Question about Kenmore Front Load Washer
Hitachi SF-120 JJS , remaining time is not reasonable .. usual time taken about (35 min) .. few days ago then for the same amount of cloths the remaining time exceeded (100 min) !!!
  • 57 Answers
Sensor may be defective otherwise the motherboard is faulty
Posted on Dec 25, 2013
1986 Lincoln Town car 5.0 intermittent stalling problem, usually while driving. fuel pump?..please advise! Thx!
It appears you may have a bad ignition coil that cuts out after it gets hot. Not uncommon.
Aug 16, 2017 | Lincoln Cars & Trucks
INTERNAL TEMPERATURE FOR BEEF
it all depend how you want your Beef
Rare:
• 120-130 °F (50-55 °C) Internal appearance very red; very moist with warm juices. Approximate cooking and resting time: 20-25 min./lb. plus 8-10 min. resting
Medium-rare:
• 130-140 °F (55-60 °C) Internal appearance lighter red; very moist with warm juices. Approximate cooking and resting time: 25-30 min./lb.. plus 8-10 min. resting
Medium (with a touch of pink):
• 140-150 °F (60-65 °C) Internal appearance pink red color; moist with clear pink juice. Approximate cooking and resting time: 30-35 min./lb. plus 8-10 min. resting
Well-done:
• 150-165 °F (65-75 °C) Internal appearance no pink or red, slightly moist with clear juices
taken from
Cooking Temperatures for Beef
Oct 30, 2016 | Cars & Trucks
Hitachi model sf-95pjs top loading only spinning not not working on last of cycle even when I select spin (no rotating with high speed and cycle finish and give pip)
If the drive motor is not burnt out, then the washer has too many clothes in it to spin fast. If you cram too many clothes in the washer, it will not spin itself to ashes. It will complain. If you practice, you will find the correct amount of clothes it will spin without complaining. Eventually, the drive motor will burn up. They all die this way. hitachi-model-sf-95pjs-top-loading-only-u40lsvyytnuesyuv3fbafhtd-4-1.jpg
Jan 04, 2015 | Speed Washing Machines
2002 Honda CRV rear brake running hot. Taken to mechanic says, needs new calipers, brake pads and rotors. Reasonable assumption or can calipers be repaired with kit, rotors re-machined and new pads...
Although calipers can be rebuilt, it's usually more cost effective to buy a rebuilt caliper. As far as turning the rotors, modern day rotors are much thinner than those of 20 years ago. Where in times passed you could turn down rotors 2 or 3 times before replacement, taking a few 1000ths off a newer rotor will take it under factory specs. As far as a reasonable price goes, the full job can run anywhere from $400-600 depending on the shop doing the work. Doing the job yourself you can save a few hundred dollars in labor and another $100 in parts markup.
Aug 06, 2011 | 2002 Honda CR-V
Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Jul 29, 2010 | Washing Machines
My washing machine drains but does not spin
Look for a motor belt that is worn out and make sure that the drum turns freely (machine off).
Aug 01, 2009 | Magic Chef CAV2000AWW Top Load Washer
My 2003 Explorer overheats when I turn the A/C on.
Q: Temp starts to climb by how much? If the vehicle interior is hot"over 90" , keep in mind the heat in the vehicle is being absorbed by the a/c and carrued out to the "condensor" in front of the engine radiator. Engine temp should be expected to climb somewhat. As the interior cools down the less heat is taken to the font and forced through the engine radiator. It should peak out ,then staer deopping or stabilize. On initial entry of vehicle on hot days it would help to open the windows for a mile or so to purge excessive heat from passenger compartmentw/AC OFF. OUTSIDE CAN BE 90 AND THE INTERIOR OF A CLOSED UP VEHICLE CAN CLIMB TO 120 DEGREES + mID 80'S IS HANDLED WITH GREATER EASE FOR A COMBINATION OF TECHNICAL REASONS OF WHICH WOULD BORE YOU.It sounds like all is well so be cool(pun) and don't waist money chasing a ghost. Happy trails. Oh, The auxillary fan is good to speeds up to 35 mph. Above 35 the forced air from the vehcle speed does the fans job.
May 11, 2009 | 1998 Ford Explorer
Bosch WFMC3200UC/01
Try cutting the amount of soap you use in half. If we use the detergent manufacturer's recommended amount (yes, we are using HE type detergents), suds remain and require additional rinse time or cycles, taking a long time. We cut the HE detergent in half and the times got pretty accurate and the clothes still came just as clean. Hope this helps you!
Apr 25, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore Front Load Washer Logo
49 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
