Ovens
My play station doesn't recognize dvds or games I put them in and no icon comes on and it doesn't paly
The Playstation 3 is a wonderful video game console, however, with heavy usage, the laser does eventually burn out. The first signs of the laser starting to burn out is that your game will start freezing during game play. Eventually the game will stop reading altogether (even though movies sometimes still work). Eventually movies will stop working and the whole laser will eventually die.
The following website sells PS3 lasers and also performs repairs:
http://store.richspsxparts.com/pl3isnotrega.html
Jun 17, 2011 | Sony Playstation 3 (PS3) Console
My watch stops working, the mechanism works on motion or kinetics. However, even with a bit of a shake it works for a bit then loses time and stops altogether
It may require rather more than a bit of a shake! Some makers say that you have to swing it gently form side to side for 200-300 times to fully wind up the watch.
I bought one some years ago that didn't work well and I had it cleaned, after which it worked perfectly for years.
If giving your watch the shaking I described above it still does not work, try having it cleaned.
Automatic watches thrive on being used but should run for 2-3 days before stopping.
Mar 08, 2011 | Jacques Lemans Classic Automatic...
My monitor will dim itself and I have to reset it so I can view the screen. some days, like today it will go dim every 15-20 minutes even when I am typing.
This sounds to me to be a problem with the CFL tubes, soon they will stop working altogether and your diplay will be very dim, or may not come up at all. In which case if under warranty return it, if not you may need to replace the CFL tubes.
Thumbs up
Thanks
Nov 02, 2010 | Acer X183HB Monitor
4.4 02 Range Rover.Blower only functions
it seems most likely it's the Control Panel faulty as this unit is has a common fault
Feb 10, 2010 | 2002 Land Rover Range Rover
Paper feeder not working
That printer has a feed switch which changes from the top feeder to the drawer below, the little light tells you whether to put paper in the top or bottom. either make sure both are loaded or switch to the one that has paper.
Sep 24, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Cordless mouse and keyboard wont work together
Hi, after experimenting a little i have fixed my problem and I think I might be able to help you.
First, try press the connect button on the receiver.. Hold it for 20 sec (might not be necessary).
Then, press the connect button on the mouse and hold it for 20 sec (is necessary)
Next, wait 20 sec (is necessary) then press the connect button on the receiver but do not hold
Finally, press and hold the keyboard button for 20 sec.
Sep 28, 2008 | Logitech Cordless Mouse
Brookstone Rover App-controlled Spy Tank With Night Vision Logo
Top Brookstone Televison & Video Experts
L Pfaff
L Pfaff
Tom Chichester
Are you a Brookstone Televison and Video Expert? Answer questions, earn points and help others
