Question about Kenmore Dryers
Dryer stopped working suddenly
Water leak from bathroom above the laundry room - leaked on dryer, only thing I can see that may have caused it to stop working??
  • 5 Answers
Does it come on at all? Check circuit breaker first. If it got into the console & or cabinet, may have shorted one of the circuit boards.
Posted on Dec 25, 2013
3 Suggested Answers
SOURCE: Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Posted on Feb 16, 2008
TheMobilian
  • 8220 Answers
SOURCE: About once every 7-10 days,
Their is a catch pan that has 2 float switches in it. One of them is supposed to pump the water into the water tray atop the machine.
The other is supposed to kill power if the pump motor fails. I would be willing to bet a hose came off the pump. When the tank gets full the water gets expelled to the floor. Here is a manual for condenser dryers:
ASKO DRYER SERVICE MANUAL
Posted on Jul 03, 2010
Bathroom leak
Most likely the problem is a leaking drain pipe in the wall, perhaps because of a failed joint. The reason it's not going down the wall to the floor of the dining room is because there is a top plate on the wall. Most likely the water is running down the bathroom wall, then out over the dining room drywall ceiling. It is finding the lowest spot in the area to accumulate and is soaking into the drywall. Since it is drain water, it is dirty and is picking up additional contaminates from the wall and causing the brown stain. It may or may not be soft, depending on how much water accumulates at one time, but it is slowly breaking down the ceiling where the stain is.
That said, are you sure it's a leak, or are you assuming that since you see the stain on the ceiling. I say this because mice, like many other rodents, usually pick one location to use as their bathroom. If you have mice in the ceiling and this is where they do their thing, you will get the same type of indication.
Nov 10, 2015 | Miscellaneous
Whirlpool duet dryer stuck on steam cycle
one trick to stop the steam is to remove the water hose connected to the dryer
Nov 20, 2013 | Whirlpool WED9500T Electric Dryer
Before leaving the house I turned on the dryer. After several hours I got home and the laundry room smelled like rotten eggs. The laundry room is upstairs with only a wash basin and washing machine in...
Its never a good idea to leave a clothes dryer unattended. They are often a source of house fires. Is it a gas dryer? Maybe a gas leak, do not use until checked by a qualified person. If electric tumble dryer, then maybe the smell was caused by some lint collected around the heater element, and it eventually scorches and stinks like that. Either way,get it checked by a profession qualified person, don't risk a fire in your house! Hope this helps, good luck.
Aug 19, 2010 | Dryers
About once every 7-10 days, an excessive amount of water leaks from beneath our dryer, flooding our laundry room. Is there an area in the dryer that water from wet clothing is collecting before it leaks...
Jul 03, 2010 | Dryers
Dryer turned off suddenly
The dryer must have a blockage. Better check the vent and filter housing for excess lint buildup. These dryers have fuses mounted on the blower housing to kill the dryer before the thing catches on fire.
f4388f7.jpgf11d8da.jpgMORE
Feb 01, 2009 | Kenmore 63942 Dryer
Zanussi wjs1265w washer/dryer
hi The door of the dryer is sealed with one or more gaskets to keep the hot air in the dryer from escaping and prevent the cool air in the laundry area from being sucked into the dryer. A deteriorated or damaged gasket greatly lowers the efficiency of the dryer. To check the gasket, hold a sheet of tissue paper near the rim of the door while the machine is running. If the door leaks, the paper will flutter. If the gasket or seal leaks, looks worn or warped, has chunks of material missing, or feels hard and nonresilient, it should be replaced with a new gasket of the same type.
Oct 25, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Water comes out bottom when I run multiple loads
pull the dryer and check your venting you can remove the vent and run a load to see if it works ok i know the hot air will come into the room but it is just a test to see if the vent is clogged this is where the condensation would come from chweck that and let me know
Mar 15, 2008 | Whirlpool GEW9250 Electric Dryer
Smell Gas.
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Condenser Dryer Still Filling Room With Moisture
all dryers produce moisture. thats what hapens when you heat wet cloths up. the dryers job is to remove the moisture to dry. thats how the automai]tic cycles work by deteting the moisture in the exhaust. i will say there is nothing wrong with your dryer. only thing i dont understand is the containers of water?
May 13, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
