Question about Grundfos Pumps Grundfos MQ 3-45 1 HP Pressure Boosting Pump
MQ3-45B pump looses pressure every 10 seconds
94 olds silhouette new fuel pump still won t run cannot hear fuel pump ?
Is it an 94 or a 2004 Silhouette.You should hear a fuel pump when turning on the key (anytime after the key has been off for about 10 seconds) or whenever there is oil pressure.
If there is no fuel pump sound or fuel pressure when the key is turned on (this is the prime cycle) then crank the engine for at least 10 to 15 seconds to get oil pressure as this is the 2nd source of power to the pump and what powers the pump when driving.
Still no pump running?
Check fuse /wiring/connections/including ground.
Lastly..... New fuel pumps don't always work just because they are new,
Feb 17, 2018 | Cars & Trucks
I have a 1991 Chevy s-10 4.3 fuel injection will crank fine every time runs for around 30 seconds then dies need help troubleshooting
Do you know if the pump continues to run beyond the first 30 seconds ? Are you loosing fuel pressure ?
Jul 23, 2014 | 1991 Chevrolet S-10
What can kill the fire to fuel pump
The fuel pump is controlled by the ECM which receives a signal from the fuel pressure sensor . When the pressure is reached the sensor signals the ECM and the power to the pump is reduced / stopped until the pressure falls . Have a fuel pressure test done on the manifold to check fuel pump--pressure regulator and filter. Run fault codes to check for correct venting around the canister.
Mar 03, 2014 | 2000 Dodge Durango
My Wel-Bilt 1hp Shallow Well Pump #109231 is continually recycling (every 30 seconds). It looses about 10 pounds of pressure as soon as it reaches 40 lbs. There are no obvious leaks anywhere. The tank...
It is hard to figure out but you have what I call a water bound system. There is no air in your pressure tank. The easiest way to resolve is to drain the tank, let it fill with air, then turn on the pump, problem should be resolved for a while. There is a device that regulates the amount of air in the tank, that has failed or needs adjusting.
Nov 03, 2013 | Plumbing
I have a 1993 Pontiac transport van and it will start up and run for 5 or 10 seconds and die
You may want to do a fuel pressure test to start. The pump could be defective. The fuel pressure should hold steadily and not decline with the pump off. If the fuel pressure falls, you either have a fuel leak, stuck injector, faulty fuel pressure regulator, or a bad fuel pump check valve. If the pressure holds at the correct spec, note the pressure as the engine runs and then dies. If the guage shows correct pressure, you can then move on ruling out the fuel system.
Apr 03, 2013 | 1993 Pontiac Trans Sport
Will start if i put gas down the port/carb seems to have fuel press at test port,,changed the rotor/dist. cap,don,t allway have fuel press may be the knock sensor ?shutting it down. it was hard startind...
sounds like fuel pump relay. next time it want start pull the ecm bat fuse for a few seconds see if it will crank then. knock sensor will not cause this. ecm bat fuse it works the fuel pump relay,fuel pump,injectors,ignition system an the pcm. also the oil pressure switch will shut down the fuel pump if oil pressure drops below recommended pressure . check the connectors on these things that not loose or corrioded.i think you will find the fuel pump relay is what this relay is the problem. this relay maybe in dash or under hood in the relay box.
Dec 11, 2010 | 1997 Chevrolet S-10 Pickup
Hard to start after it sits u have to keep cranking for at least 30 t0 45 sec
When you turn on the key the fuel pump relay causes the pump to run for one second to bring the fuel manifold presure up. If the vehicle has 'sat' for a long time, this one second is not long enough and so the engine is struggling to get enough fuel to fire. Try turning the key on and off every couple of seconds for about a minute, then turn the key to the start position. The engine should now start. Do not touch any controls such as the throttle, the computer will take care of all this.
Mar 17, 2010 | 2001 GMC Jimmy
When starting my truck it will turn over for about 10 to 20 seconds and then finally start but when it does it idles really low for about 5 seconds or so and then it finally comes up to normal idle. I...
You are loosing fuel pressure when the engine is not running. The common failures are the fuel pump and the fuel pressure regulator. The way to test it would be to put a fuel pressure guage on it and a shut off valve. Then turn the key on and see if the pressure drops. If it dose then turn the key on again and then shut the valve. Depending on wheather the pressure drops again or dose not then you will know which one is loosing the pressure. Also about the low Idle the IAC motor may have carbon built up in it. You will need to clean out the throttle body real good with carb and choke cleaner. At the top of the throttle body in the bore you will see a small passage you need to spray lots of carb cleaner in there to clean out the passage.
Hope most of that made since.
Oct 13, 2009 | Chevrolet Silverado 1500 Cars & Trucks
When starting car, takes 8-10 sec to turn over.
Do you mean 8 to 10 seconds to START? Turn over means the engine is turning or cranking BUT starting is when the engine is actually running. I think you might have a fuel problem like your loosing your prime. Turn the key off wait 15 sec. then turn the key ON not cranking it repeat this (3x) if the car starts immediatedly your fuel pump is loosing its prime or the fuel pressure regulator is leaking.
Jul 13, 2009 | 2001 Isuzu Rodeo
Grundfos Pumps Grundfos MQ 3-45 1 HP Pressure Boosting Pump Logo
42 people viewed this question
Top Grundfos Pumps Plumbing Experts
Matthew Ward
Level 1 Expert
Gil Shultz
ray gallant
Are you a Grundfos Pumps Plumbing Expert? Answer questions, earn points and help others
