Question about Chevrolet Silverado 1500 80-1858 Smartcable
When accelarating starts to cut out but when release gas pedal goes back to normal idle speed
    Top Expert:
  • 12,650 Answers
If no codes can still a few different problems 1-air fillter needs replacement-2- throttle body dirty clean if needed 3-tune up-4-egr needs cleaning 5-fuel filter clogging-6-fuel pump restriction malfunction 7-catylic conv clogging restriction
Posted on Dec 30, 2013
I have a 2002 LW200 wagon with L61 Eco-tec. I installed rebuilt engine. Put back old IAC. I checked pintal to make sure it was 20MM. Engine starts great but idles at 2300-3000. After a few seconds the...
throttle position switch sounds like getting false readings to computer,
incorrect volts or excessive play from the throttle plate or sensor causes this,has to be one or the other,also check for any intake leaks from the filter to the throttle body,good luck,Gary
Oct 24, 2013 | 2002 Saturn L-Series
My 2001 Buick Regal will only start if press the gas pedal, when I release the gas pedal to step on the brake the engine shuts off. Any Ideas?
Could be a dirty throttle body or a faulty idle air control valve.
The computer controls idle speed by regulating the amount of air entering the intake thru the throttle body.
Jan 25, 2013 | 2001 Buick Regal
2000 mercury cougar engine speed stays up when gas pedal is release, increase when pedal is release and shifting gears, takes 3 seconds or more to come down to idle when gas pedal is release, will hold at...
You have a mechanical bind. Disconnect the main linkage and work it all by hand. Everything should be free and slopy. Aerosol carb cleaner will help, but only when the engine is not running.
May 30, 2017 | Mercury Cougar Cars & Trucks
Engine start and revolution normally but failed when releasing the accelarator pedal
HAVE THE IDLE AIR CONTROL VALVE CHECKED, THIS VALVE MAY BE BAD, THIS VALVE IS LOCATED ON THE THROTTLEBODY AND IS WHAT CONTROLS THE IDLE. I WOULD START WITH THAT AND ALSO CLEAN THE THROLTE BODY AND THE PLATE.
Sep 21, 2010 | Mitsubishi Pickup Cars & Trucks
96 GC Orvis-Severe vibration in Idle.
Before you go changing the idle motor, clean the throttle body out with a spray cleaner and make sure you get into the idle speed motor orifice. Spray the cleaner into the throttle body with the engine off, do'nt be afraid to use it all then let it sit awhile. When you try to start the car it might not want to start, just keep your foot all the way down on the gas pedal and as it starts and clears up just release the pedal slowly. If the car smokes out of the exhaust, thats normal. Hope this works.
Jan 23, 2009 | 1996 Jeep Cherokee
1995 Toyota Camary Erratic idle/accelaration from engine
The timing belt is one tooth off. Pull the covers back off, set the engine to TDC and recheck your marks, and make sure that the tension is correct.
Jan 12, 2009 | 1995 Toyota Camry
1985 Buick park avenue 3.8 FWD
Idle step up or choke Check that the throttle plate is fully back on the idle screw.Make sure the return spring hasnt fallen off.
Oct 10, 2008 | 1985 Buick Electra Coupe
Chevrolet Silverado 1500 80-1858 Smartcable Logo
66 people viewed this question
Top Metra Vehicle Parts & Accessories Experts
Tom
Jim Y
Jim Y
john h
Are you a Metra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
