Question about Ovens
FRAMTID ov10 ERROR F8
I have a framtid ov10 and it is displying a f8 error which I suspect is related to the auto-locking feature which is activated during the pryolytic cleaning process. Now the door is locked and it will not open. I have unlocked in manually and had a lock around but there is not obvious way to reset the lock. Can anyone help? Thanks
SOURCE: Error Code F8
Try http://www.applianceaid.com/fault_codes.html
Posted on Jan 06, 2008
  • 6 Answers
SOURCE: oven door locked
First check to see if you activated the "child lock-out". See your manual to deactivate.
You could also try unplugging the unit, or trip the circuit breaker in your home which supplies power to the oven. Wait 5 minutes and turn power back on. This will reset the controls.
Posted on Jan 26, 2008
Hold oven door light in while touching clean cycle enter up arrow or down arrow then hit cancel. door will unlock.
Posted on Nov 18, 2008
  • 41 Answers
SOURCE: Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Posted on May 05, 2009
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 | Ovens
Oven is stuck in lock mode
Hi Lora, this is AP!
Based on the description of the Frigidaire electric range provided it appears the door lock feature has been activated. In order to cancel the Oven Lockout feature, press clear off and hold for 3 seconds. The control will unlock the oven door and resume normal operation.
This door lock feature is activated by pressing clear off and holding for 3 seconds. "Loc" will appear in the display, the "Door Locked" indicator light will flash and the motor driven door lock will begin to close automatically. Allow about 15 seconds for the oven door to lock. Once the oven door is locked, the current time of day will appear in the display. If any control pad is pressed with the oven lockout feature active, "Loc" will appear in the display until the control pad is released.
This information is also located in the owner's manual should you like to view it again, you may retrieve a manual using your model# and the following link http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/.
I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Mar 17, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
F8 code on my frigidare double oven after cleaning with self cleaning oven ....know this is in the lock but need to know how to fix it myself left it unpluged overnight plugged back in and its still f8...
Hi
Yes F8 is oven door lock error warning.
You need to physically check the door switches and lock relay, these will be inside the oven casing.
It is probably not the easiest of diy jobs as everything is concealed.
Dec 16, 2010 | Ovens
Can not activate the self cleaning cycle
Before you try to use the self cleaning feature please read this tip....
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
You out to see all of the problems that come here everyday because of the selfcleaning feature on ovens....
Heatman101
Mar 08, 2010 | Viking Ovens
F8 / Convection portion of top oven doesn't work
F8 Oven door lock failure Check lock relay and door switches.
Apr 02, 2009 | Frigidaire 27 in. Electric Gallery Pro...
GMC305PD
appears that it is starting up the self cleaning feature ( which runs the temp up to the max to burn off any grease etc ) and locks the door.. You may have a defective control board.. or check the self cleaning switch position to make sure that is not activated... Hope that helps..
Aug 18, 2008 | Whirlpool GMC305PD Electric Single Oven
Error Code F8
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC)
ohhh thats not good, escpeccially with company coming, replacing the clock appox 175 for part, def wont happen by tommorow nad no you cant separate the 2 ovens both ae wired together
Mar 15, 2008 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
1,798 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
