Question about Mercury Electronics Computers & Internet
Power but no display
No display direct power on
    Brigadier General:
  • Mercury Elec... Master
  • 3,400 Answers
1.CHECK WITH A OTHER MONITOR.
2.CHECK THE CABELS.
3.CHECK THE VIDEOCARD SHOULD SIT TIGHT AND FIRMLY,
Posted on Dec 26, 2013
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Display ic motherboard
A> Check you Power all connection proper connected.
B> Check you SMPS power proper working or not.
C> If direct display not coming then sec option is external display card connect in mother board and check display come or not. if display come then you internal display cheap damage. If both option used or display no then you mother board problem.
D> Check you RAM, section if RAM problem then display no.
E> And finally one time mother board bios batter disconnect and few sec wait and re-connect bios batter. Remember batter disconnect before all power cut.
Thanks...
Aug 26, 2013 | Dell OptiPlex Computers & Internet
No display but ram and processor is okey..
1.Confirm the Gateway notebook is not powered off or in standby mode. Tap the power button to turn on or wake the computer.
2.Check the screen brightness. Hold down the "Fn" key, then tap the up arrow on the directional pad to increase the brightness of your Gateway 400's display.
3.Toggle the notebook display. If you have an external monitor hooked up to the laptop, hold down "Fn." Press "F3" until the display switches to the laptop, or until both the laptop and the external monitor display an active screen.
Sep 22, 2011 | Gateway M360SE Laptop Charger...
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
NO DISPLAY
what type of heater are we talking about no display could be many a reason, the common is lost power to display either bad connections or dead batteries, so if you can give us heater make or at least gas, air con, electric or what not it would help with brand make and model then can help, but no display usually means no power unless its a lcd display or something like that that is broken so a bit more info and you'll get more help and pointed in right direction
Nov 17, 2010 | Honeywell Heating & Cooling
Delphi skyfi3 display blank. manual power only briefly...
try plugging the DC adapter directly into the buttom of the SKYFI3 - do you still get some sort of a power warning?
Jan 20, 2010 | Delphi SKYFi3 XM Radio Receiver with Car...
Blank display, machine seems to boot ok but display is blank.
If you hear your computer beep once then your system has no problem. If it does'nt show a display, try to check the power of your monitor, if it has power. Check the power cords and also the vga connection.
Nov 10, 2009 | HP Pavilion dv9000 Motherboard
Tally 2250
Measure with a ruler the size of the form in inches that you are going to use .
Calculate the number of lines you have by relating it to the Line Density using the formula
Form Length = Form Size * Line Density
For example for 11 inch paper at 6 lpi = 11 * 6 = 66 Lines
You must disable the Printers Menu Lock before you can change any settings - (power on holding down SETUP)
Press SET UP button on the Control Panel.
Select the MENU Option on the Control Panel Display.
Select the NEXT Option on the Control Panel Display until PAPER is displayed.
Select the PAPER Option on the Control Panel Display by pressing the button directly beneath it.
Select the Desired Paper Path for the Form Length change - The different Paper Paths can be stepped through by using the NEXT Option on the Control Panel Display.
Select Paper Path by pressing the button directly beneath it.
Select FORMLEN by pressing the button directly beneath it.
Select LINES and then increase or decrease the value on the Control
Panel Display by using the two arrow buttons until the desired length in lines has been achieved.
Select the SET Option on the Control Panel Display by pressing the button directly beneath it.
Set the Printer back ON-LINE by pressing the ON-LINE button.
This will set the form length on the printer, see the support section of www.dascom.co.uk for more info
Sep 18, 2008 | Tally T2250 Matrix Printer
Firmware upgrade failure
Try this for the reset
First turn the unit off then
hold down the "Pure Direct" and the "Direct" buttons on the display at the same time. And while you are still holding them down turn the unit on with the power button on the display.
this should reset the microprocessor.
You will need to put all custom settings back in.
Let me know if this helps.
Dave
Jun 06, 2008 | Denon AVR-3805 Receiver
Computers & Internet Logo
Top Mercury Electronics Computers & Internet Experts
David Payne
David Payne
Are you a Mercury Electronics Computer and Internet Expert? Answer questions, earn points and help others
