Question about Sharp Video Cameras
Where do i plug in a cable to connect the cam to a tv or computer? i only see an ear socket and an ext mic socket on the cam.
With the sharp viewcam VL-E30H, where do i connect the cam to a tv or computer? , i only see an ear socket and an ext mic socket on the camcorder. thanks brum
  • brumtilly May 18, 2009
    no flaps or sectret compattments on mine.
    I have been told now that there is a seperate part that plugs into where the battery goes and the cables connect to this and then to the tv/ computer. SO problem is now osolved whn i get this extra part .
    Thanks anyway
    Problem Solver:
  • 7 Answers
On my Panasonic camcorder, the RCA plug-ins are in a separate compartment covered with liftable flap. Try searching for this flap. My flap is next to the battery compartment.
Posted on May 18, 2009
How do I connect my sharp camcorder model VL-E650U to my Samsung tv series 6 630 lcd tv to view the 8mm videos on my TV screen?
You will have to use AV cables and an adapter. The adapter looks like a scart cable connector, it is that shape , and it has 3 inputs
one red one white and one yellow. It should fit in a spare scart socket on the tv and the cables should attach to the camcorder.
Just program the video to a particular channel, you may have to consult your owners documentation to discover how this is done. Go to the channel, insert the tape and press play.
Jun 25, 2015 | Samsung Video Cameras
I do not have any rca or s-video input on my computer. How do I plug it in to copy it on computer?
Have you checked if it has other connectors? Typically, it might have a 3mm round plug, that is the same as your 3mm headphone stereo plug socket. The one on my camera has this but is has 4 coaxial connections along the shaft, instead of the 3 that you would see on a headphone plug. You will then need a suitable cable which would have RCA plugs on the other end. Alternatively, check the manual. Remember, if you don't have a manual for it, just go onto the Sharp website, and download one. They usually have them available for free.
Dec 12, 2011 | Sharp Viewcam VL-Z1 Mini DV Digital...
What cable do I need to set up the HD and where do I plug it in? All the ones I lookes at have a rectangular end and I don't see one on the like that on the TV. I am using the 2 scart sockets for cable...
Any of these will work.
ANTENNA IN: UHF/VHF 75 ohm Din type (If in HD Broadcast)
EXT 1: SCART (AV Input/Output, RGB Input, TV Output)
EXT 2: SCART (AV Input/Output, Y/C Input, AV Link)
EXT 3: S-VIDEO (Y/C Input), RCA pin (AV Input)
EXT 4: RCA pin (Vomponant Input)
PC INPUT: D-sub 15 pin (ANALOG RGB), 3.5mm Javk (Audio Input)
Service Manual can be found here: http://www.givemefile.net/smanuals/lcd_tvs/sharp/file/45437.html
Feb 06, 2011 | Sharp Aquos LC-26GA5E 26 in. HDTV-Ready...
How can i hook my cam to my computor
Welcome to Fixyah,
To connect that device to your computer make sure that your camcorder had a fire wire or usb cable. If your camcorder has no capacity to connect using those cable all you have to do is to get the third party hardware device such as capture card which has the audio video cable to connect to it then from that device that can connect to your computer using usb cable.
Aug 10, 2010 | Sharp Viewcam VL-AH150U Camcorder
Computer not reading my cam
u need to first install your software that came with your camera and then plugin your camera after restarting pc
Jun 25, 2009 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Hi can someone please tell me what i need to convert my old vids
One hour + $45---
Although the View Cams are no longer supported by Sharp most I remember have a digital connection through which the video will upload to you computer. Laptop, desktop or tower? IEEE 1394/ iLink 4-pin or 6-pin? Find the appropriate connection for your computer and go. The Sharp's end should be a 4-pin connector. You computer's native one probably is 6-pin. Any consumer electronics store will have the 4-to-6-pin cable. Cable to computer then cable to turned off camcorder. Turn on camcorder. Windows Media or Toast will handle most simple home projects. No IEEE 1394 on your computer? I get a generic PCI-slot add on card (up to $20 at the same stores), install it and (already have a DVD burner?) ..go!
The alternative path costs about $80.
Take the cam with you to the store. Find a generic A/V cable( a 3-ringed 1/8-inch pin plug[to the camera with video=yellow and 2-channel-white=left and red=right]audio dangling from the other end for a converter) and buy a A>D converter(Turtle Beach, Dazzle etc) that connects via USB. These converters usually come with software to make happen what you want. Good Luck
vac8
Jan 14, 2009 | Sharp Viewcam VL-AH130U Camcorder
Mini Cassette to DVD?
you need a firewire cable to go from cam to computer or use a dvd recorder and put tv connections from cam to dvd recorder
Jul 27, 2008 | Sharp Viewcam VL-NZ100U Mini DV Digital...
NEED DRIVER FOR SHARP VIEWCAM MODEL VL-PD3AE
http://www.sharpusa.com/products/TypeSoftware/0,1086,47,00.html
If I had a model number it would be alot easier
Oct 19, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Retail outlets in Canberra
the firewire cable is available at the computer shop when you buy a ee1394 card...the av cable i know is included on the camera kit when you the camera.. if not included then try to the authorized dealer of sharp..
Aug 12, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Video Cameras Logo
307 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
