Question about Streamlight Protac HL Flashlight, 600 Lumens, Pocket Clip, Hi/Low/Stobe, 2-CR123A-88040SL
How to program the ten-tap" programmable switch.
The manufacture didn't give instructions on how to set the high/low beam/strobe program. Or C4 LED.
    Sergeant:
  • 236 Answers
Hi, I have placed a link to the instructions for the ten-tap programming.
Posted on Jan 06, 2014
2 Suggested Answers
  • 114 Answers
SOURCE: Don't know how to use the ten-tap programmable switch
The Instructions are here:
http://www.streamlight.com/static/document/product_instructions/protac-hl_op_inst.pdf
Posted on Dec 25, 2013
How to charge Coast PX45?
not a rechargable light .put in new batteries
Jul 01, 2016 | Coast PX45 LED Flashlight
When my E2d. Ed defender. 200 lumens flash light is turn on it act like an strob light how to stop it or is it a weak batteries
No, that is a 'feature'. It is for signalling or blinding an attacker.
This is the instructions for the 500 lumen version but it will be the same. Nice light, I run Fenix Tactical. Strobe is usually gained by switching on and then half depressing the button and holding. If this doesn't work, contact Surefire direct.
The E2D LED Defender® Ultra is a compact 500-lumen flashlight featuring dual-output capability and self-defense enhancements. Utilizing a virtually indestructible high-performance LED and a Total Internal Reflection (TIR) lens, the E2DL Ultra is activated with a pushbutton tailcap click switch that also selects output levels: press or click once for a high-intensity 500-lumen white-light beam-ten times the light needed to overwhelm the night-adapted vision of an aggressor. Return to off and press or click again within two seconds for a 5-lumen ultra-long runtime low beam that's suitable for navigating at night or performing close-up tasks for hours. The Defender's crenellated Strike Bezel® provides further defensive options should the need arise. Slender and powerful, the E2DL Ultra is an ideal everyday-carry light.
Jan 08, 2016 | Surefire E2D LED Defender Flashlight Max-...
HI .. Can you uys help me i need to put my led light but unfortunately i cant because of the magneto i need only 12v but my motorcyle produce higher than 12v it can destroy my led light i have this co
Your shogun does come equipped with a voltage regulator to protect your headlight, you shouldn't tap off the ignition circuit or directly off the alternator just for the reasons you listed, plus it can affect these systems unpredictably. Can you tap off the hot side of your horn before the switch, or taillight? If you tap off your headlight it would only work either in the high or low. Of course for the negative (-) side, grounding it any place on the frame is fine. Give these spots a try. Take care and enjoy your ride.
Dec 10, 2014 | Suzuki Motorcycles
Why are Dashboard lights not working on high beam?
check the dimmer switch, I had the same problem. this dimmer switch didn`t dim on low beem but went out on high beams, turned the dimmer switch up and down/on and off and it came back on.
Apr 24, 2014 | 2008 Toyota RAV4
Dec 25, 2013 | Streamlight Protac HL Flashlight, 600...
How do I use the ten-tap programmable switch
Hi, I have included a link to the instructions for the ten-tap programming.
How do I adjust the low beam headlght on a 2006 Sabaru Tribecca B9
I have a similar problem. The adjustment screw adjusts both the high and lof beams. After changing the passenger side low beam, both sides then pointed at the ground. High beams were fine. I adjusted so the low beams are fine but now the high beams point straight up.
In talking with Subaru Service he said there is a "module". He said after changing the bulbs they should point down then auto-adjust back up. That didn't happen. I haven't found anything on such a module. He said it woul be $109 for adjusting the lights OR for the module.
If I find anything more I'll let you know.
Apr 10, 2011 | 2006 Subaru B9 Tribeca
HIGH BEAM LIGHT STAYS ON IN DASH ...SWITCH GOES HIGH AND LOW BUT ONLY WORKS ON HIGH (ONE LIGHT) AND NO LIGHTS ON LOW
I have the same problem and I've tried two fixes so far and neither has worked.
- I replaced the daytime running light module and that didn't work
- I replaced the trun signal/hazard/light switch and that didn's work
I've had one comment that it could be a ground issue.
hope this saves you spending money on "fixes" that don't solve the problem
Dec 03, 2010 | 1996 Pontiac Sunfire
I HAVE REPLACED THE BATTERY IN MY KEY FOB BUT IT IS NOT WORKING. IS THERE ANYWHERE I CAN BUY A NEW CIRCUIT BOARD FOR IT?
NOTE: If a double audible warning sounds during the programming procedure a system malfunction has occurred. Repeat programming procedure.
Obtain all keys fitted with remote control. Open driver's door. Operate headlamp high/low beam switch to flash high beam position and hold. Insert key into ignition switch, turn to ACC position. Ensure system LED flashes once and an audible warning sounds. Operate headlamp high/low beam switch to flash high beam position 5 times. Ensure system LED flashes once and an audible warning sounds. Programming mode activated: Press and release lock or unlock button on first key. Ensure system LED flashes once and an audible warning sounds to indicate correct programming. Repeat programming procedure for remaining keys. Switch ignition OFF and remove key. Close driver's door. Check operation of keys. Keys can also be programmed using diagnostic equipment.
Mar 21, 2010 | 2002 Jaguar S-Type
Key fobs not working i have changed the battries on both
Jan 31, 2010 | 2002 Jaguar X-Type
Streamlight Protac HL Flashlight, 600 Lumens, Pocket Clip, Hi/Low/Stobe, 2-CR123A-88040SL Logo
186 people viewed this question
Top Streamlight Camping, Backpacking & Hiking Experts
Stan Ford
Tom Chichester
Are you a Streamlight Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
