Hitachi SP-120 JJS , remaining time is not reasonable (take long time for the same amount of cloths before the sad day !!)
Remaining time is not reasonable (take long time for the same amount of cloths before the sad day !!)
  • 57 Answers
May be the timer section is defective
Posted on Dec 25, 2013
The fan for heat/air condition not working
Hello Bill,
Sounds reasonable... just a fuse... problem is fuses operate for good reasons most the time... and a quick look in the internet says... more about blower motors than FUSES
My favorite wiring site shows service bulletins... but is sadly devoid of your Magentis wiring diagram...
bbbind.com
LOOK FOR YOURSELF AT
https://www.bing.com/search?q=kia%20magentis%202007%20heater%20blower%20fuse&qs=n&form=QBRE&pq=kia%20magentis%202007%20heater%20blower%20fuse&sc=0-20&sp=-1&sk=&cvid=9B05FFEB1CAC416EAE90FFEAD3ABCC7B
BBB Industries Premium Alternators Starters Power Steering Products
Likewise Rock auto .com has lots of 2007 blower motors... just lacking the Magentis model (again... but does show Optima: You must verify...
... (same?))
2007 KIA OPTIMA 2 7L V6 Blower Motor RockAuto
Apr 09, 2016 | Cars & Trucks
My washer always gets unbalanced load with 7 minutes remaining.
This sounds like a problem with an unbalanced washer or unbalanced load. Your washer has four leveling rubber screws underneath. To keep it from rocking make sure all four points are touching the floor at all times. Washer machine being level is a great plus. Also it could be the amount of clothes put into the washer. The more clothes you put in the less chance of your load being uneven.
Jun 06, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Series 80 dryer not holding a flame. the flame lasts 1-2 minutes then goes out. IT IS NOT the gas coils because i just replaced them. the thermal fuse gives me a beep from my multimeter. i ordered one
Must be the control thermostat. Note: them coils only stay on a brief period of time. They do not stay on indefinitely. The duration depends on how many wet clothes are in the dryer etc. The least amount of resistance to heat the quicker they shut down. The way it works is temp is maintained between 140f and 105f by doing a series of burns for breif amount of time. The coils do not remain on for very long. If they did the clothes would burn up. You need to remove inspect and clean the filter chute. Probably clogged. The dryer must be put back together for testing with damp clothes in the drum and the door closed.
Nov 20, 2013 | Kenmore 75944 Gas Dryer
Hitachi 28LD5200E will not turn on after long periods of time
There are various reasons for this. Moisture inside the TV, dry solder on boards, dry/leaky capacitors on the board etc. Try changing the power outlet and ensure that it is giving out the voltage required. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Hitachi 28LD5200 28 in. HDTV-Ready LCD...
I need to purchase a drive enclosure for a Hitachi hard drive. Model no. HTS541612J9SA00. I have bought 2 different models both were wrong. Help!
The drive you posted is a SATA I drive, that may be the reason the other enclosures did not work. Search for an enclosure that is SATA I compatible.
Here is one from Thermaltake:
http://www.thermaltakeusa.com/Product.aspx?C=1289&ID=1940#Tab1
Jun 12, 2011 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Jul 29, 2010 | Washing Machines
Is Zune 120 water resistant at all?
sadly it is not. However you can place the zune into a DRY bowl of rice for twenty four hours to help pull all remaining moisture from the circuit board. After that, if it does not power right on, reconnect it to your computer and see if it starts charging. If this does not work, you most likely have fried the circuit board. it's unfortunate but i've done it myself a time or two. Hopefully this resolves your issue though. Let me know how it turns out :)
May 21, 2009 | Microsoft Zune120 Digital Media Player
Clothes are not clean How can I take washer aprt to clean soap dispenser???
Dear carolesergy,
Welcome to fixya
You sad,My clothes get dingier ever week from using my washer especially the towels. They are now Grey and not white
1.Here are some ideas and INFO!
2.How old is your MAH5500B washer and did you buy it new?
3.Do you use HE High Efficient detergent?
4.Do you ONLY put the proper amount of detergent directed to be used by the manufacturer?
5.Using to much detergent will degrade the seal and eventually destroy the bearings.
Which will cause oil to leak out on your clothes and sometimes make gray stains on them !
6.Is there tiny gray oily pieces in the wash and on clothes?
7.Look closely at your rubber seal around the opening. Is this worn or deteriorating away slowly due to bleach or detergent? Is it a gray or black rubber?
Please have patients and bear with me, with all these questions I propose to you here!
I am searching with your eyes for things I have seen in the past about this model"
Here are some reasons this may also happen!
How large of a load can I wash in my Maytag Neptune washer?
* The tub can be loaded completely full with dry, unfolded clothes. However, do not pack the tub tightly. If the load is heavily
soiled it is very important not to overload the washer.
My whites are not as white as I’d like.What can I do?
* Wash white loads using the cotton/sturdy fabric selection. Select the hot wash/cold rinse temperature setting and put 3/4
cup of chlorine bleach in the bleach dispenser. The bleach will be dispensed in the final minutes of the wash providing for
optimal whitening. Maytag recommends a hot water wash temperature of 120-140° F (49°- 60° C).
Also:
*The lint filter in side the machine may be clogging with dirty lint!
*Which means you needed service!
I hope one of these solutions is the reason!
Let me know how you do!
Huuum
Please remember to leave a rating for me!
Oct 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Bosch WFMC3200UC/01
Try cutting the amount of soap you use in half. If we use the detergent manufacturer's recommended amount (yes, we are using HE type detergents), suds remain and require additional rinse time or cycles, taking a long time. We cut the HE detergent in half and the times got pretty accurate and the clothes still came just as clean. Hope this helps you!
Apr 25, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
