Question about Oreck Vacuums
Vacuum motor screaming
Oreck Magnesium Upgright - sucked something unpleasant and started screaming - does so every time I turn it on!
    Prodigy:
    An expert who has answered 500 questions.
  • 517 Answers
Look at all the pipe and unblock them
Posted on Dec 25, 2013
chrispurs1
  • 372 Answers
SOURCE: Oreck Vacuum troubleshooting
Hi. If the motor is on its way out the motor noise will be eratic eg slowing down speeding up popping noise & a smell of electrical burning. If you have none of these symptoms then chances are its not the motor. Does the bag inflate or is it easy to collapse when you push the bag ? If bag inflates ok check belt. If bag not fully inflating check for blockages along length of the handle pipe its designed to pull apart by lifting up rubber sleeve at machine end of pipe, push ball latch in & pull pipe out remove any debris stuck in the pipe. Remove bbottom of machine as if replacing belt check to see if there is any debris stuck in the oppening that goes to motor fan, then check the fan blades you can see them through the port is there any missing or snapped off. If blades are missing or have big chunks missing you will need to replace. If fan only has minor bits missing then reassemble it should now worl well.
Posted on Sep 09, 2007
reddevil6
  • 1673 Answers
That the bottom plate off, check for a clog in the inlet. If clear, then you probably have a clog in the handle tube. You will have to take the handle loose to clean it out. It may also need a new belt if you haven't changed it for a while, they stretch.
Posted on Feb 05, 2008
SOURCE: Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Posted on Mar 26, 2008
SOURCE: Oreck Vacuum Cleaner problem (upright)
the belt has stetched and needs changing.
Posted on Apr 21, 2009
SOURCE: My Oreck XL has quit sucking. The brush turns but
Same problem here with XL9100. Bag would not expand implying no suction. Motor ran and brushes turned. Easy disassembly using common tools found that a plastic bag had been sucked up and caused a blockage prior to the impeller. Cleaned up, reassembled, and everything worked fine after that.
Posted on Nov 06, 2009
Hi I have an Oreck lw100 magnesium SP and it turns on for a second and then turns right off what do you think that could be thank you
It can be something stuck in roller or fan housing and it is turning off to protect the motor.
Jul 24, 2016 | Oreck Vacuums
When i press the wreck magnesium power button the unit starts but turns off after ten seconds. What the problem as the light continues to flash.
Robert,
You could have a couple of problems. 1, you could have a broken belt, 2, you could have a bad sensor, or 3, you could have a bad pc board. The Magnesium has a sensor that detects whether or not the brush is turning. A quick way to check would be turn the vacuum over and turn it on, if the brush does not turn in those 10 seconds, you have a broken belt. If it does turn, I would suggest taking it to an Oreck repair store because it may still be under warranty and the sensor or pc board may still be covered under warranty. Hope this helps!
Mar 02, 2015 | Oreck Magnesium Upright Vacuum
How do I reset my oreck vacuum cleaner
If you are talking about the Oreck Magnesium vacuum, press the start button and hold it for about 15 seconds. Beyond that, most Oreck vacuums do not have any reset buttons.
Aug 06, 2014 | Oreck Vacuums
How to more easily vacum plush carpet with oreck XL vacum
The only Oreck vacuum cleaners that are rated for plush carpets are the two Magnesium models.
Jun 25, 2014 | Oreck XL Ultra Bagged Upright Vacuum
How do you change the battery in an oreck magnesium vacuum cleaner
At the back of the handle is the battery compartment, There is a simple turn knob to take the cap off to get to the battery. It takes a 2032 button battery. Hope this helps!
May 03, 2014 | Oreck Magnesium Upright Vacuum
Oreck magnesium won't turn on
Could be that you need a new battery in the handle. It takes a 2032 button type battery.
Apr 20, 2014 | Oreck Magnesium Upright Vacuum
Oreck magnesium keeps shutting off
Need to check your brush roller to see if it is spinning. Turn the vacuum over and turn it on. If the brush spins before it shuts off, you may need to check the bearings to see if any strings or hair has built up around the brush bearing shafts and is causing the brush to spin slower. If the brush does not spin, you have a broken belt and you will need to replace it. The Magnesium has a sensor that looks for the brush to spin at a certain speed and if it does not, it will shut down. Hope this helps!
Apr 12, 2014 | Oreck Vacuums
My oreck vacuum has stopped sucking up things.
It won't turn the brush because the belt is stretched or broke from the heat of sucking something too big up. If you have your service manual it should show you the location of the belt covers to replace it.
Dec 03, 2009 | Montgomery Ward Oreck XL Celoc...
Nov 05, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Vacuums Logo
203 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
