Question about HP Compaq nx6110 Notebook
Problem with monitor
Hi! I'm having a problem with my HP Compaq nx6110 laptop. The problem started 4 days ago. When i plug in the power cable, my screen becomes very dull making me strain my eyes in order to see whats  on the screen. And when i remove the power, it becomes bright (normal) which is the opposite of what should occur. I am wondering what the problem could be. I have never experienced this before. I cannot use it for long without plugging in power because the battery becomes depleted & it goes off.
This morning when i switched it on, it gave me the following message;
"Non-system disk or disk error replace and strike any key when ready"
I was surprised as there was no disks in it. So i had to restart it but this time it did not show this message, it started normally.
Is this the end of my laptop? I'm really worried. This is a struggle for sure. Please help me out on this. Thanks in advance. Your efforts will be highly appreciated.
Yours truly,
Gabzie.
email: hassan_gabzie@hotmail.com
  • Gabzie Oct 17, 2007
    Thanks for all your efforts. I ado appreciate. Though now the problem is; how do i adjust the brightness  when you plug in the power supply as you state the problem might be? I don't anything about this. Can you please direct me on what to do in order for me to solve this problem? I am totally messed up with this. Thanks for the help so far.
  • ol98ter Jun 19, 2008
    I have a problem with my HP Compaq nx6110 PC Notebook. Whenever I plug in the power cord the screen becomes dull. hen I remove it it becomes back to normal. I tried changing the power supply cord but it appears to be the same. I'm afraid it might crash sooner. I need some assistance in solving this problem.
Thanks a lot. This works. I do not know how to thank you enough. I appreciate from deep down. Thgought my laptop was about to crush. Get blessed. Cheers!
Posted on Oct 20, 2007
    Problem Solver:
  • 6 Answers
Hi Gabzie,
Don't worry regarding that the issue regarding the display could be probably you try changing the brightness when you  are plugged with  you power  supply and regarding the non system disk error may at that point of time the system has taken both the hard disk and dvd drive as master that is the reason you have got this message if this repeats then please provide me the serial no. and product no of the notebook and where do you live so that i'll guide you.
Posted on Oct 17, 2007
  • Venkata Naveen A
    Venkata Naveen A Oct 20, 2007
    Hi Gabzie,
    Just press Fn+F8 to increase your brightness and Fn+F7 to decrease the brightness....
    Hope this will help you.......
I have hp compaq 6910p laptop, which worked at its best for several weeks after it was bought. but few days back it started freezing, taking too much time in startup and to run programs aswel. I was t
Instructions
Plug one end of the VGA connection cable into the VGA port on the external display. Tighten the knobs on the VGA connector to secure the cable to the monitor.
Plug the other end of the VGA connection cable into the VGA port on the on your Compaq 6910P. The VGA port is located on the back of the device. Tighten the knobs on the VGA connector to secure the cable to the laptop.
Plug the external display's power cord into a wall outlet. Power on the device by clicking its "Power" button.
Boot your Compaq 6910P.
5
Click on the "Start" button in your task menu.
6
Select "Control Panel," then click "Appearance and Personalization."
7
Click "Personalization" in the window that appears.
8
Select "Display Settings."
9
Select "Mirrored" from the New Display Detected dialog box to have your displays mirror each other.
10
Select "Extended" from the New Display Detected dialog box to have your display function like one, large workspace.
11
Select "External Display Only" from the New Display Detected dialog box to use only your external monitor.
12
Click the "OK" button to keep the changes and exit the setup.
Jan 10, 2013 | HP Compaq 6910p Notebook PC PC Notebook
Compaq nx6110 laptop hangs after 30 minutes, please help
It should caused by a power supply too weak or not stable problem.HP Compaq nx6110 PC always happen to this problem.
Feb 10, 2011 | HP Compaq nx6110 PC Laptop
I have HP compaq nx6110 laptop with fogoten BIOS password what should i do?
You will need to:
  1. Turn off the laptop.
  2. Remove the battery.
    Remove the two screws that secure the keyboard.
  3. Remove the keyboard.
  4. Remove the battery "RTC".
  5. Leave it in this state for 15 minutes.
    Then connect only the main power cable WITHOUT the battery installed.
  6. Power on the laptop, and the RESET is done.
    Power off the laptop.
  7. Reconnect the “RTC”.
  8. Re install the keyboard.
  9. Re install the battery.
  10. Make sure there are no spare screws.
  11. Power up the laptop and continue to use.
Sep 09, 2009 | HP Compaq nx6110 PC Laptop
Compaq nx6110 problem
check your laptop by another charger, so u can find the exact problem, sometime charger problem may also occur.
Note: change your charger
regards
ehsanullah
Jun 17, 2009 | HP Compaq nx6110 Notebook
I want to download hp compaq nx6110 drivers
Click here to download your drivers.
Just select your operating system and download the drivers.
Do not forget to rate !
Thankx
Mar 04, 2009 | HP Compaq nx6110 PC Laptop
My laptop, hp compaq nx6110 has a screen problem. Its dim
OS?
Check the "Power Options" in your "Control Panel" (classic view). For whatever option you have picked, click "Change plan settings". There you can either "Restore default settings", or manually "Change advanced settings". If you choose "advanced settings", look for "Display" / "Display brightness".
Feb 26, 2009 | HP Compaq nx6110 PC Laptop
My compaq nx6110 screen goes black and on, why?
This is the issue with the monitor.This is a hardware issue.Please connect the notebook to external monitor and check .If it is working fine then it is the issue with the LCD of notebook If not then this is the issue with the video card.
And ckeck the power cables tooi think this is the issue with the monitor of the notebookAny how you can try to install the latest version of video drivers
Jan 08, 2009 | HP Compaq nx6110 PC Laptop
Compaq nx6110
Usually one of the function buttons F5-F8 etc together with the FN button will toggle through from lcd to tv/external monitor to both.
Is the cable S-Video or does your tv accept a dvi or vga input?
Do you connect using the s-video output on the laptop or the standard external monitor port?
Mar 21, 2008 | HP Compaq nx6110 PC Laptop
HP Compaq nx6110 Notebook Logo
199 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
