Question about Emerson LD195EM8 19 in. LCD TV
Pairing codes for bluetooth devices
Need bluetooth pairing codes
  • Emerson Master
  • 3,320 Answers
Most devices use 0000
Posted on Mar 05, 2014
Pairing Code for ASUS r503c?
If you are talking about connecting a Bluetooth device to your laptop the laptop would not typically have a paring code. The device however may.
For example you would not be able to enter a code into Bluetooth headset as it does not have a keypad, so a code is pre-set into the device. Whatever the device you are trying to connect with see the manufactures manual or try 0000 as the code.
If however you are trying to pair with something like a mobile phone (providing both Bluetooth devices are set to "Discoverable") then you should be able to start the pairing from either the laptop or phone. Once the 1st device (That you has started the search/pairing from) asks for the pairing code you may enter ANY 4 DIGIT CODE OF YOUR CHOOSING. Once the is done you should be prompted to do the same on the 2nd device and you simply need to enter the SAME 4 DIGIT CODE.
This should complete the pairing.
Nov 22, 2013 | Computers & Internet
Bluetooth pairing codes
If you are familiar with Bluetooth wireless technology, you'll probably recognize the term "Bluetooth pairing". But do you actually know what Bluetooth pairing means?
Bluetooth pairing occurs when two Bluetooth devices agree to communicate with each other and establish a connection.
In order to pair two Bluetooth wireless devices, a password (passkey) has to be exchanged between the two devices. A Passkey is a code shared by both Bluetooth devices, which proves that both users have agreed to pair with each other.
This is the normal process that occurs with Bluetooth pairing:
Oct 06, 2012 | Radio Communications
What is the numeric keycode for pairing bluetooth? Jabra BT2035
As you pair the bluetooth in your computer and a bluetooth device, it gives you a pairing code, only if needed so, like the keyboard. The pairing code is seen in the computer, and is generated by the computer as you click on "create a pairing code". For other devices, a pairing code is NOT required.
Thank you for visiting FixYa!
Apr 25, 2011 | Computers & Internet
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
Code for sony dr-bt100cx bluetooth
Hi, when you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope that helps...
Thanks for using fixya.
Nov 25, 2010 | Sony DRBT100CX Bluetooth Headset
I go to the bluetooth menu and turn it on. it says "Bluetooth turned on" But the icon fails to appear and file transfer fails.
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Aug 16, 2010 | Sony Ericsson K550i Cellular Phone
Need the pairing code for bluetooth device to my Altec Lansing
Hi if your intentions are too connect your Phone to that bluetooth device , The paring code is what you make it , when you connect the two device's together , When you search for devices it will ask you to pair with that device , and you make the code anything you wish....Otherwise have a look at the manual under connection , it should have .
I hope this helped bud
Happy new year
Dec 24, 2009 | Altec Lansing iMT525
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Emerson LD195EM8 19 in. LCD TV Logo
136 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
