Question about Canon NP 6551 Black and White Copier
E540-8005 in canon ir 2870
I have a problem with canon ir2870 in start error E540-8005 shutdown help...
KyoDoc
  • 38 Answers
SOURCE: IR 2870
The waste toner container is full. the front cover of the machine (the one with the Canon logo on it) must be removed. behind you will see a big white plastic bottle. Remove the bottle, empty the contents into the bin, wipe it off, and refit all removed parts. Finally restart the copier.
Posted on Sep 24, 2008
canontech
  • 1219 Answers
SOURCE: error code 19
You have waste toner full!
Remove the drum, on top of drum there is cork, remove cork and vacume all the waste toner out.
Posted on Jun 02, 2010
canontech
  • 1219 Answers
SOURCE: I have a caono IR
You need to replace fixing film.
Posted on Dec 28, 2010
SOURCE: Sir I have Canon IR
Sir I have canon 2870 machine. The machine giving the finisher problems, when starting the finisher going down. The machine showing the problem E540. Please kindly solve
Posted on Jun 09, 2011
canontech
  • 1219 Answers
SOURCE: canon ir2870 error code e000002
these means that in fixing assy is low temperature. It can be that you only need to clear the error trough service mode, or you need to change thermistor.
To clear the error:
enter the service mode:
1) Press the asterisk key " * " on the control panel
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " " on the control panel.
then choose COPIER, then FUNCTION, then CLEAR and choose ERR. Shut down and back ON the copier.
If these doesn't helps, replace thermistor which is inside of fixing film ceramics.
Posted on Jun 12, 2011
How to Clear Error- 000716-0010 in Canon IR2870 Copier?
E716 - There is an error in the communication with the pedestal.
After the presence of a pedestal has been detected, the communication fails to be normal for 5 sec.
1. Check the cable. Replace the DC controller
2. PCB. Replace the pedestal drive PCB.
http://www.smoothprinterservice.com/
Sep 22, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
How do I solve Error Code - E000716-0010 In Canon IR2870
Failure of the communication with the 2-way unit
Description
When the communication with the 2-way unit is faulty after detecting the connection with the finisher.
Remedy
1.Install the 2-way unit.
2.Check the cable.
3.Replace the DC Controller PCB (PCB4).
4.Replace the 2-way unit driver PCB.
E000225 0001
Oh, it looks like your ImageRunner's fixer unit (the heater thermistor it uses to regulate temperature) burned out or disconnected on you. http://canon-ir-6000.blogspot.com/2009/02/e000-main-cause-main-thermistor-th1-has.html
Find that little sensor leading up to the coils and replace it.
Otherwise, say that again in just Hindi?
Aug 04, 2014 | Canon Crtdg, gpr15, ir 2270/2870, bk
Canon ir4570 ir3570 ir2870 ir2270 service manual
Hello friend, you can find the canon ir4570 ir3570 ir2870 ir2270 service manual in below link:
Canon service manual:
http://goo.gl/GDAzQQ
Thanks
Apr 12, 2014 | Canon imageRUNNER 2870 Copier
Ir2870 how to solve error 602-0102
press *(additional function) then press 2 & 8 together and *(add. fun.) again . select COPIER on screen then <function>..<clear>...<system>...<hd clear>.... switch off and after a minute start. if problem continues.... replace hard disk.
Oct 18, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Canon ir2870 e000732-0010
your problem might be faulty connection on your DIMM modules.
Take it out and clean the contact area with a brush, place it back and start the machine.
If this dose not solve your problem it means the Reader Controller PCB is faulty and needs replaced.
Oct 29, 2012 | Canon Ink Cartridge GPR15 for iR 2270, iR...
I need help in canon ir 2870 error 00001
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
Replace The Main Power Supply PCB Assembly (The part number FM2-0260-000).
NOTE: if the fixing unit circuitry has an open or a short, the code may not reset.
Confirm the fixing unit wiring and try to reset the code first, before you replace the Main Power Supply Assembly
hope it helps
Sep 24, 2012 | Canon IR2870 COPIER FOR 220 VOLTS ONLY
Canon NP 6551 Black and White Copier Logo
89 people viewed this question
old marine
old marine
