Question about Sound Logic Bluetooth I-tower Speaker
Dmtech problems Hi my ipad connects to the speaker easily enough but the sound is "jumping" like an old vinyl record player.
All my records sound really modulated skipping the pitch on longer notes and higher end vocals. It is pretty much brand new, any ideas pleaseeee????
I suggest you begin by ensuring the turntable and tonearm are as near perfect as you can. The reproduction of sound from vinyl depends first and foremost on the operation of the mechanical components.
The correct stylus fitted correctly with the weight of the tonearm adjusted to the recommended value for the cartridge. There should be no friction vertically or laterally in the arm travel, though some high quality types are fitted with hydraulic dampers.
It is also essential the turntable runs smoothly at a consistent speed. Vinyl purists have all sorts of ways of checking the turntable speed is correct. Most turntables have rubber belts or wheels in the drive from the motor and a defect can ruin the quality of the reproduction.
Owning a turntable for vinyl reproduction is a suitable hobby for a keen amateur mechanic...
Once you are satisfied the mechanical components are in good order and functioning correctly there is only the electronics to consider.
There are two approaches. One involves putting a known good signal into the input of your record player amplifier and the other involves using the output from your turntable into a known good amplifier and speaker system.
These steps involve opening up the case of your record player and making and unmaking various connections.
Mar 05, 2016 | Crosley CR49 Traveler Portable Turntable...
How to transfer vinyl to cd-simply-I have manual but very confusing-simple step by step needed-thank you-Al B
The popular recording software known as Audacity is a good choice for getting all sorts of sounds saved in a digital format. The easy-to-use features of this program will help you to create complex musical compositions, or just record incoming audio streams. One of the basic things you can do with Audacity is to record sound from vinyl records. Many people still keep vinyls on hand, though the production of this medium has diminished. Here are the basic steps that will help you to use Audacity to record vinyl.
Steps
  1. Get your phonograph or record player. Assemble your collection of records and make sure that your record player is in good functioning condition.
  2. Use a cable to connect your record player to the computer with Audacity installed on it. In order to record from vinyl, you'll need to make sure you have accurately connected your record player as an incoming audio stream into the microphone jack of your computer.
    • Use hardware adapters to secure your cable connection. Many older record players utilize a 1/4-sized input jack. The modern laptop computer, as well as many desktop models, use a smaller, 1/8-sized input jack. You can buy simple adapters at your local electronics store to fix this problem.
    • Make sure that your cables and adapters support stereo.
  3. Open the Audacity program on your computer. You will see the signature Audacity screen, with controls at the top, and an empty space to accommodate created tracks.
  4. Start playing the record on your record player.
  5. Hit the red circle that represents the "record" button in Audacity.
  6. Observe the sound coming into Audacity. You should see the track being populated with sound, represented by a fluctuating line as the cursor moves along.
  7. Hit "Stop" to stop the recording.
  8. Stop the record player.
  9. Repeat this process with the entire track. Reset the record player, start playing and hit the Audacity "Record" button again, allowing the entire track to populate with the sound of the vinyl record.
  10. Save your project in your desired format. Audacity supports a number of file formats for the finished product. You can select one of these when you have recorded the entire track. Make every song its own track, or simply record the entire side of the record on one track.
Aug 26, 2015 | Audio Players & Recorders
I can't get loud sound when attached to my speakers. I comes in very low and can hardly hear it. What can I do?
What kind of speakers are you connecting to and how are you connecting? My understanding with this product is that it was designed to connect to USB on computer. If it has RCA (red and white connectors) on it, those are likely line level outputs that will not be strong enough to be run directly to speakers, it would need to go into some type of amplifier.
Aug 09, 2015 | ION Usb Turntable Convert Vinyl Records To...
Why can I not record to a CD from the "aux in" port?
Your question has not provided enough information. Are you trying to record vinyl onto a cd?
You cannot record onto a normal cd player. You need a cd burner(/recorder).
Vinyl turntables have a quieter output signal too so unless you have a device that has a phono (vinyl) input you will not be able to record your vinyl. If you have a laptop then the easiest way to record vinyl onto cd is to buy a soundcard that has phono input. You can then use free software (programme) like audacity to record your vinyl and covert it to a format (wav aiff or mp3) to burn to cd using iTunes or Windows Media player.
Sep 27, 2014 | Audio Players & Recorders
Needle jumps on all new vinyl, but plays old records fine. New vinyl plays on other turntables without a problem. Do you have any suggestions?
Adjust the balance force up. This is a counterweight on the back of the arm. For most needles it is 1-2 grams.
Jul 06, 2014 | Crosley Audio Players & Recorders
Sony DAV-DZ560 Can I use a record deck and put it through the surround sound to play vinyl's
Shouldn't be a problem as long as you get a record player with a built-in preamp. Old record players did not have a preamp, and will not output a signal at a high enough level to be used through the sony system.
Jan 10, 2013 | Audio Players & Recorders
Connect an active soundbar to a receiver
What if the soundbar is Bluetooth? Will I still be able to use that function and connect the active soundbar to the tv (Bluetooth) and connect the av receiver for other surround sound speakers? (they are pre-wired in the walls in the apartment I moved into)
Jan 08, 2013 | Audio Players & Recorders
Only one speaker works
Check the connections at the rear of the pickup. They tend to work loose over time
Sep 30, 2012 | ION Audio Vinyl Recording Turntable
Philips Gramophone record player repair
which model you have? 242? Philips truntables can be easily repaired only if you know where to take them for repairs. I am also living in bangalore.. and I am a vinyl, retro turntable collecter. just send me you phone # at redlag@gmail.com. I will be glad to guide you on this... cheers
May 15, 2008 | Audio Players & Recorders
Connecting speakers to amp
Your Amp will be having a pair of Phono / AUX input sockets at the rear. Connect the two Red and White cabbles from the Turntable to these sockets. I am unaware of what are Pilot Speakers. regular speakers have a dual colored pair of cables coming from them. they have to be connected to the speakers Connectors at the rear of the Amp. Play a Vinyl Record, select Phono on your AMP, and enjoy your music.
Sep 15, 2007 | Audio Players & Recorders
Sound Logic Bluetooth I-tower Speaker Logo
24 people viewed this question
Top Sound Logic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sound Logic Audio Player and Recorder Expert? Answer questions, earn points and help others
