Midea dishwasher problems
Dishwasher wqp12-9346b-cn shows error message 001 please assist
2 Suggested Answers
co7196
  • 3433 Answers
SOURCE: Problem of Midea dishwasher WQP12-9240A
yOU SHOULD BE ABLE TO USE THE SERIAL AND MODEL NUMBERS. The factory technician will ned those at the least.Look up the Midea on the internet and get the factory rep to explain the warranty or the dealer you purchased the unit. Good Luck
Posted on Jun 01, 2010
I bought a FS40-8MW/FS40-SMB fan and it was missing the small pieces. No plastic nut or spinner - Can you send these items to me at B.Townsend, 101 Vandenberg Cir, Roseville, CA 95747 Thank you
Alas Barbara Townsend,
I have a very soft spot in my heart for Roseville...
Specifically ... There is NOTHING ... FIXYA
only has FREE ADVICE.
>> Please...
EDIT this question and REMOVE your
private & personal information...
Name & address... (etc.)
((it is an IDENTITY risk you don't want... I assure you)).
Notwithstanding ... it appears you have an OSCILLATING FAN
MIDEA (currently listed under "DISHWASHER") is still a viable
manufacturer...
1-866-646-4332...
NONE of my usual parts suppliers recognize EITHER
MODEL NUMBER you posted... HOWEVER
eBay has proven quite helpful FINDING OBSCURE
bits & parts when I've been restoring things
(again... no exact matches (look for "donor" parts)).
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.Xmidea+fs40.TRS0&_nkw=midea+fs40&_sacat=0
Would that we could...
FIXYA is still only an independent ADVICE organization...
Hope this helps!!
Owners manual
Midea FS40 8M Instruction Manual
midea.com/us/contact-us
Midea Contact Us Best Home Appliance Brand Make Yourself At Home
eBay
19results for midea fs40
Carnac the Magnificent
Jun 20, 2017 | Dishwashers
Midea Tower AC show error E5
Midea Error Display = E5
Error Code Definition = Open or short circuit of outdoor temperature sensor
Apr 03, 2017 | Midea Heating & Cooling
How do i fix code E9 on midea air conditioner
I have a problem with Midea Brand Aircondition .display shows E9 code error,what is a solution
Dec 22, 2012 | Midea Heating & Cooling
Hi, I have an E4 error message on my Midea WQP8-9325 dishwasher. In my instruction manual this is detailed as "overfilled" and the possible cause is "too much inlet water". I have had a...
Well there is water by the sensor or the sensor is bad. Do you run your garbage disposal and clear it out before you run your dishwasher ? I would say you have a clkogged or slow drain on your dishwasher I would check that and there lies your problem. could be you have some debris offf a pan in there slowing or trapping water down there enough to get your code. Clear it out and see if that rids you of your problem ,I'm sure it will and you will even find the sensor in the process to see what is going on.
Jun 23, 2011 | Dishwashers
I need the manual to use the Pelonis model ACS120A3R
Pelonis units are manufactured by Midea Group. You will need to contact them for the manual they can be found at the following link:
http://global.midea.com.cn/midea/categoryProductHome.do?categoryTypeId=8
or Via their contact page (depending on your country):
http://global.midea.com.cn/midea/about/aboutMidea_M_Competitiveness_OGN.jsp?open=block&style=block
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | Pelonis Heating & Cooling
Hi I have an LG LD - 14AW23 dishwasher. It shows an IE error (no water) but it fills, stops and then gives the error message. What's thye problem? Many thanks, John
Hi
Error code IE on LG dishwasher means Inlet error. This error comes up when the Water Supply Tap is closed or Water Supply is shut off. If water supply is turned on then make sure that the Inlet Hose is not kinked and water Pressure is not low (should be above 10 psi). Next thing to check for is Water Inlet Valve, measure the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of Inlet Valve is not clogged.
Hope this helps... Please post back for further assistance.
Daniel
Mar 26, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
Jun 01, 2010 | Midea MPM-08CR-BB4 Portable Air...
Printer Drive Problem
Please uninstall all drivers and software related to printer. Detach printer from computer connection.
Install drivers and software without the printer connected.
Restart computer and connect printer.
Thanks and Good Luck! =)
Jan 06, 2009 | Brother MultiFunction Center MFC-440CN...
Problem with printer
Here is what you do! Uninstall your printer's software by going to Control Panel then clicking on Add/Remove programs.After the list populates scrool down the list and look for Brother Printer .Unistall it. You should have a Disc that came with the printer.Place it in the drive and run it.Reinstallation will fix your problem.
Jan 06, 2009 | Computers & Internet
Dishwasher error 1
Let me know the exact model and make, So I can assist you further. Also the exact error code.
Reset the error message as follows: To cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. If the fault message reappears, please contact our Customer Service.
Regards
Ellin
Oct 04, 2008 | Dishwashers
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
