Repair royal cozyfire c603r
No light display controls other than red light not working
2 Suggested Answers
  • 2460 Answers
SOURCE: I need instructions on where to place coals on a
Hi google royal cozy fires you can down load a manual
Posted on Feb 16, 2010
1992 oldsmobile 88 royale. Two issues here that I haven't been able to nail down. The first is my heater only comes out of the defrost vents and floor vents, but I have checked all of the vacuum lines...
Check to make sure your idle air control valve is working and the passage thru the throttle body is clear. Instructions for testing are at the link below. Repair Guides Electronic Engine Controls Idle Air Control Valve AutoZone... if the iac is good, you might want to test the map sensor.
For the vents, are you saying all of the vacuum actuators are working? The mode switch simply transfers vacuum to the different door actuators. If all doors are working, the problem must be the control valve in the panel. Autozone.com also has the procedure for removing the panel at
Repair Guides Heating And Air Conditioning Control Cables AutoZone com
Jul 16, 2017 | Cars & Trucks
Royal 9500ml screen is blank
It sounds like you have a faulty LCD display unit. get it checked. It is almost certainly nothing to do with memory. It would be best to get your products backed up before the repair is attempted.
If anyone needs more information, the Royal 9500ML manual is here:
http://the-checkout-tech.com/manuals/TOC/cashregisters/Royal/Alpha-9500ML%20user.TOC.pdf
Aug 10, 2012 | Sharp Royal Alpha 9500ML Cash Management...
The red & yellow light light stay on motor doent turn on when I feed paper I took it apart & clean it still not working
If you've already cleaned the "eyes" you may have a bad PCB...give Royal a call at 1-800-524-0799 they should be able to help with parts.
Aug 11, 2010 | Royal VF1012mx Shredder
A Royal crosscut shredder that usually only runs in reverse
in the middle of the paper enterance clean sensor
May 22, 2010 | Royal CIA 12X Shredder
The red power light comes on but the digital display doesn't always come on
The red power light indicates that your main power is getting to your iron and the digital display not working indicates that you have a problem with your iron electronics control circuit: if still under warranty, return it to be fixed otherwise consider buying a new iron as the repair cost in general can be quite high for 'electronic' iron (unless you have a handyman available!).
Hope it helps.
Feb 21, 2010 | Black & Decker Irons
Position of coals on a gas fire
Hi crosslee are on google they have a e-mail help line they should be able to send a pic of how the coals should go ,
Sep 30, 2008 | Honeywell Programmable Thermostat Heater
Wiring toggle switch royal 9512x
Did you get wiring diagram for Orca 9512X shereder swithc.
Wiring is as follows.
Looking down on switch from the back with the forward facing the feed. and control on top
Top left has two yellow wires one to bottom right of switch other to control box/board
Top right has orange going into control box/board
middle left has black going to motor
middle right has red going to motor
bottom left has smaller red going to control box/boafd
bottom right has yellow from top left.
Hope this helps. I'm still trying to find a manual for mine.
Jun 10, 2008 | Office Equipment & Supplies
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
