Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
FILLS, THAT'S ALL
FILLS, NOTHING ELSE. HEAR TIMER RUNNING. LID SWITCH?
    Champion:
  • 219 Answers
Yes lid switch
Posted on May 22, 2009
Maytag lse7806ace
open and close the lid,if you don't hear a clicking sound you just have a bad lid switch,you have an older machine and it has a cherry switch in it,go here and look at part number 5
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-dryer-combo-Parts/Model-LSE7806ACE/3048/0152000/M0601018/00016?blt=06&prst=0&shdMod=LSE7806ACE
part number 208823,all it is is a safety so the washer can't run with the lid open so it will fill and then stop because the switch is bad.
Jun 06, 2013 | Washing Machines
Whirlpool washer won't wash or spin or dump water
usually a broken lid switch if it fills with water and then nothing,set the timer on spin and pull out the timer,open the lid and stick a screw driver into the hole where the plastic acuator on the lid goes into the hole and push down easily and see if washer will run this is where the lid switch is and it's only a safety switch so when the lid is open the washer won't run,if not push up and down on the switch and listen for a clicking sound,no click switch is bad part number 285671,watch video
http://www.youtube.com/watch?v=Ag1eT5PrMnE
Apr 06, 2013 | Whirlpool Washing Machines
It will fill up with water but nothing else
check the lid switch,set the timer on spin,push it in so it will run,get a screw driver or anything that will fit into the hole on the right side,that's the lid switch,the strike on the lid hits it when you close the lid,if the switch is broke it kills the power to the machine,it's a safety so the machine won't run with the lid open,when you push down on the switch you should hear a click and it should spin and drain,if you don't hear a clicking sound the switch is broke,or you can close the lid,lift it up a few inches and close it down,do this a few times,when it closes and opens if you don't hear a clicking sound the switch is bad.part number 3949247 and it's around 45 dollars.http://www.youtube.com/watch?v=MFsvLiuTniU copy and paste,it will show you how to get at the switch.let me know what you find so if someone else has the same problem they will read what you found,thanks
Sep 24, 2011 | Roper RAX4232KQ Top Load Washer
RCA Whirlpool Model LSQ9665J will fill with water but does not agitate, spin, or drain on any cycle. Was working fine yesterday.
put the timer on spin,open the lid,with a screw driver push down on the lid switch,if the washer starts to spin and drain the lid switch is bad,also if nothing happens,lift up and push down on the switch if you don't hear a clicking sound the switch is bad,all it is is a safety so the washer won't run with the lid open.part number 3949247 and the lid switch is around 40 dollars,
Apr 02, 2011 | Whirlpool Washing Machines
Kenmore washer will not drain
I would check the lid switch first using a pen open the lid set into spin and depress down on the lid sw if you dont hear it click then it is bad
Aug 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer
Check the lid switch first, make sure when you close the lid the switch is activated with the tab on the lid, if the switch doesnt work, your machine will only fill and wait for the lid switch to be satisified. You should hear the lid switch lick or snap when you open and close the lid.
Start here, if could be the motor or timer, however check lid switch first.
Jul 12, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Will not work
check the lid switch first, can you hear any "clicking" just before the lid is closed, try opening and closing a few times listening closely for he click, if not sounds like a bad lid switch(not recognizing the lid is closed and for safety reasons will not advance further.(far more common issue hen the timer)
Mar 24, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washer won't start/fill/spin -- anything
Dea, does the washer fill? If it fills and justs sits there it could be the pressure switch. If it fills, agitates and then no spin no drain, then it's the lid switch. If it doesn't do any of the above, it may be a timer issue. Lift the lid and gently lower it, do you hear a click when the actuator on the lid hits the switch? I will attempt to attach a picture on how the consol flips up to see the lid switch harness, pressure switch and timer. Your model will have two screws that must be removed, they maybe in back of the end caps. To remove the lid switch unclip the clips on the right and left side, unplug the harness and tip the cabinet foward. You will see how the lid switch mounts to the cab. Catriver..post back
Aug 24, 2006 | Roper RAS6233KQ Top Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
61 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
