Question about Sansui HDLCD3210 32 in. LCD TV
Witch button on my remote controle is the scan button
I cannot find the scan button on my remote to scan in a channel that works with my video machine.
    Top Expert:
  • Sansui Master
  • 74,198 Answers
Try this link, and downlaod the user manual to your TV. It has all details. http://tv.manualsonline.com/manuals/mfg/sansui_electric/sansui_electric_flat_panel_television_product_list.html
Posted on Dec 25, 2013
Directions for remote control for model#WD40fb2530 what are the buttons for?
You have to do a channel scan to store active channels in your area, then you can press channel up or down to step through them.
Jan 10, 2017 | Televison & Video
How to get channel 4
You have to go back to the setup screen and scan for channels. Then you need to have a signal present for channel 4 so that the scan finds that channel. Note that if it is a unit that is not digital then it wont find channel 4 for broadcast. If it is digital and you are hooking something to it like a video player then it wont see channel 4 if the player is not digital.
Dec 08, 2014 | Sharp 13" Tv Model No. 13n-m100b
Why is my remote control not working despite changing the batteries.
Not sure if this will help but, I recently put an antenna on the roof of my house. I don't watch TV much but wanted to enjoy some TV, but my remote locked up and the side buttons on the TV wouldn't work either. I tried changing the battery, but no luck. There's a broadcast station 64.2 that is locking up TV's & remotes. Here's the fix that a TV repair co. gave me which did break the lock of the station 64.2.
1) unplug antenna (not roof but connection from TV to wall)
2) unplug and plug back in TV
3) find a way via remote or side buttons to scan channels
4) Go to Menu
5) EZ Setup
6) Channel Set Up-Scan Channels
7) Channel Memory
8) Digital Set Up
9) Turn Skip On for 64.2 (Delete this Channel)
10) Turn off TB
11) Hook Antenna back
You may have to play with the order to acheive the end result or figure out a way to delete 64.2, but during the process you will at least unlock from being stuck on 64.2.
Good Luck if this was the same issue!
Jul 14, 2014 | Audio Players & Recorders
Buttens on remote controle
Use the input select button; usually marked as AV/TV.
Dec 25, 2013 | Sansui HDLCD3210 32 in. LCD TV
The control of My dishnetwork sat remote control does not work with my Viore LCD TV Model EL 404.The current list supply with the remote control of dish network show some numbers but any work with my TV....
Hello, my name is Cheri Torres and I am with DISH Networkcustomer service. I came across your post and wanted to see if I could helpwith a solution. Sometimes some of the codes we have available for certainbrands of televisions are not compatible with certain models of that brand. Ifnone of the codes are working when trying to address your DISH remote to yourTV, we do have an option to run what we call a channel scan. A channel scanwill basically scan through all possible remote codes, until if finds thecorrect one for your specific TV. I hope you find these instructions for achannel scan useful and please feel free to post back here with any furtherquestions or concerns. You can also email me at Cheri.Torres@Dishnetwork.com.
Instructions for running a channel scan
  1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.(For your case press and hold down the TV mode button), then press (500) in the number keypad, then the pound(#) button once and release. You should see the TV button flash three times.
  2. Once you have completed the first step you will again press and hold the TV mode button until all the mode button light up at the top of the remote.
  3. Press the big red power button on the remote once and release.
  4. Press the Up button once every second while pointing the remote at the desired equipment.(press the up arrow as if you were changing the channels up). Keep doing this until your TV powers off.
    Note: If the code for the equipment comes up, the equipment will power off.
  5. As soon as your TV powers off, Press the POUND (#) button right away. If the code entered is valid for the remote, the mode light flashes three times.
Nov 24, 2010 | DISH Network IR Remote Control
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
My remote is nt working for channels
before you try to change the channels, firts look for a button that says tv/video `press it ( some times more than once ) depending on how manny video jacks on your tv until it shows tv again, good luck
Dec 18, 2009 | Televison & Video
Channel button on tv and remote control dosent work
The channel buttons on the tv and remote only navigate through the channels programed into the tv. You will need to go into set up and scan for channels or manually add channels you wish to receive.
clarkco
Mar 07, 2009 | Vizio GV42L 42 in. LCD Television
Sansui HDLCD3210 32 in. LCD TV Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
