Question about DeLonghi Coffee Makers & Espresso Machines
En110.0 capsule cover locked
And three blinking lights
  • Barbara Urquhart
    Barbara Urquhart Dec 25, 2013
    Hi Barbara Urquhart, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Posted on Dec 29, 2013
Why does led flash blue then red constantly
Hello there,
From this download here
http://store.x-mini.com/upload/manuals/120416%20X-mini%20KAI%20Manual%20%28Eng%29.pdf
LED Battery Indicator
When charging:
Red - X-mini KAI Capsule Speaker is charging
Blue - X-mini KAI Capsule Speaker is fully charged
When in use:
Blue - X-mini KAI Capsule Speaker is turned on
Blue (dim) - X-mini KAI Capsule Speaker battery low
During playback through bluetooth, users will be alerted if
charging is required by a three-beep indication
If this is not right you will have to email them on support@xm-i.com
or if is in Warranty, get it repaired by the Seller.
Sep 16, 2014 | X-Mini KAI XAM11-B Bluetooth Capsule...
Why does red light keeps flashing on dolce gusto mini me ?
In my case it was a minor detail: The capsule holder tray has a small magnet on the top right side, you can feel a light pull when you are inserting it in the machine. This magnet became dislodged from the capsule holder, and the machine won't operate and will give you a continuous blinking red light if the magnet is not in place; I found it when emptying a small bin where I put the used capsules. You just have to put it back in place with two drops of glue, or if you can't find it, just order a new capsule holder.
The picture shows the underside of the capsule holder and the magnet next to the slot it came from.
Sep 02, 2014 | De'Longhi EDG200T Nescafe Dolce Gusto...
No manual Bellini Coffee maker
En110.0 capsule door will not open and there are three blinking lights. No coffee:(
Dec 25, 2013 | Coffee Makers & Espresso Machines
XMI X-Mini Ii Capsule Speaker won't charge
The rechargeable battery may be exhausted and probably needs to be replaced. Try www.ebay.com type make and model of Capsule Speaker and scroll through the list. The only other option is try the manufacture, contact customer support and the technical department.
Jun 01, 2012 | KB Covers Xam4-r X-mini Ii Capsule Speaker...
Error U163
I can then help you with your specific problem.
Error Code U163 (Ink Cartridge Empty or Low)
First of all, Yes, this is a common problem.
When you open your printer up, by lifting the Scan Cover, you will see lights blinking for the cartridge that is low or is empty.
1.) A lamp blinking once every three seconds means your cartridge is low.
2.) A lamp blinking once every second means your cartridge is empty.
Using your printer with an empty ink cartridge is capable of harming your printer, according to Canon Engineers.
Until such time as you can replace the cartridge you can use the method described below to temporarily turn off the error message.
Press and Hold the Stop/Reset button for 6 full seconds and then release it? Use the one Mississippi method of counting.
The Scan cover must be closed completely and locked in place. And the ink cartridge must be firmly locked in place as well.
Feb 28, 2011 | Canon PIXMA MX310 All-In-One Printer
Tv light standby red just keeps blinking after replacing bulb
If red light was not blinking before lamp replacement and after that it start blinking 3 times then pause for three seconds and again blink, check lamp cover that has not been fixed on tv or it is not fixed/ seated correctly there.
Lamp cover is first thing that you removed from tv to replace lamp.
Hope these info will help. If red light is blinking other than 3 times, let me know how many times it is blinking along with tv model number written at rear to provide you helpful info.
Thanks.
Jan 27, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Replaced projection lamp and also cleaned out most of the dust inside the tv. will power on but shuts off before picture comes on tgen three red light blinks. please help asap. thank you.
Three red light blinks shows that lamp cover is not properly closed after lamp replacement. Make sure that the lamp cover is in its proper position. Try to reset the lamp cover and turn it on clockwise direction until you heard a click sound of a micro switch activated by the lamp cover, then put the set on..
Oct 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blinking orange light on model D290 and it is not full of capsules
I solved this problem by realizing that I had forgotten to insert back a certain piece of plastic, that I had taken out to clean. this caused the blinking light
Jan 04, 2010 | Nespresso Coffee Makers & Espresso...
The capsule lock system does not make holes in the capsule
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
Oct 09, 2009 | Nespresso Le Cube
I have a Sony kdf50we655 and replaced the burned out lamp. When I turned on the unit the light turned green and the fan starts up briefly and than everything turns off. The light turns red and blinks...
MAKE SURE YOU HAVE THE LAMP COVER ON CORRECT NOT TO TIGHT AND THAT BOTH SCREWS ARE SCREWED IN THE SAME AMOUNT TRY TO REPLACE THE COVER AND THE PANNEL AND TURN BACK ON
Mar 05, 2009 | Televison & Video
Coffee Makers & Espresso Machines Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
