Question about Sanyo Heating & Cooling
BTU OF SAP-K123GJL - Sanyo Heating & Cooling
Can't get it out of SAP mode. tried two different remotes. TV doesn't respond.
1. If you're watching TV via a Cable or Satellite box , then the SAP (Secondary Audio Programming) is activated in the box, not the TV. Check with your TV service provider how to activate/deactivate SAP in their box.
2. Only if you're using the TV's own built-in tuner to watch TV (you're changing channels by using the Panasonic remote for CH up/down), then press the SAP button on the Panasonic TV remote to cycle through the SAP options.
Mar 15, 2016 | Panasonic Viera TH-50PX80U Plasma TV
What is the capacity of this model no. sap-306
the capacity of the system is on the plate /decal located on the inside section on the end or on the outside section near where the pipes are fitted.
It will be either a btu rating or a kw rating
Jun 17, 2015 | Sanyo Split System Air Conditioner
My printer is intermec PF8T i have i SAP program to print patient information but it cannot print the error is orange ligths was the error.
There are a few things to figure out here from a SAP basis administrator perspective these steps are common. Also I am just trying to help and with SAP there could be multiple solutions. Good luck.
Check SAP MarketPlace for SAP note: 1557674
Here are the steps taken from the SAP Community Network which might help. I would suggest reading the entire link as its informative. http://scn.sap.com/thread/1975158
Step:
run SPAD
to create an output device, choose Output Devices on the Devices/Server Tab
click on Display now you will be in Spool Administration window
click on Change button then Create tab will be appear, now you have to put the following information.
Under DeviceAttributees
put the Output Device name with shortname
Device Type: SAPWIN
Device class: Standards printer
you can put Model/Location/Message as per concern.
Under Access Method
Access Method: G
Host Printer: __default
save
for more information about
Device Type
http://help.sap.com/saphelp_nwmobile711/helpdata/en/d9/4a910f51ea11d189570000e829fbbd/content.htm
Access Method
http://help.sap.com/saphelp_nw70/helpdata/en/4f/9c033cff903105e10000000a114084/content.htm
(1) Choose "S: Print Using SAP Protocol" if a print server with SAPlpd or SAPsprint is used to print barcodes.
(2) Choose "F: Printing on Frontend Computer" if SAPlpd and SAP GUI are used together to print barcodes, SAP GUI sends print job to SAPlpd, SAPlpd is started automatically and forwards the print data stream to the Windows print manager.
(3) Choose "G: Frontend Printing with Control Tech", only SAP GUI is involved in printing barcodes, SAPlpd is not used.
Here are the Intermec drivers:
http://www.intermec.com/support/downloads/index.aspx
Understanding the LED Indicators
LED Meaning
Green (blinking) Auto-Sensing mode
Green (blinking) Downloading font, form, or graphic
Green (solid) Dump mode
Green (solid) Ready mode
Green (solid) Print mode
Orange (solid) Boot mode
Red (blinking) Media jam, overheated print head or stepper
motor
Red (blinking) Downloading firmware
Red (solid) Error mode
Good luck
Dec 27, 2013 | Intermec Office Equipment & Supplies
How to I disable the SAP function on RCA FLAT 19 INCH screen?
Hello
From its main Menu, surf towards its sound Menu.
By using UP/DOWN buttons of the remote handset, select SAP
SAP (Second Audio Program) (for analog channels only) Plays the
program's audio in a second language, if one is available. The TV displays
the word SAP in the channel banner when you tune to a program that is
broadcast with SAP information. SAP audio is broadcast in mono. SAP is also
used to broadcast a program's audio with descriptions of the video for the
visually impaired. Press the right arrow button to turn SAP on or off.
OK.
Sep 22, 2011 | RCA TruFlat 27F520T 27" TV
I think that my TV soney braiva xbr has an issue with SAP but some ch. are in spanish some do not have sound How do i reset this tv?
Press MTS/SAP on the remote (under the number buttons) to go between the 3 options of STEREO or MONO or AUTO SAP. Not all channels will have SAP (secondary audio program). Selecting stereo should eliminate any secondary audio.
Mar 24, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
How do I use the sap function
SAP button,function button is a dupping to audio to spanish langauge for a show.The SAP function only work,if the beginning of the tv show,have SAP logo,when the show begin.
Sep 17, 2010 | Samsung LN37A530 37 in. LCD HDTV
No sound on two stations
the best thing to do fine tune manualy
Sep 05, 2007 | Sansui DTV2760 27" TV
Heating & Cooling Logo
63 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
