Question about Kenwood Audio Players & Recorders
Kenwood kt 990d
Does not switch to stereo
dunnbiker
  • 8546 Answers
SOURCE: Kenwood Stereo
I presume you realize none of these things produces speaker amplification. A receiver would do that and facilitate graceful and simultaneous interconnections. But it's not a necessity for selective interconnective between them, just not all at the same time.
I can't find any details on anything you named except the Tuner.
Typically, the tuner would use an RCA pair to go to a receiver AUX, TUNER or other Line Level input for source selection and amplification. Lacking a receiver, run it to the Tape Deck inputs for recording.
Ditto for the CD changer, but you'll probably have to disconnect the tuner.
Posted on Jan 27, 2010
caroldon
  • 17130 Answers
SOURCE: HELP NEEDED I am having trouble
In the first part use the following leads
1. Keep the Power amp as the base and connect to the Cd input the CD player, the tuner to the tuner input, the cassette deck - play output to the tape in ( amp) and Rec out of tape to the tape out(amp).
connect all the RCA sockets with the R&L in the same side of the input/output.
Now the graphic equaliser input must be connected to the Amplifier's preamp output and the equaliser's output must be connected to the Amplifier's preamp input.
Now the equaliser will work through the amp.
The left and right speakers can be connected accordingly with the polarity in order.
The second system can be connected similarily with the cassette deck, tuner and cd player connected to the input of the Amplifier using the R&L RCA sockets.
Connect the speakers accordingly and test.
Please connect each RCA cord one by one and do not mix them up.
Posted on Aug 28, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have an old kenwood
Connect the RCA Outputs of the Tuner to the RCA inputs for Tuner on the amp.
Connect the output of the Tape Deck to the Tape Input on the amp.
Connect the input of the Tape Deck to the Tape Output on the amp.
Select Tuner on the amp to listen to the tuner.
Select tape Monitor to hear the Tape Deck(s).
Posted on Dec 30, 2010
AJIN G
  • 6694 Answers
SOURCE: Don't know how to hook up kenwood ka-994
Check the bellow link for the user manual of kenwood KA-994. In page number 4 of the user manual You can see how to make the connections to the receiver
Manual
Ajin
Posted on Mar 10, 2012
  • 483 Answers
SOURCE: Kenwood ka 996 integrated amp. The standby light will dont turn off. I also need to see if someone will tell how everything should be hooked up.
the standby light should be on if the unit is not 'ON' if you want the 894 to turn on when you power up the 996, then you will have to plug the ac for the 894 into the 'switched' ac outlet on the back of the 996
what specific problems do you have with this system
Posted on Mar 07, 2013
How do I reset am and fm channels on a kenwood stereo synthesiser am/fm tuner kt-57?
Trisha, I beleive you use your autoscan feature, when it stops on a station you want to keep press and hold one of the preset buttons.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Keenwood KT 57 digital tuner
ORIGINAL OWNERS MANUAL FOR KENWOOD KT 57 TUNER0 results You may also like
Jun 25, 2016 | Kenwood Car Audio & Video
How do I turn the volume up and down on a Kenwood tuner KT-56
Hello, according to the information I have, the Kenwood KT-56 tuner is just that. This means in order to have volume control you will need an amplifier. The KT-56 only allows changing of the stations, pre setting stations and may be a couple of more options. But it is only a tuner or simply put a display, now you need to put power behind it to make it put out sound.
Jun 17, 2016 | Kenwood Audio Players & Recorders
Where can I find a manual for Kenwood Tuner kt-57?
Is it a tuner only? If so you will need a power and or just a receiver with speakers. A tuner only has no power output for things like tvs.
Mar 25, 2016 | Kenwood KT-57 Stereo Synthesizer AM/FM...
Mar 07, 2013 | Audio Players & Recorders
I just got a Kenwood system, i would like to know how to hook it up, it has, Kenwood power amplifier km207, kenwood stereo control amplifier kc 207, disc player dp-m 97, cassette deck ky-77 cw, stereo...
That's a pretty standard setup. RCA cables from the KM207 to the preamp (KC207), and RCA cables from all of the other components into the KC207. Speakers connect into the KM207
Nov 01, 2012 | Master DE Kenwood with Housing...
Manual
Ajin
Mar 09, 2012 | Audio Players & Recorders
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Kenwood installation manual help?
Click HERE for Kenwood support and manuals.
May 15, 2008 | Kenwood Audio Players & Recorders
Kenwood Home Stereo System
this outdated system,but a regular rca cable will inter connect the components.as or the remote Box i am not aware of any.
GoodLuck
BIGRED
Feb 17, 2008 | Audio Players & Recorders
57 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
