Icoustic bluetooth tower speaker TADK24 auto standby, how do i turn the auto standby after 15 mins off
ICraig Tower Stereo system will not turn on from standby
sometimes the system can get a little "rusty" after inactivity. The most common simple solution is to unplug it then plug it back in
Jan 01, 2014 | Craig Tower Speaker System For iPod,...
Please can you help us. when we turn the computer on the monitor light stays blue with the screen remaining black, when we turn the tower off the light stays blue when it usually has the orange standby...
There is probably a conflicting setting in your power management options. My recommendation is that you check the monitor setting in Windows and see how you have it set up. In Windows it is under CONTROL PANEL>POWER OPTIONS. There are a few differences between WINDOWS 7 and XP from here on out, but in general, do not select a scheme and do not select any hibernate, standby, or sleep modes. If you stick with a simple power saving option, like "TURN OFF MONITOR: After 15 mins." you should not have any further problems.
Many of the Windows "green schemes" will not work right with different combinations of BIOS, Hard drive, motherboard, and monitor. It is best to avoid them, unless you are very patient and willing to go the trial and error route. Good Luck!
Mar 08, 2011 | ViewSonic VX2235WM Monitor
Any know how to set the clock on an icoustic eb837 ipod dock clock radio?
HOLD THE "STANDBY/SOURCE" UNTILL THE SCREEN LIGHT DIMS OUT. THEN PRESS THE "MODE" BUTTON. IT WILL SAY "24HR", IF YOU PRESS THE "MODE" ONCE MORE IT WILL GO TO 12HR CLOCK. PRESS "TUNE/SKIP" TO ENTER THE HOUR. PRESS "MODE" TO SELECT THE MINS AND CONTINUE ON USING "TUNE/SKIP" TO ENTER THE MINS
Apr 12, 2010 | Audio Players & Recorders
AR SW-30 subwoofer doesn't switch to standby mode when off
Disconnect its input cable to see if a true lack of signal lets it go to sleep. If not, it has a bug. Otherwise, you probably have some sort of signal present on the sub cable.
Jan 17, 2010 | Audio Players & Recorders
145 people viewed this question
 Grubhead
Grubhead
