Question about Saitek Pro Flight Multi Panel (PC) Flight Simulator
Stuck action the knob is stuck and will not turn!
Stuck Knob Solution here! Hello, I had the same problem and found the perfect solution online (for just $2.99): In order to fix this problem you just need a larger knob which provides the extra leverage needed to (effortlessly) turn the knob. The original knob should come off easily by wiggling and pulling at the same time. The knob is attached to a 1/4'' shaft so any lager knob that fits a 1/4'' shaft will do fine. I used one from radio shack (Model: 274-407), which was 1/4'' shaft and it also contained a micro screw that you can tighten to ensure a snug fit. This knob slightly covers the labels (ALT,VS IAS, etc) but because these values show up on the screen as you tune to them, it's no big deal for me. Btw, I attempted to contact Saitek for a solution and shocker! -No Response.
Posted on Jun 16, 2014
Knob stuck
if the knob is stuck remove it and spray the valve heavily with wd-40 while pressing the stem in and out and in and out and in and out and slightly wiggling to turn. If the inside is not broken this will remove the built-up dirt that does not allow the valve to turn. If this does not help then the inner lubricant has been over-heated and stuck in the ball-valve. it cannot be fixed, only replaced.
Nov 06, 2013 | Thane Q-BBQ Grill
Knobs stuck, won't turn on
turn the gas off. take the knob /s off get some wd40 spray them. then tap the tops with a hammer using a bit of wood. dont hit hard you just need to make it move a bit. if this dont work you will need new valves. remember dont hit them hard. just tap them.
Oct 29, 2013 | Bertazzoni Cooktops
Whirlpool Ultimate Care II LSB200KQ1 Top Load Washer - the washer filled and then stopped. No humming, no sound, no action when we turn the knob. Thoughts?
The limit switch that detects that the lid is closed is probably defective. You've already probably experienced how the agitator would stop if the lid was opened when the machine was working properly--same thing.
Jul 17, 2012 | Whirlpool Washing Machines
Inspiration 4205 stitch length won't change
Are you certain that the pattern selector is set for straight stitch and not buttonhole?
Turn the handwheel so that the needle is up and the take-up lever is in it's highest position. Then turn the pattern selector knob through all of the patterns back and forth a few times. Finally, select straight stitch and see if the length works. If not, need to take it to a repair person to determine the course of action.
Feb 21, 2010 | Singer Inspiration 4206
Water filter stuck on my Kenmore Fridge
I had the same problem. I coudn't get the knob to turn. I ended up taking the front grill off so I could get a better grip on the knob. Once I did that I still have to put a lot of pressure on the knob to turn it but that did the trick. When I got it turned a quarter turn then it was easy to pull the filter out. Hope this helps!
Jun 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Dishwasher knob is stuck
dont turn the knob counter clockwise it could damage timer try prying the knob off it could be shoved in to tight
Dec 13, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Saitek Pro Flight Multi Panel (PC) Flight Simulator Logo
97 people viewed this question
Top Saitek Video Game Consoles & Games Experts
 TE5LA
TE5LA
Rob Emerson
Rob Emerson
juanmireles1
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
