Question about Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round
Sanibest toilet is LOUD when flushed
My sanibest pump was working properly for a while and would drain out the pump with a medium length burst when full (I also have a washing machine and sink draining into the unit). Now, it seems to drain out using an endless series of short bursts. The main problem, is when you flush the toilet, it is now REALLY LOUD, so I am assuming there is a problem with the macerator. It actually shakes the house now when flushed. When the toilet is flushed, it gives a short burst, followed by the long, loud burst, followed by another short burst. Is the macerator maybe plugged up with something? Is this something I can fix myself, or does it need to go into the shop? Any info would be great! Thanks.
  • Ned C Cook
    Ned C Cook May 11, 2010
    I'm sorry, Mind on something else.. Disregard the motion part of last post.. Please
    Problem Solver:
  • 17 Answers
Shut down the power and pull the pump from the unit and give it a exam. There might be something as simple as a item that was flushed down the toilet (pencil, pens, combs, etc.) or just a hair clump. Check that the float is free to track fully up and down. Good Luck!
Posted on Jul 07, 2009
My washing machine leaks alot of water from the drain trap while it is working or when it has just done a wash.
Thanks for the model number. The leakage is very likely from the drain hoses that are connected to the drain pump. For your model the drain pump is located at the bottom front behind the bottom plate. You will have to remove the screws holding the bottom front plate. Once you get this out you can access the drain pump and hoses. Either one of the two hoses (inlet from drum or outlet to laundry drain hose) could have burst or lost hose clamp. Need to fix this. Also check the laundry tub drains are clear and there is no back water into washing machine.
May 01, 2014 | Washing Machines
F&P MW511 HELP beeping and not draining
You have a blockage in the drain hose or pump,
Try to drain all the water out before you remove the pump
Error Code 37,
37. (00100101) Phase 1 to 6 - Pump Blocked Error ( No change in the water
level)
While draining, the water level reading from the pressure sensor has not changed
for over 3 minutes. There are three likely reasons for this fault. One is that the
drain hose or the pressure switch hose has been squashed or kinked and the pump
out rate has been dramatically reduced. The second possibility is that the pump is
partially or fully blocked. The third is that the pump is not operating due to Motor
Controller module, wiring or pump failure. This fault could also appear if the
machine is pumping to an unusually high head of drain hose or into an extended
length of drain hose. The Fourth possibility is a diverter valve fault or blockage,
water level is not altering as the diverter is stuck in the recirculation mode, giving
the module the appearance the pump is not lowering the water level.
Primary Source: Pump System.
Action:
1) Check that the drain hose has not been kinked.
2) Check the length of the drain hose and try to reduce the length if excessively
long. A 1 metre extension hose of the same diameter fitted to the existing
drain hose is the maximum allowable length.
3) Check for open circuit windings in the pump. (Note: Pumps are fitted with a
thermal cut-out which will reset on cooling.)
4) If the bowl is empty of water, remove the pump from the pump housing and
check that it is not blocked. Also check the drain hose is not blocked.
5) If the bowl contains water, then service the pump from the top of the machine
by removing the top deck and inner bowl. Bail out the water, remove the
pump cap and hood and clear the restriction.
Secondary Source: Wiring.
Action:
1) Check the pump harness is connected correctly to the pump.
2) Check continuity of the pump harness.
Tertiary Source: Motor Controller module.
Action:
Activate the pump by operating the machine in spin mode. Check the pump
is rotating. If it is not operating, and Primary and Secondary checks have
been performed, then replace the Motor Controller module.
Note: Consider fitting Pump Hood Kit (WM013). If 5kg Smartdrive fit splash guard to
pump.
Jun 10, 2013 | Fisher and Paykel GWL11 Top Load Washer
Bosch Nexxt Premium Washing Machine Drainage Blocked. Cleaned out impeller still not working.
You need to check the drain pump externally to see if the pumping is good Also remove the drain hose clamps and remove the drain hose flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jul 02, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
I have a Fisher Paykel GWL11 Top Loader Washer. It washes fine, but when it goes into Rinse it stops. No Locked Lid light on
You may have a pump blockage or pump not working.
37. (00100101) Pump Blocked Error (No change in the water level)
While draining, the water level reading from the pressure sensor has not changed for over 3
minutes. There are three likely reasons for this fault. One is that the drain hose or the
pressure switch hose has been squashed or kinked and the pump out rate has been
dramatically reduced. The second possibility is that the pump is partially or fully blocked.
The third is that the pump is not operating due to Motor Control Module, wiring or pump
failure. This fault could also appear if the machine is pumping to an unusually high head of
drain hose or into an extended length of drain hose. The fourth possibility is a diverter
valve fault or blockage, water level is not altering as the diverter is stuck in the recirculation
mode, giving the module the appearance the pump is not lowering the water level.
Action: 1) Check that the drain hose has not been kinked.
excessively long. A 1-metre extension hose of the same diameter
fitted to the existing drain hose is the maximum allowable length.
fitted with a thermal cut-out, which will reset on cooling.)
housing and check that it is not blocked. Also check the drain
the machine by removing the top deck and inner bowl. Bail out the
water, remove the pump cap and hood and clear the restriction.
Action: 1) Check the pump harness is connected correctly to the pump.
Tertiary Source: Motor Control Module.
Action: Activate the pump by operating the machine in spin mode. Check the
pump is rotating. If it is not operating, and Primary and Secondary
checks have been performed, then replace the Motor Control Module.
Jun 18, 2012 | Fisher and Paykel GWL11 Top Load Washer
How to test a drain pump for Kenmore Elite he3T washer?
easy length of wire with ends bared wrap around pump terminals and plug it in .simple usual health and safety precautions to be taken of course
Mar 19, 2012 | Kenmore Washing Machines
It wont work it flashes fl
the Fl code indicates an overfill condition. If the washer is empty, then you likely have a problem with the water level pressure switch. If the washer is full of water and will not drain, you likely have a problem with the drain pump or the washer drain line.
If the washer is full of water, make sure that the washer drain is clear and working properly. Check the drain hose for kinks or clogs. If you find no problems with these issues, I recommend that you manually drain the washer using a wet/dry shop vacuum. Check the drain pump and connecting hoses for problems. You may need to replace the drain pump of water will drain out of the washer properly but the pump will not work properly. A clog in the check ball assembly at the bottom of the tub can also prevent the washer from draining properly.
Aug 11, 2011 | Maytag Neptune MAH5500B Front Load Washer
While running the washer in mid cycle, quit working. Ld error code. the tub has water. emptied clothes. Unplugged, burst if water, then stops
Ld is = Long drain, something has plugged the pump and must be remove to work properly, or the pump has failed 95% of the time its a sock or something like that.
Apr 09, 2011 | Washing Machines
My Sanilflo system is fed by a toilet and a sink. When the sink fills it to operating the grinder runs for about 5 seconds and switches off. When the toilet is flushed (no solids) the grinder runs for...
The amount of time that the pump operates is determined by the amount of water that is drained into the unit. If the amount of water from the sink is less them the amount flushed then the pump will run accordingly.
Mar 06, 2011 | Saniflo SANIBEST Pump Macerator Grinder...
Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round Logo
654 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
