Question about Coleman Grilling
Propane tank won't light even though there is a "clicking" noise
  • 68 Answers
Try to see the connection i think there's some particles blocks the way.
Posted on May 18, 2009
3 Suggested Answers
  • 4736 Answers
SOURCE: Master forge grill won't light with 2nd propane
Here's the problem and how to solve it. When you opened the valve on the tank, you did it as you normally would. However, the new OPD Valve tanks will often shoot a heavy load of gas to the regulator and lock it up.
To hopefully solve the problem, do the following:
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow), until the valve is fully open.
Then light the burner farthest for the tank first. Did the burner light and does the flame height
look correct? If so, light the remaining burner(s) the same way. Do all the flame heights look
correct? If so, you solve the problem. Remember to always open the tank valve Very, Very
Slowly.
If that didn't solve the problem, you will need to replace the Grill's Hose/Regulator Assembly. You can pick one up at any hardware store or home center that sell grills and accessories for about $30.00. Take you old one with you for comparison purposes.
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy grilling!!
Posted on Jun 28, 2011
  • 4736 Answers
SOURCE: Won't light! New tank, regulator is positioned
Sheldon, this happens a lot, but it's easy to solve.
1. Turn the gas tank's valve OFF & disconnect the hose from the tank.
2. Wait 5 minutes & reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow Motion, slow).
4. Once the valve is fully open, light the burner farthest from the tank first and turn to HIGH.
Did the burner light and does the flame height look correct? If so, light the remaining burners
one at a time the exact same way. Do all the flame heights look correct? if so, you solved
the problem (with a little help). Just remember to always open the tank valve Very, Very Slowly.
If the above did not solve the problem, you will need to replace the grills Hose/Regulator Assembly as it is permanently locked up. You can pick one up for about $30.00 from any hardware store or home center that sells grills and accessories. Take you old one with you for comparison purposes.
I hope the helped you and Happy Grilling!! Thanks for choosing FixYa.
Posted on Jul 21, 2011
I have a KitchenAid 6 burner range / model # KGCP467. It does not appear as if it has ever been used. I bought the LP conversion kit. Replaced the burners and flipped over the plastic piece in the...
I would look at your pressure. My guess is it is too high. The cooktop is designed to run 10-14 iniches water column which equals .36 - .5 psi. If you were running higher than this you could have damaged components in the cooktop.
Apr 07, 2017 | KitchenAid Kitchen Ranges
My fire place elecric starter won't work after running out of propane
Most likely, you need to "bleed the line". The new propane needs to travel to your fireplace, but you have a huge air pocket in there now since it ran dry. It takes forever for the air to "bleed" out through the tiny orifice of a pilot light, especially if the distance from the fireplace to the tank is far.
Jan 28, 2013 | Skytech 3301 Thermostatic Gas Fireplace &...
Refill water tank light won't go out
Then replace it because they are not repaired.
Jun 30, 2017 | Philips GC 8220 Iron
Won't light! New tank, regulator is positioned right. It's brand new! Ignitors work! Can smell propane when i turn the tank on....Can't get it to light. It's set up for propane.. Can't...
Jul 21, 2011 | Jenn-Air JLG7130A
Won't light even though I just replaced the propane tank - I tried using a match as well and can't get it to light any suggestions on what the problem might be?
You may have turned the tank valve on too fast causing the excess flow valve to cutoff the flow of gas. Turn tank back off, disconnect, reconnect, and very slowly turn it back on. If you need more assistance, let us know.
May 17, 2010 | Brinkmann Grilling
What could be my problem
Check your switching device, it is defective. Have it repaired or changed.
Sep 21, 2009 | Refrigerators
The valve on my propane tank won't turn off or on. grill lights
suggest you take the tank and trade it in for a new one with one of the propane companies like blue rhino. it's about $15 to $20 and you get a brand new full tank.
Jul 16, 2009 | Grilling
We bought a new 41 inch viking grill. Hooked up LP regulator and tank. When we light the burners there is a loud humming noise that is coming from the regulator and/or hose (we have reassembled twice to...
First make sure everything is tight on the valves if you still smell it get some windex spray where you hoses, the tank where it connects places where the propane gone if it bubbles you have a leak for the noise turn the tank upside down and shake it for about 10 second
Jul 12, 2009 | Viking VGBQ532-3RT All-in-One Grill /...
Grilling Logo
394 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
paulcarew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
