Question about Fusion CP-AS1080 8" Ultra Slim Active Subwoofer
Fusion wiring diagram
Require wiring diagram for CP-AS1080 8" Super Slim Active Subwoofer
I have a pioneer dxt-x4869bt sterio do I need a certain hook up subwoofers
Unless your Pioneer has a dedicated subwoofer output or output for bass speakers the signal for subwoofers will need to be generated by either a passive or an active crossover from the regular speaker outputs and then the resulting output will probably need boosting by an additional amplifier if a passive subwoofer is to be used. An active subwoofer might not require the additional amplification.
Feb 14, 2016 | Pioneer Car Audio & Video
Amp wont play
Quick test...with your Lanzar volume all the way down, connect MP3 player or other type audio source directly to the subwoofer input connection. Play audio and slowly increase volume control. If subwoofer is working using this method, reconnect and check for audio output to Lanzer connection problem, or subwoofer "settings" issues with the receiver.
Nov 11, 2013 | Lanzar VCTBS8 Vector 8-Inch Super-Slim...
Need wiring diagram for bass w x 10
You have not mentioned what equipment you would like to connect to this active subwoofer.
Assuming you have an AV Receiver, you will require a single long RCA to RCA subwoofer cable. Connect the left input (white socket ) of the subwoofer to the AV Receiver subwoofer pre output.
Leave the front crossover knob at 100Hz , Phase at 0. While playing an audio track slowly increase the subwoofer front volume to suit your taste. If you are using big floor standing speakers along with the subwoofer reduce the crossover frequency to 70Hz. Phase should be adjusted to blend the front speakers with the sub.bobhifi_6.jpg
Mar 09, 2011 | SpeakerCraft BassX-10 Subwoofer
Need a weiring diagram
go to the manufactures website or go to a best buy or jo dies they can help
Jan 08, 2010 | Fusion FEW12PK Car Subwoofer
I need a wiring diagram for sony xplod active subwoofer XS-AW200X
Hello ml3ray, you might want to check the following link i actually dont have the wiring diagram for that specific subwoofer if there is any technical support you may need just email me at usmclex@hotmail.com or write back at my fixya profile.
http://audio.manualsonline.com/manuals/mfg/sony/xsaw200x.html
Oct 18, 2009 | Sony Car Audio & Video
Driver suitable for CP-HR7X Slim Scanner to work in Windows 7
I can not find driver suitable for scanner CP-HR7X to work in Windows 7 too. I am from Russia.
May 27, 2009 | Genius ColorPage HR7X Slim Flatbed Scanner
Have no wires for a Fusion EN-AT110 Basstube!!!
The best place is to go to any store like halfords or maplin, or a lot cheaper if you wanna wait is ebay, many fusion amps/ active subs need special wiring !!!£80 from them direct only way, or you can go to maplin and get this product: A21GF (power supply extender 24pin) then cut off the three columns you need and the top and bottom of each are the respective 12v positive input remote and earth, cut the wires off half way and twist the top and bottom together, then add the twisted wires to your normal sub cables. make sure you use insulation tape around the naked wires for quality and stop it short curciting
Dec 09, 2008 | Fusion FEW12PK Car Subwoofer
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    Fusion CP-AS1080 8" Ultra Slim Active Subwoofer Logo
    180 people viewed this question
    Top Fusion Car Audio & Video Experts
    Brandon Berry
    Brandon Berry
    Matthew Spark
    Matthew Spark
    Tygh Duval
    Tygh Duval
    Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
