Question about Packard Bell iMedia Computers & Internet
Monitor vga connection hdmi
When i connect my vga to my monitor it says no signal but if i connect hdmi it works and i dont understand why
    Master:
  • Packard Bell Master
  • 788 Answers
You can check these:
1. Connection: Make sure that both ends are connected properly,
2. Monitor: Most newer monitor has 3 options: VGA or DVI or Automatic. Test the "Automatic" and "VGA" options.
3. Cycle your display option using your laptop keyboard (Alt + F4). Please tap the F4 several times (to change the option to Mirror, Laptop Display only, External Monitor only)
Posted on Dec 25, 2013
  • 4 Answers
SOURCE: No signal input when connecting PC to LG TV via HDMI
Do you also have a computer monitor attached to the computer when attempting to use the HDMI?
Posted on Mar 30, 2009
ehsan_bba
  • 112 Answers
SOURCE: No Display from new Acer Desktop AX1700
check all power cable. check vga cable,
Posted on Jan 26, 2009
Mastersage
  • 164 Answers
SOURCE: DVI no input signal......VGA input active.
Are you running an additional Video card? Or are you using the built in one.
You might try cleaning the connector / plugs with acetone from finger polish remover or de=natured alcohol.
Never jam anything on a computer.
If its an add on card, remove it and reboot. Shut down and reinstall card and reboot.
keep me posted please,
Posted on Feb 22, 2009
SOURCE: graphics card hdmi output to monitor digital input seems to not be working
i am having a problem with my sound and i need sound driver for dell dimension 2350
Posted on May 24, 2009
lothar96
  • 11 Answers
SOURCE: can't connect my emachine to 50" samsung plasmatv mod#pn50B530S2F
try going to "display properties" and adjusting the settings there. Right click on the desktop wallpaper and go to properties, then click on the settings tab. Make sure the TV setting is turned on
Posted on Mar 29, 2010
I am receiving a CABLE NOT CONNECTED error when I connect my vga monitor to my laptop using an VGA to HDMI cable
If you actually have a cable with HDMI on one end and VGA on the other, it will probably not work. HDMI uses a digital signal and VGA uses an Analog signal, there needs to be some circuitry somewhere that handles the conversion. You are probably getting Cable Not Connected because the monitor is scanning for an Analog signal and not recognising the digital signal coming in over the VGA port.
Get a HDMI to VGA converter
Jan 22, 2017 | Vga Computers & Internet
I connected up vga and HDMI cables and power, etc to ASUS desktop. All inputs are without signal. If I set monitor for vga, it says no vga signal. Same if set for HDMI input: no HDMI signal.
I would check your source for why it is not sending signal rather than why the monitor is not receiving. Of course, that being said, is this a new monitor or an old one that could be shot?
Dec 26, 2015 | ASUS Computers & Internet
How do I connect a laptop to this tv?
It will depend on the laptop's available external video ports. You can connect a VGA cable from some laptops to the VGA port on the TV. Then plug in a 3.5 mm audio cable from the headphone jack to the PC audio in port. (The audio connection is optional. You could continue using the laptop's speakers.)
Make the connections with the TV and the laptop off. You may need to enter the BIOS to enable the external video port. (It can be turned off to save power. The BIOS is accessed on boot by pressing a key (Esc, F1, Del) noted on the splash screen. For Win8 machines, you'll need to do a special restart.) Then turn on the TV before turning on the computer. The TV monitor should be automatically recognized for resolution and refresh rate. Next, if you have a Windows system, right click on the desktop (pick a spot with no icons or running programs). Click on Screen Resolution (or perhaps Graphics Properties, depending on the OS). Set the monitor to duplicate the screens or send data only to the TV screen.
I'm not sure if the HDMI ports will understand a computer signal. (Not all TVs can interpret the computer's HDMI signal; it is different than that of other set top boxes.) You can try the following connections.
If your laptop has a DVI output, use a DVI to HDMI cable (or adapter) to connect to the TV. Then connect the HDMI cable to HDMI 1 and use the PC audio connection as above.
For an HDMI output, use an HDMI cable. (You will still need the audio cable unless you can reset the audio signal to output on the HDMI port. Go to the Control Panel and then the Hardware and Sounds section. Under Sound, select Manage audio devices. Then in the Playback tab, make the HDMI audio the default.) For Display Port or Thunderbolt outputs on the laptop, you will need a DP to HDMI adapter.
If the HDMI port doesn't understand the computer signal, you'll need to use a converter to go from the computer's output to component video or to VGA. Then connect the converter's output to the appropriate port on the TV.
I hope this helps.
(To access the Control Panel in Windows 7 and earlier versions, click Start and then find the Control Panel in the right hand column. For Windows 8, press the Windows key + X (or access the Charms menu on the right-hand side (Win+C) and choose Settings). Then select the Control Panel.)
Oct 13, 2013 | Haier L42B1180 - 42 1080p LCD HDTV
What kind of wire do I need to connect my samsung laptop to panasonic viera hd 3d plasma tv?
Most TVs will have HDMI and RCA component and composite jacks. Some TVs will also have a VGA port. Your laptop will have a VGA port. (If the laptop is fairly new, it may also have an HDMI port.)
Not all TVs will support an HDMI signal from a computer, so the VGA signal is often better. However, that limits you to SD (anything with HDCP will fail.)
Very few TVs ship with the HDMI or component cables. However, there are some vendors who do package the HDMI cable with their TV. Without knowing which exact model of TV and laptop, I can only make a few suggestions. I know that the TCP42ST30 (Plasma 42") doesn't have a VGA port.
Look at your laptop for any external monitor port. VGA ports are generally blue female ports with 15 holes (D-Sub). If your TV has a matching VGA port, get a standard VGA monitor cable.
If you have the VGA port on the laptop but not on the TV, you can try a converting from VGA to HDMI. (You may need a DVI to VGA adapter and either a DVI to HDMI cable or a DVI to HDMI adapter.) Note: this gives an analog signal (RGB format) to the TV. You'll also need to make sure that your VGA port is active (in the BIOS for some computers) and then set your computer to send the signal to the external monitor. It is best to turn off both the computer and the TV before connecting the two. Then turn on the TV and set it to the correct input before turning on the computer. (In Windows 7, I set the video signal for the external monitor by right clicking on the desktop and selecting Graphics Properties. Set the signal to the external monitor and click Apply. Then click OK (in the external monitor's screen).)
If this doesn't work, you need a VGA to component video converter. (Not a VGA to component video cable - those are for projectors that read the RGB signal.) See http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html .
Some laptops come with an HDMI, mini-HDMI or a DisplayPort option. For the latter two, you will need the appropriate cable with that end and the HDMI connector on the other. Then connect the TV and the computer as described above. (Note: my TVs accept a computer signal at the HDMI port labeled HDMI/DVI. However, you need to make sure that your TV understands this signal. It isn't the same format as that from a set-top box. My laptop has VGA and HDMI out; the desktops have VGA, DVI and HDMI (on one).)
If you add a comment with the model of your TV and laptop, I'll be glad to give you more specific options to connect the TV and the computer.
I hope this helps.
(A DVI port is a digital video out option with ~21 pins and is usually white.)
Feb 03, 2012 | Panasonic VIERA Televison & Video
I have sapphire ati radeon 5570 graphics card. i have aoc 912sw+ 19 inch lcd monitor. how to connect hdmi port of graphics card with monitor?
the HDMI port is for connecting video and sound to a home theatre / surround sound system. I understand that this monitor only has a VGA connector.
The sapphire ati radeon 5570 graphics card has the following ports on the back to connect to a display: DVI (white), VGA (blue) and DisplayPort (the thin slot in the middle). You can use an ordinary VGA cable to connect the card to your monitor.
Unfortunately you cannot connect this card directly to your monitor using the DisplayPort.
Hope this helps
Tom
Jul 21, 2011 | AOC 912SW-4 Monitor
Hi there, i was just wondering that, my hdmi monitor which is goodmans GTVL19W17HD monitor and it has a HDMI slot, but my graphics card doesnt, instead my graphics card has a vga and dvi slot, and if i...
Hi hassy786,
Regarding your question if you will use a converter from VGA to HDMI will it provid High Defenition video?
I believe that it will provdie video converting the signal from VGA to an HDMI connection but I do not think that the video will be High Definition since the VGA is just being converted to HDMI signal and not an actual HDMI but just a converted signal, and it is possible that it may not work properly or the LCD TV may have difficulties recognizing the signal from VGA converted to HDMI.
Thanks for chosing Fixya,
avf110686
Mar 27, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
My DVI has no signal but my VGA does! what do i do? Please help me!!!
Your HP2009M monitor supports (3) methods of accepting signals from a computer. They are: 1) VGA, 2) DVI and, 3) HDMI.
You would connect the computer to the monitor using one connection only. Generally the VGA is the least desirable as it is an analog signal. The DVI and HDMI method provide digital paths into the monitor and often perform better. Your computer may only offer 1 or 2 connection choices, so you'll have to choose a cable type that is supported by both the computer and the monitor. The HDMI choice will pass audio signals to the the speakers in the monitor without needing to run a second cable between the stereo audio jack of the computer and the audio input jack of the monitor (located next to the HDMI jack) or to a set of external speakers (unless of course you prefer the external speakers).
The message you're seeing is normal. Once the monitor is connected to your computer, there will only be one active selection; VGA, DVI or HDMI. Since you're using the analog VGA jacks and cable, it is expected that you'll see a message that there is no signal present on the DVI (and HDMI) inputs when attempting to view signals on other inputs.
I hope this helps and good luck! Please rate my reply, thank you.
Feb 26, 2011 | HP 2009M Monitor
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
Computers & Internet Logo
62 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
