Question about LG DLE3733 Electric Dryer
Dryer turns, blows air out vent but not heating up
  • 547 Answers
Need to replace heatin element
Posted on May 17, 2009
Why isn't my dryer drying anymore?
Clear the vent hose to the outdoors- clean the lint trap - if all vents are clear, your temp safety switch is cutting off heat (for a reason) If dryer is 5 yrs orolder - replace with higher rated energy saver - it will pay off.
Jan 15, 2018 | Dryers
No heat or air blowing inside unit
Are you sure you dont have a clogged Dryer Vnet?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Feb 09, 2014 | Samsung DV419AEW 7.4 Cu. Ft. Electric...
My Kenmore HE5 dryer will not run without blowing an internal fuse. The repairman replaced the fuse, and it blew again. The dryer heats up but will not turn it's heating element off until the fuse blows....
Has any one checked the exhaust vent,other than a bad thermostat the number one cause for the thermal fuse to open is a clogged or restricted exhaust vent flow, the entire vent system needs to be checked ( not just the hose from the unit to the wall) for proper air flow. Turn the unit on TIMED ,AIR DRY (NO HEAT) and go outside to the exhaust vent and check the air flow,if there is any question as to weather the air flow is sufishent get someone out to clean the exhaust vent ,it always a good idea to clean out every few years regardless to help prevent build up of lint witch could cause a fire......Hope this Helps Good Luck
Dec 14, 2010 | Kenmore HE5 Electric Dryer
My Whirlpool Super Duty Imperial drier won't produce heat. I made sure the outside vent was unclogged; it is blowing cold air.
When a dryer doesn't heat, either the heating element is bad, or the flap inside the venting of the dryer is opened allowing air to bypass the dryer instead of blowing the air into the dryer.
Jun 24, 2010 | Dryers
Can 3431 be converted to a regular vented dryer?
You cannot convert this model. This unit blows hot air into drum and the water is turned to steam and exhausted out through the pump to the drain. Unlike regular dryers that blow hot air into drum, creating link and just heat that blow out vent.
Jun 22, 2010 | LG WM3431 Front Load Washer / Dryer
Why does dryer heat and tumble,but doesn't blow air
No air flow is due to a restriction due to lint build up. Pull the lint filter and look closely at it. Sometimes the filter gets a residue from dryer softener sheets that can cause lint to stick to the screen and block air flow. To remove wash it with a mild detergent and use a gentle brush on it.
If that is clear then the restriction is further inside the dryer or in the vent pipe between the dryer and wall or the pipe that goes from the wall to the outside. You may have to take off the vent hose and turn the dryer on to see if air blows out the back of the dryer for a few seconds. If air blows there then the problem is in the house venting and you need to have that cleaned.
May 01, 2010 | Whirlpool Dryers
I have a GE Dryer Profile Harmony. It is several years old. The dryer is not blowing air out the back ventilation so not drying. It is making a quiet odd sound as well. When I troubleshooted I shut the...
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
Apr 09, 2010 | GE Profile Harmony DPGT750EC Electric...
Dryer isn't heating. It turns and blows air but
make sure lint screen and vents are clean. next shut off electric and check heat element for broken element. then get model # and serial # order and change thermocutoffs located on heater box and fanhousing ck these steps one by one
Dec 09, 2009 | Kenmore 75962 Gas Dryer
Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Jan 25, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
The dryer only blow out cold air.
When I turn the dryer on, only cold air blows out. There's no heat. I cleaned out the vents? What do you think is my problem> Thank you very much. K
Oct 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
LG DLE3733 Electric Dryer Logo
250 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
