Question about Sony VAIO Computers & Internet
Sony vaio VPCEB43FD
I have got new ddr3 ram 8gb for my laptop it says online that my core i3 will run and handle it but for some reason when i put the 8gb ram in i will get an error from windows 8 but when i go into my bios it shows that the ram is there and ever thing. Thank you for Helping Rick
Benimur
  • 6966 Answers
SOURCE: How easy is it to install RAM into a new sony vaio VGN NR110 laptop
Most current laptops have a lid/panel underneath the bottom covers hiding the memory. You need to turnover the laptop and visual inspect the bottom panel/cover. Memories often are readily accessible to the user. They are underneath a lid/panel which is roughly squarish about 2 X 2 inches. It is normally held in place by small screw(s). Upon screw removal, you need to pry open the lid cover to expose the memories. Pressing sideways on the 2 retaining clips of the memory would pop it out slightly which should then be relatively easy to remove.Popping in new memory is the reverse. Diagonally insert the new memories into the slots to initially set them in. Gently but firmly press on the memories downwards to lock them in place. You will notice that the 2 retaining clips will automatically lock in place.
Alternately, for a few more, you can purchase the memory from any computer shop/store and ask them to install hereby assuring yourself that the job was done right. Further the store will not have any excuse/reason when the new memory malfunctions and can be readily replaced.
Of course yo can do it yourself, it is relatively a simple job and if you are willing to take the risk (very minimal), go for a DIY (do-it-yourself).
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Dec 07, 2007
SOURCE: BIOS Password For Sony Vaio
I Want to clear my bios password.
Posted on Jul 28, 2008
Dr Geek MD
  • 201 Answers
SOURCE: i need to flush my bios.forgot password. Sony vaio pcg-7g1m
Try This:
Reseat the CMOS battary:
How to Change/Reset a BIOS password Posted on 30 December 2008
Tags: Tech News, Tutorials If you are a normal computer user who has forgot his BIOS password and you are unable to access to your BIOS, then you need a simple way to change your BIOS. Its not that hard because you just need a simple trick to reset your BIOS password.
Open your CPU cabinet after switching OFF the power and then try to locate the CPU battery which can be found very easily. Once you locate your battery you need to remove it once and restart your PC without the battery.
cmos-battery-check.png Note : Once you remove your battery from the mother board, you will find that all your time settings in your computer would be lost, and some softwares may stop working which are based on your computer time.
You need to shut down your PC again and now add back the battery which will enable you the time saving feature and also reset your BIOS password.
Posted on Feb 22, 2009
  • 6 Answers
SOURCE: Having a problem getting my Sony Vaio PCG-3E2L laptop to auto play my photo DVD slide show. Using Windows Vista Home Premium OS.Also, where can I find a PDF Sony User Manaul for my laptop?
A quick short cut is to open a browser if you use Internet Explorer and select tools menu, then select Internet options. When the box opens then select the advanced tab and scroll down until you see a check box under security and check allow active content from CD to run on my computer.
Also here is the link for your manual: http://esupport.sony.com/US/perl/index.pl
Posted on Jun 02, 2009
  • 88 Answers
SOURCE: my Dell Insipiron N4010 intel
These fan are meant to run constantly at a low power and on high when using a lot of processing power (like playing a game or HD movie).
I would boot into Dell diagnostic and make sure the high and low settings of the fan aqre working properly it may be that the fan is on high all the time when it should be in low mode.
Dell Diag. Press F12 at boot Select Dell Diagnostics Go through the basic diagnostic ~5 minutes After basic diag the advanced diagnostic will start Go through the menu and select the Fan test
Posted on Mar 15, 2011
Does Intel DH61BF motherboard supports 4GB 1600Mhz RAM ?
OK, I was looking for a solution, but hardly got anything that clarify if it's compatible or not. But what I did find out is that if you install a 1600MHz memory stick, this one will clock down to 1333MHz in order for the MB not to crash. Here is a C/P.
Part #: 2xCT102464BA160B • 16GB (2x 8GB Kit) • DDR3-1600 - 1600Mhz - PC3-12800 • CL11 • Dual Rank • Non-ECC • Unbuffered • 1.5V • 16-chip 512Mx8 • Lifetime Advance Replacement Warranty • This 1600 MHz module is programmed to clock down to 1333 / 1066MHz where the system requires it.
Mar 04, 2015 | Intel Computers & Internet
Sony vaio VPCEB43FD upgrade ram wont work
Try them in different order. I swear sometimes, they have a mind of their own!!
Ohhhh, same can be said for USB devices. One port won't be able to install it, another port will have the driver installed by the time you clicked on it ??
Sep 27, 2017 | Sony VAIO Computers & Internet
My pc keeps hanging when i install an additional ram which is 4gb my current ram is 2gb My specs is: Intel Core i3 530 2.93GHz 2GB RAM 2GB Palit GeForce GT 610 1TB HDD Windows 8 Pro 64-bit Asus...
what clock speed is $are 2gb Cards. You should use 2 2gb cards rather than 4 1GB cards. If you can boot up down load Belarc Advisor and run identify particulars. It's free.
Sep 03, 2013 | Gateway Dx4831-01e Intel Core I3-530 2.93...
Why my acer aspire 5742 is automatic restart while i'm watching and playing! i dont have any idea why is that happening!
due termic reason!!!!!!is to hot !probably dust; you must clean and after that try to put a coolpad underneath it will help you
Aug 23, 2013 | Acer Aspire 5742-7620 Core I3 Processor...
Installed memory 8gb (2gb useable)
YOU CAN'T WINDOWS 32X CAN ONLY USE 4 GB (1 GB TO THE SYSTEM).THAT LEAVES YOU 3 GB AND 4 USELESS GB.
YOU NEED A 64X PROCESSOR TO HAVE USE OF 8 GB MEMORY.
Jun 11, 2013 | Intel Corporation DH77KC H77 LGA 1155...
How to ram upgrade
After doing a little research online, I see that the maximum memory supported for this laptop is 8GB. You currently have 4 GB. You would need to purchase this upgrade kit:
8GB Kit (4GBx2)
DDR3 PC3-12800 • CL=11 • Unbuffered • NON-ECC • DDR3-1600 • 1.35V • • Part #: CT3912184
You can install this kit by opening the square panel's on the bottom of the laptop. The panels are about 3 inches wide and are held closed by a screw.
Jan 14, 2013 | Sony SVE11125CXB E2-1800 1.7G 4GB 750GB...
Having problems upgrading my GatewayDX4840-11e to 32GB of memory.
Memory Type: DDR3 PC3-10600, DDR3 PC3-12800, DDR3 PC3-8500, DDR3 PC3-14900, DDR3 (non-ECC)
Maximum Memory: 32GB
Slots: 4
Each memory slot can hold DDR3 PC3-10600, DDR3 PC3-12800, DDR3 PC3-8500, DDR3 PC3-14900 with a maximum of 16GB kit (8GBx2) per slot.*
*Not to exceed manufacturer supported memory.
Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
How much memory your Windows OS will recognize depends on which version of Windows you are running. To utilize more memory, install a 64-bit version of your OS.
Thank You
TomMiller
Eng
Aug 19, 2012 | Gateway Desktop / Intel Core i3 Processor...
Which the best laptop i need a quad processor and good specs in my laptop
Before deciding the make and model of the laptop, I recommend that you may consider the specifications, Operating System, Size and Weight, Wi-fi Connectivity, Battery Life etc. and above all Warranties & Support at your city/ country level, which is of prime importance in case the laptop malfunctions at any later stage.
I suggest that you may checkout Sony VAIO or Dell Inspiron Series.
New series of Intel processors (with multi-threading) are Core i3, i5 and i7. i3 & i5 have 2 Physical Processing Units, whereas, i7 has 4
Physical Processing Units. RAM up to 4GB/6GB/8GB and storage capacity (hard disk) up to 250/350/500/1000GB are common in new models. High Definition Audio and video is a must as well. Wireless-N (up to 300 Mbps data rate) should also be available.
So, look for the laptop with above specification and decide the make/ model after actually having a look at it.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 24, 2011 | Computers & Internet
Broke my screen on my sony vpc-ea2vgx. I have a new screen coming today but need to find out how to remove the two lower screws on the bezel, do you know how?
Hi
If you go to www.sonysupport.com and download the manual for it it should show you how to do it also make sure you save it somewhere like a pendrive so that you can always refer back to it if necc also you will need adobe reader installed so that you can read it
Dec 14, 2010 | Sony VAIO VPCEA2VGX/BI Laptop Computer -...
I need ti know the warranty period of my laptop bcz iam going to sell...( Sl no: 275202857004512, Service tag no:- c603u12s )& also i need to know how much rupees i can get if i sell this laptop....
All the VAIO computers are shipped with a limited 1 year warranty.
The detailed information on Sony Warranty is available in the below link.
http://esupport.sony.com/US/perl/support-info.pl?template_id=1&info_id=28
Refer your purchase receipt or contact the sony support team to get the exact warranty status. Provide them with the model # of your computer.
Nov 19, 2010 | Sony VAIO VGN-S460 Notebook
Computers & Internet Logo
23 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
