Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
WheI need after market filters for the wind storm vaxuum Modes AT7961 VOLTS 120 AC 650W AMPS 5.4 HERTS 60re to find wind storm filters
All I need is some filters that will fit this vacuum
I am trying to find out the size of the filter. The model is C 2006P. It also does not have a brand name, only a D on the side. It takes a cyclone shaped filter
Mellisa, searched the net, very little info. suggest you take vac/filter with you and stop by a vac/repair shop who will be able to see if it matches other models and can set you up with replacement filter.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 27, 2016 | Filter Vacuums
My problem is that Model 16N5-K, 120v 60Hz 12 amp Bissell Vacuum cleaner has no wattage indication in the unit itself, in the box, in the product brochure. our power output in the Philippines is 220v. I...
All the information you need is in your text :>)
Volts, Amp Watts To determine the wattage, use a simple multiplication formula. The ampere (or amps) is the amount of electricity used. Voltage measures the force or pressure of the electricity. The number of watts is equal to amps multiplied by volts.
How to Calculate Wattage (Formula and Tools) - wikiHow
www.wikihow.com/Calculate-Wattage
To find a step down transformer for 1440 watts, you will buy a new vacuum cleaner cheaper.
volts amps watts equation Google Search
Oct 01, 2017 | Vacuums
HOW DO I TAKE APART vax performance 2200
I fixed a stuck mains cable on a VAX 2200 and made this take-apart guide. Use at your own risk. I hope it helps someone.
http://homepages.herts.ac.uk/~comqpq/VAX2200-takeapart.pdf
Jan 20, 2012 | Vacuums
What brand ceiling fan is this AC-52 5AO-0034
Not sure of the brand, but I believe it was manufacutered by Shi Chen Electronics of Taiwan.
Specs: 120 V, 60 Hz, .9 Amps, 80 W
Aug 13, 2011 | Vacuums
I have Wind Storm vacuum Cleaner. I need a replacement filter for it, but thier customer service number wants me to sign up for a membership with a monthly fee to have my question answered. Do nI just...
If you search the interned for Windstorm Vacuum, you will find many complaints and a class action suit. If you received and like your vac, you are in a minority.
I could find no parts.
Gary
Feb 23, 2011 | Vacuums
We just moved in - the house is about 9 years old. I have a Eureka Mega Boss central vac - looks like model # is CV20220. 12.4 amps, 120 volts. Can't figure out what type of bags I need. Can you...
Well, for this unit you will need any of the following bags,
Eureka genuine Part# 90610
Eureka replacement (Central vac bag)
another genuine bag style called CV-1, and/or CV-2
Kenmore Central vac bags
Most of the bags there are available at your local vacuum shop, and sometimes even Sears. The Kenmore central vac bag is, can and will fit your Eureka Mega Boss. Prices range on these bags anywhere from $12-$20 for packages of 3. Generally you will replace a bag once every 3-4 months.
Good luck,
Mark
Nov 10, 2010 | Vacuums
Service/repair needed for Dyson DC07 in Herts, UK
try go bestbuy store service
Customer Service, Web Site, Store and General/Corporate Inquiries
1-888-BEST BUY (1-888-237-8289) frmContactusForm.email.style.display='block'; wS('1','10')
Feb 13, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Wattage for Kirby Sentria G10D
The conversion of Amps to Watts is governed by the equation
Watts = Amps x Volts
For example 1 amp @ 110 volts = 110 watts
your case 7 amp @ 120 volts = 840 watts
unless you are running it at 230v but I don't think you can
I would look for one rated for Volt-Amps instead of watts
It's best to round up to be safe add 40 - 60 watts
Don
Apr 25, 2009 | Kirby Ultimate G Bagged Upright Vacuum
About kirby carpet extracters
The heritage 2 pulls 5.5 amps or 660 watts in hose mode and 4.5 amps or 540 watts in carpet mode.
Volts to Watts
The conversion of Volts to Watts is governed by the equation Watts = Amps x Volts
Mar 24, 2009 | Kirby Heritage II Vacuum
Won't start
take an AC VOLT Meter and place the leads of the meter where the power cord terminates,one on the white lead and one on the black. There should be 110-120 volts AC. If that is good then move one of your meter leads to the other side of the on switch. With the on switch ON there should be 110-120 volts AC.If that is good, you may want to connect the motor directly to wall current to ensure that it is good. BE VERY CAREFULL IF YOU DO THIS!!!!!!!!!!!!!!!!!!! Before you do anything be sure to make sure that there is not a breaker or reset button somewhere on the machine that has been overlooked.
Oct 21, 2007 | Electrolux Epic 6500 Vacuum
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
35 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
