Question about Honeywell Heating & Cooling
Honeywell st1000 The central heating is not working including hot water
  • 16 Answers
SOURCE: cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Posted on Aug 17, 2009
heatman101
  • 43501 Answers
SOURCE: st6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Posted on Nov 12, 2009
  • 767 Answers
SOURCE: honeywell T8400c thermostat went blank. central
I would check the batteries in the thermostat. If the batteries are okay then you might have a blown fuse in the furnace or the furnace lost power check the breaker.
Posted on Jan 21, 2010
  • 36 Answers
SOURCE: boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Posted on Jan 31, 2010
  • 3248 Answers
SOURCE: Honeywell ST6400C programmer
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Posted on Feb 18, 2010
How do I fix central heating
The first thing you need to substantiate is the fact that there is enough water in the system. It will be a closed loop system requiring approximately 10 psi/ floor. (Only a rule of thumb). Usually when one protion of the system works and the other does not, it is an issue of water quantity available to circulate through the combination of loops. If you have to add water, you will probably have to purge air from the highest points in the system. Even if there is an "Airtrol" fitted in the bottom of the expansion tank, bleeding the high points will eliminate air quicker.
The hot water portion of the loop should only be going through a heat exchanger that transfers the loop temp to the domestic water circuit and the three way valve is probably a 'mixing valve' utilized to maintain a certain loop temperature on the primary loop.
Dec 01, 2014 | Honeywell Heating & Cooling
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Oct 21, 2017 | Heating & Cooling
I need programming info for an Altech model ALTHC001 central heating and hot water programmer
Can you please tell me how to set clock for central heating the clock is an althc001 had power switch off and when it was turn back on the clock is not working when the boiler is calling for heat and the same with the heating can you help
Oct 07, 2011 | Honeywell Programmable Thermostat Heater
St6400c thermostat wont run the central heating independantly
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
Boiler is a baxi control for heating is honeywell.
it will e split.
Oct 05, 2009 | Honeywell Programmable Thermostat Heater
Cannot get central heating working,for honeywell ST6400 programme
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
Honeywell T403A1174 suddenly doesn't appear to call for heat
some times inside the boiler on the internal pipework you will see little sensors, on the central heating piping there sometimes is a thermastic sensor on side of flow pipe with a little reset button on ? i guess with the problem you said the poiler locked out and the pipe work overheated ? this is a safety feature on some boilers not, all and easerly reset via this button ?
Jan 31, 2009 | Honeywell Water Heaters
Honeywell Central Heating Timer ST699
In the end I bought another timer on sale/return. My heating didn't work with that one either, so my problem's not the timer but something else.
Aug 26, 2008 | Kitchen Appliances - Others
Jul 25, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
26 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
