Question about OEM 1997 Ford Expedition Radio / CD Player g62174658h AM-FM cassette, ID F65F-19B165-BD; AM-FM cassette, ID F75F-19B165-DA Houston, Texas
How to connect a car radio model F75F-19B165-DA
My radio does not want to work I checked da fuse its not blown and da radio still dnt work
If your car's battery was dead/removed/replaced, the anti-theft authorization code has been lost. To retrieve it for a factory radio, it will require VIN and proof of ownership and a GM cars dealer. I suspect it will cost something too.
Aug 24, 2010 | 2005 Pontiac G6
Where do i connect da pink wire
connect da pink wire to the ground wire on the stereo units wiring harness. This will tell it you are in park.
May 13, 2010 | Audiovox VM9312 Car DVD Player
I need da code u know it
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} In order to attempt to calculate your code ,the radio will have to be extracted from the dashboard ...Then please quote your radio MAKE+MODEL plus ALL the NUMBERS+LETTERS on ANY LABELS , BARCODES or STAMPED IN THE METAL CASING
Also quote the MAKE of CAR it is fitted into.
Mar 10, 2010 | Jensen Car Audio & Video
Diagrama de arnes para conectar car estereo f65f-19b165-bd
si intiendes ingles un poco, aqui es los colores por los cables para estereo tuya..
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Brown/White
Left Rear Speaker Negative Wire (-): Light Brown/Yellow
Right Rear Speaker Positive Wire (+): Light Brown/Green
Right Rear Speaker Negative Wire (-): Brown/Pink
Nov 19, 2009 | 2000 Ford Windstar
Have stock radio # F75F-19B131-AA its in a 1998 F250 need to know how and if i can hook up one Amp for the two door speakers, and if i can hook up an additional Amp for some subs. Ofcourse if radio can do...
You will need a line level converter for starters (takes speaker level signal and converts it to line level/RCA signal) you connect this to the speaker left/right wires and it has a RCA left right on other end to connect and run to your amps, (you need this box because factory radios don't have RCA outputs on them) At that point all you have to do next is run the power/gnd/rem for your amp and then speaker wires to your front/rear speaker and then sub (if using). You can use one of these converters for your front/back speakers so you will still have use of your front/back/left/right fading options. make sure you disconnect th factory plug/harness at each speaker since the amp will be powering them and you will run speaker wires to each speaker. If you only want one converter it will be on your front channel and your sub will be power by the front. (you will fade to front for more/less sub bass unless your amp has a separate volume/bass control). If you want your sub to fade with rear speakers you will need to install another converter off of the rear speakers. Found a site with some photos that may help you with your project.
http://www.redlineforums.com/forums/howto-section/15003-how-sub-stereo-amp-install-factory.html
Aug 18, 2009 | Car Audio & Video
Need a wiring diagram for car stereo f65f-19b165-bd A speaker wire diagram is needed for a 1997 Ford Expedition with stereo part number F65F-19B165-BD.  I have purchased a JVC HD Radio and will be...
why not put a belson car radio that uses a sd chip card and a usb connection ,a 1gb sd card is about 30 cds so why mess about with the cd changer ,old technology ,would you put an 8track in it ?? or a mobile vinyl 45 record player
Jan 14, 2009 | 1997 Ford Expedition
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Sep 29, 2008 | 1996 Ford Explorer
OEM 1997 Ford Expedition Radio / CD Player g62174658h AM-FM cassette, ID F65F-19B165-BD; AM-FM cassette, ID F75F-19B165-DA Houston, Texas Logo
145 people viewed this question
Top OEM Car Audio & Video Experts
D. E. Hev
wadingriver
wadingriver
Are you an OEM Car Audio and Video Expert? Answer questions, earn points and help others
