How do I connect to Sony TV?
SOURCE: reception of vhf/uhf channels
You did not mention which set you have, so look for a small switch (usually on the back of the set) or go into the menu and set the TV to the "broadcast" or "tv" mode. If the set is in the "cable" mode, you will not get any UHF channels above 13.
SOURCE: Digital to Analog converter...no signal
One of the problems with digital reception is if the signal is not strong enough for the converter box/or built in tuner on a new TV- you will not get any picture at all. If you followed all the directions-and the converter box shows no channels- then you do need a better antenna. I don't know how far you are from the broadcast antenna, but a good rule of thumb is if you live 10 miles away, buy an antenna that is good for twice that distance, or further. They are rated in miles of reception
SOURCE: Want to hook up Zenith converter box with RCA F25432 TV
If the converter box calls for rca cables and your tv has none, you will need a vcr to interconnect. If your converter box has coaxial then it's an easy hook up. If they are holes labeled S and F then those are Screen and Focus screws. To adjust your screen and focus it. If the are actual jacks labeled S and F, then I don't know what F is but the S would be S-video. Hope this helps.
SOURCE: VHF/UHF cable connector broke off from back of televison
well it can be fixed but you will need rf connector their cheap send it to a tv shop they will fix for 30-50 bucks sorry
SOURCE: old tv, digital converter and dvd hook up?
connect the converter in connector to the antenna.
connect the converter out to the dvd in, and the dvd out to the tv in.
