Question about Carrier Heating & Cooling
Have a Carrier Window AC (1.5ton), Model: ''Optima Plus D EQR''. Recently fitted it, but unable to wire up the front panel (with LED indication and IR sensor). The AC can be operated only when this front panel is connected. Require help to connect the colored wires to the rear of the front panel as no wiring diagram is available in the manual. Wiring diagram or place from where i can get one is required. Thanks.
Carrier 1.5 tr outdoor unit wiring connection please.
Posted on Jul 21, 2009
Remote sensor on the tv is not working.Have seen solutions on line that say put headphone jack into the "remote input" or "wired input" port.The 47LS4500 does not have this port. What is the solution?
use a phone camera and look at the front emitter LED the camera will show the invisible output as white light, if you indeed have output showing you can be reasonably sure the remote is working, here is a link for IR sensors on the plus side they all plug into the set with no soldering and just one screw.
IR Sensor Boards MBTV Electronics
Nov 29, 2015 | LG 47LS4500
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Need emachines t3306 motherboard connection diagram
The eMachines T3306 desktop computer, uses the FIC K8M-800M motherboard.
First International Computer, (Inc)
http://www.fic.com.tw/product/motherboard/amd/ficimages/k8m-800m.jpg
http://www.fic.com.tw/product/motherboard/amd/k8m-800m.aspx
Here's the download page for the motherboard manual,
http://www.elhvb.com/mboards/OEM/eMachines/manuals/index.html
Column in middle, 3rd file from bottom.
This is a Zip file. A Zip file is a Compressed file. Used to send large amount of information more easily.
Has to be decompressed, or 'unzipped'.
After you click on the blue -> FIC K8M-800M file name, a small window will come up-
Opening K8M-800M_manual.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
IF not; click in the empty circle to the left of Save File.
No go below in the small window, and click on OK.
A small download window will come up.
Allow the file to fully download all the way, then DOUBLE-click right on the file name.
(Yellow folder icon with a zipper on it. K8M-800M_manual.zip is to the right)
In the next small window go to the far Left, and click on -
Extract all files.
At the bottom of the next 3 small windows click on Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name ->
K8M-800M_manual
(Next to the red Adobe PDF icon)
There is your motherboard manual in PDF file form.
For an example;
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
Motherboard installed in computer case, the Front Panel header is at the Bottom/Right.
The Front Panel header is Orange in color. (Page 20)
Two rows of contact pins.
5 pins across the Top row.
4 pins across the Bottom row.
The Top row is numbered ODD.
The Bottom row is numbered EVEN.
Starting on the RIGHT side going across to the Left; Top row,
Pins 1, 3, 5, 7, and 9.
Starting on the RIGHT side going across to the Left; Bottom row,
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected.
Reserved for factory use. Probably a 5 Volt test point.
D) Pins 2 and 4 are for a Power On LED light.
These two pins are used for a Single color, Power On LED light.
Two wire LED light.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
There is ALSO a jumper used for this LED light. More on it at the end.
E) Pins 6 and 8 are for a Power On switch.
To the Right of the Orange Front Panel header, (F_PNL), is the PW_LED header.
[Page 20 to right of Front Panel header. -> PW_LED
(Power LED, 2/3 Pins) ]
3-pin Black header. Sits Vertically.
(The Orange - Front Panel header, sits Horizontally)
This is used for a 3-wire Power On LED light.
Used for a Dual Color - Power On LED light.
One example is if the computer has Turbo Mode, and Normal Mode.
Green color usually for the Turbo Mode, Yellow color of the LED for the Normal Mode.
Starting from the BOTTOM going UP;
Pins 1, 2, and 3. (3 at the Top)
A) Pin 1 is for the Positive ( + ) wire. [Signal]
B) Pins 2 and 3 are for the Ground wires.
Jumper block for the 2-wire Power On LED light, and 3-wire Power On LED light; Page 13 - Set System Jumpers
(Actually it starts on Page 12)
6-pin header to right, of 3-wire Power On LED header.
Has Blue jumper caps on it. Two of them.
(PL_LED1)
http://www.ebay.com/itm/NEW-FIC-uATX-Skt-754-AMD-Desktop-Motherboard-VIA-K8M800-AGP-4x-8x-DDR400-800FSB-/280923928691?pt=Motherboards&hash=item41685ef873
Two rows of 3 pins.
The bottom row is numbered EVEN.
Starting on the RIGHT side going towards the Left; Top row,
Pins 1, 3, and 5.
Starting on the RIGHT side going towards the Left; Bottom row,
Pins 2, 4, and 6.
A) With the jumper caps on Pins 3 and 5; plus 4 and 6; the Power On LED light works as a Single color LED.
B) With the jumper caps on Pins 1 and 3; plus 2 and 4; the Power On LED light works as a Dual color LED.
For additional questions please post in a Comment
Regards,
joecoolvette
Mar 07, 2013 | Computers & Internet
I need help with hooking up the front panel wires from a acer veriton 460 on to a asus p5g41t-m lx plus mother board
I don't think it's gonna' fit.
Acer Veriton L460 computer Case Dimension specifications,
http://support.acer.com/acerpanam/desktop/0000/Acer/VeritonL460/VeritonL460sp2.shtml
Chassis: 2.5 inches Wide (63.55mm) x 10 inches Long (254mm) x 8 inches High (203.2mm).
Asus P5G41T-M LX motherboard is 9.6 inches LONG, (244mm), and 7.9 inches High (201mm).
http://www.asus.com/Motherboards/Intel_Socket_775/P5G41TM_LX/#specifications
However,...........
If you do not know what the Power On switch, Power On LED light, and Harddrive activity LED light wires are, then remove the Front Panel, and trace them back.
(Side Panel then Front)
Click on the Download tab.
(Overview / Specifications / Download / etc)
http://www.asus.com/Motherboards/Intel_Socket_775/P5G41TM_LX/#download
Click on any O/S. They will all get you to the Manual download.
Click on the + sign to the left of Manual (12)
Scroll the inside blue bar down until you come to -
Version E7096 -
P5G41T-M LX User's Manual (English)
Click on the blue - Global
A small window will come up on the right -
Opening E7096_P5G41T-M_LX.zip
[This is a Zip file. A Zip file is used to send large amounts of information, more easily. A Zip file is a Compressed file. It needs to be uncompressed after downloading, or can be stated as 'unzipped'.
If WinZip is no good on your computer, then just download the free 7-Zip ]
Make sure there is a Green dot in the small circle, to the left of Save File.
If there is no Green dot; left-click in the small empty circle to the left, of Save File.
Now go below in the small window, and click on OK.
A small window will come up on the left.
Allow the file to fully download in this window.
Then DOUBLE-click right on the file name.
On the left side in the next window, click on - Extract all files.
At the bottom of the next three small windows, click on -
In the last small window DOUBLE-click on the file name -
E7096_P5G41T-M LX, next to the red Adobe PDF icon.
Page 1-6 (16 of 62) shows the Motherboard Layout.
The area of contact pins on the motherboard, that the main wires from the Front panel connect to, is the Front Panel header.
Motherboard installed in computer case; Processor to Top, Ram Memory slots to the Right, white PCI slots to the Bottom;
the Front Panel header is below the bottom white PCI slot, and next to the bottom edge of the motherboard.
F_PANEL
4 pins across the Top row, (Then no pin)
5 pins across the Bottom row.
1.10.2 Internal Connector section - Page 1-26 (36 of 62)
8. System panel connector (10-1 pin PANEL)
Pins aren't numbered, I'm going to number them;
Pins across the Top row are numbered EVEN.
Pins across the Bottom row are numbered ODD.
Starting on the LEFT side going towards the Right; Top row,
Pins 2, 4, 6, and 8. There is NO Pin 10.
Starting on the Left side going towards the Right; Bottom row,
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
If the HDD LED is dim when the harddrive is active, switch the wires around.
C) Pin 9 is N/C. Not Connected. 5 Volt power reserved for the factory.
D) Pins 2 and 4 are for the Power On LED. (Light)
E) Pins 6 and 8 are for the Power On switch.
F) There is NO Pin 10. Just a flat spot.
The small 4-pin header immediately to the LEFT, is for an internal speaker. Used to hear BIOS Beep Codes. The computer's way of telling you something is wrong, and an area to look into for it.
The Front Panel USB header is listed, and Firewire ports. (1394a)
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 14, 2012 | Acer Power S290 PC Desktop
My carrier AC(model: Optima D plus) is displaying a error "E3". Can someone suggest a solution to it.
An E3 error on your thermostat (T-Stat) has the following description from your manual:
"Brownout condition or too low of voltage to thermostat. Double check wiring and check for
24 vac between R and C. E2 will clear 15 sec after proper voltage is restored."
If you are unsure how to check the low voltage to your t-stat, then please call a professional in your area to check the t-stat wiring and the transformer in your furnace.
Jun 13, 2011 | Heating & Cooling
Nead to know where the IR Receiver is on the tv.
hi.
You can see the IR receiver near the standby led. normally Ir receiver and standby led are fitted on the same board. And the same board will be fitted on the frond panel of the tv. Have added a picture for your reference.
ok
Jun 09, 2011 | LG RU-52SZ51D 52" Rear Projection...
How do i wire-up the: ( eg. power l.e.d., HD led, reset led ect. to the board
The various wires from the case front panel should be labeled to indicate power LED, HD LED, etc.
The motherboard front panel jumper pins should be grouped together and the pins should be labeled to indicate PWR, HD. RST etc.
You can go to the motherboard manufacture's WEB site to download a diagram of your model motherboard and it will show all the locations of the connecting pins.
Jan 30, 2011 | Chaintech MP4M266A Motherboard
My window will not go up and AC doesn't have airflow.
check the wiring for the ac, then check your battery,, this problem can be solved by charging the battery,, or by replacing, if the wiring is,, good, only the battery must be the problem.,
Jun 29, 2009 | 2004 Kia Optima
Heating & Cooling Logo
1,019 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
