Question about Huawei U8800-51 Impulse 4G AT&T Android Smartphone
Format memory card using file - Huawei U8800-51 Impulse 4G AT&T Android Smartphone
I m Abrar..using nokia 5130c-2..i have two questions..firstly my mobile memory is 1.1 GB and it is bieng used 724 MB..how can i increase its size?? And secondly,what is the meaning of formating a memory...
Welcome to FixYa.
Hi Abrar, the memory card is a fixed storage device in terms of capacity. There is no way the size can be increased. The only thing that you can do is either delete some files from the memory to free some space or to replace the memory card with a higher capacity like 2 GB, 4GB or 8GB.
Formatting the memory means to prepare the memory so that it can be recognized by the phone. Be warned that formatting the memory will delete all files stored in the memory card.
Thank you for using FixYa.
Have a great day.
Jas247
Jun 09, 2011 | Nokia Cell Phones
My mmc card is corrupted how can i format mmc card
Hello DJB,
Formatting the memory card is a easy process. You can format the memory card from the format option available in memory card option itself. You can also format the memory card using the desktop pc or laptop. Remove the memory card from the phone and connect the memory card in computer using the external memory card reader and format the memory card.
Apr 15, 2011 | Nokia 6630 Cellular Phone
On pokemon XD it keeps saying that the save file currupts I have alot of room on it but it still crrupts so what do I do to fix this
  • Fully Corrupt:
    When the entire save area of the Memory Card becomes corrupt, the system will inform the player that the Memory Card is corrupt and offer to format it. The card must be formatted before gameplay begins or when the game attempts to access the Memory Card. The exact message may vary from software to software.
    Follow the steps for formatting a memory card.
    For specific issues with the Memory Card 1019, please click here.
  • Suggestion: It is always a good idea to copy your most important files to a second Memory Card as a back-up.
  • Data Area Only Corrupt:
    When only the data area of a Memory Card is corrupt (not the entire Memory Card) the game may not detect this until the Memory Card is accessed. Once it is accessed, the game will inform the player that the file being accessed is corrupt and must be erased. The game will only delete the one file being accessed and will not format the entire Memory Card (Other saved game files on the Memory Card may be OK).
    Follow the steps for deleting a file.
  • Memory Card is Damaged:
    If the Memory Card has been physically damaged, or has been damaged beyond repair, you will get this message. The Memory Card will need to be replaced. The system may attempt to format the card, but if it cannot it will give the error Memory Card is Damaged. There is no way to recover the game data from the memory card.
    Please use our convenient repair options.
This procedure is only used if a corrupted Memory Card is inserted into the Nintendo GameCube.
If required, this procedure will begin automatically when you select "Memory Card Screen" from the main menu. You cannot use this procedure to erase files from a useable Memory Card.
  1. After selecting "Memory Card Screen" from the Main Menu, if your Memory Card requires formatting, a window will appear to ask for confirmation for formatting.
  2. Use the Control Stick to select "YES" and press the A Button
  3. A window will appear to notify you that all data will be erased and ask again for confirmation for formatting.
  4. Use the Control Stick to select "YES" and press the A Button.
NOTE: When you format a Memory Card, all data will be permanently erased and unable to be recovered.
Jan 11, 2011 | Nintendo GameCube Console
Memory card not formatted operation failed problem solutions
Well. There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article how to fix memory card not formatted to see fix step by step. Best regards.
Aug 07, 2010 | Computers & Internet
Will not format Memory Card for Use.
Hello my friend.
Try this tool which you can download clicking here.
It can solve your formatting problem.
- Download the file.
- Plug your memory card into your PC.
- Run the "exe" file that you downloaded.
- On the program menu select your device (memory card).
- Select FAT32 as file system.
- You may give a valid volume label.
- Uncheck the "Quick Format" option.
- Then start formatting your memory card clicking the start button.
This formatting will delete all the files in your memory card.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 28, 2010 | Kodak EasyShare Z740 Digital Camera
Memory card full
Using a memory card reader on a computer, erase unnecessary files or if the card is just corrupted, try formatting the card using the computer (use FAT16 file format in the format menu, not NTFS).
Mar 25, 2010 | PNY 2GB microSD Memory Card
When i click in memory card option,memory card not formatted shown,what will i do..........
select your memory card -> options -> format memory card option.
After the format you can use your card to store files as you wish.
Note: Format will erase all the existing files from your card
Thanks
Mar 06, 2010 | Nokia 3110 Cellular Phone
I have nokia n73. there is a problem in its use. whenever i use it , it gives the message of memory full and asks me to delete some data. please tell me some solution.
The phone's internal memory and memory card may be running out of space. Try to delete unnecessary files and free some memory space. Go to Menu>Tools>File Manager. Select the folder or file you want to delete and scroll left or right to switch from the phone's internal memory to the memory card.
Format the memory card and the phone's internal memory if the problem is not resolved above. But it will erase all saved data on both memory.
Memory Card Formatting Procedure
  1. Go to MENU > TOOLS > MEMORY.
  2. On the memory card menu press OPTIONS.
  3. Scroll to Format memory card.
  4. Press Select.
  5. Select Yes
  6. Once the formatting is complete, remove the memory card.
Phone Memory Formatting Procedure
  1. On your phone dial *#7370#.
  2. Press Yes then enter your phone lock code. Default code is 12345.
  3. Formatting is complete when the phone restarts. Insert the memory card and format it again.
Jan 15, 2010 | Nokia N73 Cellular Phone
Memory card format
Phones are very picky about how their memory cards are formatted. They must be the ones to format them and sometimes they still don't accept it. They use a special file system which they need to have installed in order to use it properly.
As far as the computer making your memory card no longer pure... reformat it with your computer and make sure you look to see what file system you are putting on it (FAT32 or NTFS). I believe most flash memory is FAT32 but Windows prefers to format things to NTFS by default so you will need to change that setting.
Feb 27, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Huawei U8800-51 Impulse 4G AT&T Android Smartphone Logo
12 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
honeybun1986
john h
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
