Question about Bose Wave Radio
Poor DAB radio reception
The Dab aerial supplied with the radio is poor. Is there another aerial available? It needs to be with a 2.5mm plug
4 Suggested Answers
cjackHD
  • 71 Answers
SOURCE: AM reception
Since there is no AM antenna input on this radio, you will have to get an AM proximity antenna. One that does not need to connect to the radio. At Bose they recommend the Terk AM Advantage proximity antenna. I think you can get it on Audiovox.com.
Posted on Jun 22, 2009
  • 74 Answers
SOURCE: i have a bose wave radio and cd player the cd
you sure have a problem with your cd pick up unit or servo drive,for that must bring it to your local repair shop
as for the poor recepcion olease try a better antena
Posted on Dec 18, 2009
dunnbiker
  • 8546 Answers
SOURCE: I am having very poor
The power cord is the antenna and it should be stretched out straight for best possible reception. You could experiment with re-orienting the Bose, too.
There is a threaded 75-ohm coaxial FM External connector. You could probably get a compatible FM antenna at an electronics store.
See the manual, Page 10
Posted on Feb 04, 2011
Why will my radio new 3120 not pick up dab stations at all really tune and all I get is radio 2 have tried for a week to get magic fm thank you
If you have replaced a normal car radio with a DAB then your existing aerial is not suitable due to the required frequency range. You need a DAB aerial for cars. There are many types available, internal or external. Don't bother with converters as this will only give a marginal boost to the fm aerial.
Jun 06, 2016 | Cars & Trucks
I am trying to re tune to my local radio station radio Merseyside on dab but it says station not available or goes to another station ?
Have you checked the frequency of that Station?
Also check your aerial.
I have also found this:
Listeners to DAB digital radio in the Merseyside area will need to retune on Wednesday 20th April following a frequency change that will affect local radio stations.
The local DAB multiplex carrying BBC Merseyside, Radio City 1-3 and Capital Liverpool among others will be moving to a new frequency in order to allow better reception over a wider area. The current frequency will be turned off late on Tuesday 19th April. The new frequency will go live from 6am on Wednesday 20th April, after which listeners will need to rescan their DAB radios in order to continue listening.
May 26, 2016 | Audio Players & Recorders
I bought a Bush digtal/ AM/ FM radio ("retro transistor" style). DAB reception dropouts lasting several seconds each time have started occurring recently. AM/ FM is ok.
Constant usage of DAB should not cause it any damage ever. The dropouts are very characteristic of a poor signal reaching the DAB tuner, as digital is either there, or not there, nothing in between.
Check the aerial connection if any, the rod antenna if any, and try moving the antenna (whatever it is) to a better location, usually higher up, away from thick walls, and away from speakers if any.
Apr 18, 2015 | Grundig FR200 AM/FM/SW/DAB Radio
How do i fix faulty dab radio
If your signal keeps breaking up , you might be in a poor reception area , Check if you get the same problem on other DAB stations you are tuned into.
Mar 15, 2015 | Cars & Trucks
How do I find out if I can get DAB radio in my home of St. Just Cornwall?
Google "UK DAB Coverage" and enter your Postcode to any fo the websites that come up. Unless there is a local repeater,the nearest transmitter will be Caradon Hill or Redruth - You may need an external aerial for crackle-free reception.
Sep 12, 2014 | Audio Players & Recorders
Can not get DAB radio too work on my Vita audio but FM radio works fine
This may be because you live in an area where DAB reception is currently poor, but to check this, please use our postcode checker (see 'check your DAB coverage' panel on the right) to see which DAB stations you should be able to receive. If reception for your area appears to be good, then it may be down to local conditions or building materials. Buildings constructed from steel and reflective glass are not good for radios with internal aerials as they reflect and greatly reduce the strength of signal. In such a case an external aerial will greatly improve reception, but most importantly, if you are using the supplied telescopic aerial, you should ensure that it is properly fitted and fully extended upright.
Secondly, when our products are first powered up from new, they automatically scan the DAB network to see which services are available. During this process it is important that the radio is not touched and that the aerial has been correctly fitted and extended as instructed. If this has not been done then it is likely that not all stations will be detected and only the strong ones displayed. To correct this a new AutoScan/AutoTune or System Reset should be performed as instructed elsewhere in our Q&A's.
questions answers
Sep 04, 2014 | Audio Players & Recorders
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
Lost all DAB stations recently and purchased an
GOT NEW DAB MICRO IT KEEPS MAKING A RACKET BUT WHEN I TOUCH AREIAL WIRE I CAN GET STATION BACK WHAT IS THE PROB PLEASE HELP
Dec 18, 2009 | Audio Players & Recorders
Bose Wave Radio Logo
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
