Question about Sony Ericsson Computers & Internet
No service no signal - Sony Ericsson Computers & Internet
    Scholar:
    New Friend:
  • 87 Answers
Check whether your sim is placed properly in the slot. Try to reinsert the Sim. Still if you face the same problem then your phone might be locked to particular Network. To solve this problem you need to get your phone unlocked. You can unlock your Sony Ericsson phone using unlock code. You can get the unlock code for your phone from your Network service provider or Network service provider or any third party online vendors like Unlock-Zone.com here you need to specify your country, current Network name, IMEI number of your phone. Then they deliver unlock code to you through mail with unlocking instructions. Using this you can unlock your phone from Network lock easily.
Posted on Dec 28, 2013
My tv was working fine this morning came home and all I get is no signal moving around the screen
Hello, Tracey -
When we see the No Signal message moving around our TV screen it means our cable TV service is not available. If you have a satellite dish for your TV, the "No Signal" also probably means there is no service.
If yours is cable TV service, if you have not already done so, I suggest you pick up your phone and make a call to the number for your cable TV and ask to be connected to a technical service representative. You will probably need to have your cable account number and other ID handy when you make the call.
If yours is satellite dish service, again, call the TV service number. If you reside where there have been strong storm winds, the reception dish may have been blown out of alignment and it will need to be set back in the proper direction for signal pick up.
Best wishes.
Jan 15, 2018 | Televison & Video
I have a 2002 Park Avenue my turn signals do not work my flashers work
gmlogoflat.gifService Information
2002 Buick Park Avenue ' Park Avenue (VIN C) Service Manual ' Body and Accessories ' Lighting Systems ' Description and Operation ' Document ID: 643323
Turn Signal/Cornering Lamps
The HZDT/SIG fuse in the fuse block - underhood - left supplies battery positive voltage to the turn signal/hazard flasher module and have ground at G202. The turn signal lamps may only be activated with the ignition switch in the ON or ACCY position. The T/SIG fuse in the fuse block - underhood - left supplies battery positive voltage to the turn signal switch. When the turn signal switch is placed in either the left or right position, current flow is from the turn signal switch assembly to the turn signal/hazard flasher module. The turn signal/hazard flasher module then sends an on-off voltage signal to either the left or right turn signals and their instrument cluster (IPC) indicator. When the hazard switch is pressed, all the turn signal lamps will flash including both IPC turn signal indicators. The left turn signals have ground at G106, G400 and at G402. The right turn signals have ground at G105 and G400. The turn signal switch supplies battery positive voltage to the cornering lamps, the left cornering lamp has ground at G105 and the right cornering lamp has ground at G106.
+snpvvsvwho06+5aqhepgaaaabjru5erkjggg==
May 10, 2016 | Cars & Trucks
Signal weak
I'm assuming that your cell phone works fine.
Your cell phone gets its signals from cell towers serving your cell phone service provider, e.g. Sprint, AT&T, Verizon, T-Mobile.
If you are in a building or elevator, your signal can be weak. Try going to the edge / side / top of a building, like by a glass window to see if the signal is stronger.
Or if your cell phone service provider (phone company) doesn't have a cell tower close to where you are, the signal can be weak or nil.
You can find out your cell phone company's cell tower coverage areas ...by checking their website. If you are at locations where your cell phone service provider has good coverage, you will get stronger signals. Otherwise, expect to get weak signals.
Yes, it's always prudent to check which cell phone service provider has good cell (tower) coverage in areas where you are (using your cell phone) most of the time, and subscribe to that company's cell phone service.
Nov 04, 2013 | Samsung Star Cell Phones
Very poor mobile signal
That is the Service Providers tower signal being poorly received or being disrupted/blocked in certain areas.
Best change your service provider using number portability to a reputed one, viz., Vodafone, Airtel, Tata, etc.
Jan 10, 2012 | Cell Phones
Hello.. look.. here is the problem. i have a samsung s5230 star since the begining of this year. since two weeks ago my phone only shows limited service or no service. however sometimes i have signal .....
Your phone can't seem to locate signal on your are that's why it says No service. There;s nothing wrong with the phone, it's more on the signal coverage of your netwrok provider. There are some areaas that have strong signals and some areas that have weak signals. You may also want to contact your network provider about it.
Aug 28, 2010 | Cell Phones
Motorola v6 no signal
that golden piece is the service. That's what brings signal to the phone. its like an antenna that make the phone have signal.
So try to fix it back on into the phone, and your phone service should be restored.
Good luck.
Apr 15, 2010 | Motorola Mobility MOTORAZR maxx V6...
LG KS360 Signal in and out and roaming all the time
Mine does the same thing. But that actually is because my house has terrible signal in certain parts... The best thing to do is to make sure that where you do makes call ect. is somewhere with very good reception..
Something like that tho can't really be helped.. I think this phone is just generally terrible for getting a good signal.
Jun 16, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Nokia N-Gage No Signal
n-gage try to go nearest cellphone technician there tell cp tech.reprogram your fone.tnx
Oct 01, 2008 | Nokia N-Gage Cellular Phone
Signal
i suggest that you need to go to service center, your phone need servicing.
Jan 18, 2008 | Nokia 6233 Cellular Phone
No signal
check your service provider/carrier if ou are having problems with your phone , bring it to local service center.
Sep 20, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Computers & Internet Logo
52 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
