Question about Dell OptiPlex GX280 PC Desktop
I need only circuit schematic diagram
My system fan is runing very fast
    Problem Solver:
  • 10 Answers
Do you require circuit diagram because your fan is running fast? If yes, the reason is probably the CPU is over-heating. Check the CPU temperature in the BIOS. The internal area of your desktop case should be free of dust, especially the CPU heat sink/fan. Use an air blower to make it dust free.
The fan on the motherboard spins fast when and as required in order to keep the processor cool. You may also want to check / replace thermal paste between heat sink and processor if necessary.
Posted on Dec 25, 2013
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 22 Answers
Restart it or get off of gamesites or things like, Minecraft, Call of Duty, Terraria, and others like those. If a game takes a little to load and after a while you can hear the fan getting louder you can do something else until the fan starts to slow down a bit.
Schematic?
A schematic, or schematic diagram, is a representation of the elements of a system using abstract, graphic symbols rather than realistic pictures. A schematic usually omits all details that are not relevant to the information the schematic is intended to convey, and may add unrealistic elements that aid comprehension. For example, a subway map intended for riders may represent a subway station with a dot; the dot doesn't resemble the actual station at all but gives the viewer information without unnecessary visual clutter. A schematic diagram of a chemical process uses symbols to represent the vessels, piping, valves, pumps, and other equipment of the system, emphasizing their interconnection paths and suppressing physical details. In an electronic circuit diagram, the layout of the symbols may not resemble the layout in the circuit. In the schematic diagram, the symbolic elements are arranged to be more easily interpreted by the viewer.
Schematics and other types of diagrams, e.g.,
Transit map, a schematic map (i.e. not drawn to scale, stations are equidistant, lines are drawn at 45 and 90-degree angles)
Schematic of a drive train
Chemical engineering schematic
exploded view of a 3D-engineering drawing
Jan 22, 2016 | Computers & Internet
Car overheating
You will have to troubleshoot your cooling system. If your running out of water, then you need to check for signs of external or internal leakage. Could be a head gasket. You need to make sure your fan is working properly and that your thermostat is good. Also your cooling cap could be bad. Make sure it is holding pressure.
Jan 07, 2012 | Ford Escort Cars & Trucks
Schematic diagram example of AC DC regulated power supply 1.5volt to 35volt
You will need to add transformer and rectifier diodes before this circuit to be able to get the voltage you need.
See the link below of the regulated part of the circuit
http://simpleelectronic.com/2010/06/11/simple-adjustable-regulated-power-supply-circuit-diagram/
If you need more help let me know.
Sep 29, 2011 | Computers & Internet
I need to know what each color means on my distributor???
Review this guide as reference; this Electrical Schematic Diagram applies for 1994 Accord Coupe series of model. Here you will find complete explanation about electrical system of the vehicle. Started from Troubleshooting (tips and precautions) on handling the electrical system, in this manual you will be guided step by step examining each electrical component installed and its connection for example in Wire Harness and Ground Location, started from Engine Compartment, wiring harness is shown from engine ground cable, starter cable, and battery ground cable.
These 359 pages of pdf.fieltype manual is divided into some sections which are Wire Color Code, Relay and Control Unit Location, Wire Harness and Ground Location, Air Conditioning System Circuit, Anti-lock Brake System, Battery, Blower Control, Charging System, Cruise Control, Fan Control, Fuel Pump, Fuses, Ground Distribution, Heater Control, Ignition System Control, Lighting System, and etc.
Download the complete 1994 Accord Coupe Electrical Schematic Diagram here.
You can also find complete workshop manual of 1994 Accord Coupe here.
Pass: freepdfmanual.com
Good luck.
Sep 21, 2009 | 1997 Honda Accord
I'm looking for a wiring schematic for the electrical cooling fans on a 1996 chevy lumina car my girl let her exbf straight wire it and now its not working properly i'm sure i can fix it if i can just find...
Hello freak4style, my name is JShreader. Thank you for choosing fixya.com.
Click HERE for the Wiring Diagram for the Fan Circuit on your Lumina. I hope this helps you. If you have any more questions or need any more diagrams, please don't hesitate to ask...Thanks again, JShreader!
Apr 01, 2009 | 1996 Chevrolet Lumina Mini
Ups
filter cct burn out so, kindly give e filtter cct of 800 apc ups.
Sep 16, 2008 | Computers & Internet
Ciruit or block diagram of pioneer home theater system
The (schematic) circuit diagram is included in the service manual. A downloadable pdf copy is available here.
Hope this be of help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 13, 2008 | Audio Players & Recorders
Dell OptiPlex GX280 PC Desktop Logo
85 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
