Question about Garden
Fitted new head gasket
I need the Rocker shaft torque settings for my John Deere 2030 Tractor
  • Garden Master
  • 2,475 Answers
They are head bolts most of the time. 110 ft. lbs
Posted on Dec 26, 2013
4 Suggested Answers
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
No valve movement on 320 John Deere lawn tractor.
the jd 320 lawn tractor is fitted with a 2 cylinder water cooled vertical shaft Kawasaki engine
parts numbered -j59051 and , I 59051 show it as a gear driven cam shaft
I would be looking for the rocker arm bolts loose /stripped, bent push rods or the key or the key that drives the crank gear has sheared
May 02, 2017 | Cars & Trucks
What is the torque on the front axle nut on a John Deere 3215b fairway mower
You should consult a John Deere mechanic then but a repair manual for your equipment.
Sep 20, 2014 | John Deere 420,1020,2010,2020,2510,2520...
What makes 2030 diesel engine fire
injector pump right behind the alternator shaft driven off the front crankshaft ? why?
Nov 11, 2013 | John Deere Tractor Side Screen...
We have a 3020 john deere gas we just had head redone new head gasket put back together and only getting oil to half the rocker arms. Took rocker arm assy back off and made sure holes were clear put back...
You might go ahead and put a manual oil gauge in place of your oil sending unit..back side of eng block r/h side.. check you pressure,needs to be between 15 to 25 psi at low ideal,with the eng at at operating temp.The head oils from the back main to the back camshaft bearing to a port at the R/H back part of the eng block to the head.Go ahead and pour some oil on the rocker arm assemble and let the tractor run a bit work it up to high ideal.If it doesnts oil possible problem with the head gasket being ported wrong are back cam bearing,
May 14, 2010 | John Deere 3010,3020 Tractor Basic...
I have diesel in my oil on my 2030 john deere tractor
it can be one of three problems fuel pump leaking injectoin pump or a injector over fueling
Apr 03, 2010 | John Deere Tractor Side Screen...
We have a 3020 john deere gas we just had head redone new head gasket put back together and only getting oil to half the rocker arms. took rocker arm assy back off and made sure holes were clear put back...
A couple of things should be looked at.
1. Make sure head gasket is aligned properly and not blocking any ports on the head or block. 2. When the head was milled debris may have been pushed into a port blocking flow, check for blockage. 3. When you replaced the head, did you torque the bolts in the proper sequence and to the specified ft/lbs?
Mar 26, 2010 | John Deere 3010,3020 Tractor Basic...
Torque spec on a 425 john deere head
Initial torque-115 inch pounds,final torque-186 inch pounds.Intake manifold is 53 inch pounds on all 8 screws.Valves set at 0.010 on all 4.If you go with the new style valve cover gasket {the flat one} be sure to leave the old o-ring in valve cover to keep the new gasket from splitting.
Feb 09, 2010 | John Deere 420,1020,2010,2020,2510,2520...
1974 John Deere 2030 diesel tractor and the engine dies
I will assume you have bled the fuel system per the owners manual to ensure no air lock in your system. This is especially critical after replacing the injector pump.
The next step is to ensure you fuel filters are good and flowing and last but probably the problem is the screen on the petcock (fuel shut off) in the fuel tank. Remove this shutoff valve and clean the screen with a fine wire brush and carburetor cleaner.
Nov 16, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Hello, does anybody know the torque setting for the head bolts ona v-twin yanmar desiel engine fitted in a john deere 355. Cheers
I found the tech manual one lin but it can"t be opened since deere is updating it.I will see if we have the book"tm1974" at the dealership in the morning and get back to you.
Oct 28, 2009 | John Deere 4020 Gas & Diesel Tractor...
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
