Question about HP Compaq nx6115 Notebook
Can't read hard disk - HP Compaq nx6115 Notebook
My WD My Passport external Hard Drive ! TB formatted for Mac is not reading my files
A Windows PC computer will not read files on the WD hard drive that has been formatted on a MAC.
The fix.
Copy your photos onto the MAC computer then remove the WD hard drive and connect it to your Windows PC and format the WD hard drive in FAT32 file system.
After formatting has been completed remove the WD hard disk and connect it to the MAC computer. The MAC can read and write to a Windows FAT32 formated hard disk. You can now copy the photos from the MAC to the WD hard disk. When copying is complete, remove the WD hard drive and connect the WD hard drive to your Windows PC and you can now copy the photo from the WD hard disk to your Windows PC.
Mar 05, 2012 | Western Digital Passport WDXML800UE...
Why is my hard disk drive indicator light always blinking on my Sony Vaio Laptop? My laptop reads cds and dvds fine, it is just annoying to always see it blinking.
This is perfectly normal. Your hard-disk indicator light is always blinking because your hard-disk is constantly being used by the operating system. Windows and other applications are performing operations in the background which require both reading from and writing to the hard-disk regardless of whether you are doing anything or not.
You only need to worry when the hard-disk light STOPS blinking . . . permanently!
Nov 03, 2010 | Computers & Internet
Will not read any disks except for store bought ones ???
Did you mean hard disk? If so, make sure you buy the right hard disk, there are something different between IDE and EIDE hard disk although their interface look similiar. Go to BIOS to auto detect the HDD if available. The jumper settings on the hard disk can not both set to be master if they are on the same ribbon of IDE interface. If BIOS recognize the hard disk and not reading, there might be something wrong with the disk. Try it on another computer or do some scan on it. It is an option to call Dell and ask them whether they have some hard code of their machine so the machine only read disk with some hidden information too just in case. If the disk is not a hard disk, then there could be standards issue of media too. You can check the specification of your machine and see the detailed version of the interface and see whether you have the same version of standards on your disk.
Aug 23, 2010 | Dell Dimension 4700C PC Desktop
It wont read the disks i put in
your cd drive reads disk, it probably is bad
u should look up hard drives on wikiapedia
May 27, 2010 | HP (PV944A) 160 GB Hard Drive
My acer 7520 opens with an error reading NVIDIA boot agent 249.0542, then reads PXE-E61 media test failure, check cable, PXE-M0F exiting NVIDIA boot agent.
This error message could be a faulty hard disk or a faulty disk controller.
Reseat the hard disk to see if the problem is fixed.
If not go into the BIOS settings and check if the BIOS can detect the hard disk.
If the hard disk is not detected then remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If the this computer cannot detect it as an external hard drive then the hard drive is faulty. Then the Acer needs a replacement hard disk and Windows installed together with the laptop's device drivers and programs etc.
Oct 20, 2009 | Aspire Acer 7520-5324 Laptop
Disk read error alt+ctrl del restart
load optimal or fail save setting then check if it eliminates the problem if it didn't work. reinstall the ide cable of your hard disk check if it eliminates the problem if it also didn't work back up your hard drive for important file, delete and create hard disk file system, partition and reformat your hard drive if this also didnt work replace your hard disk.
Sep 14, 2009 | Microsoft Windows® XP Professional Full...
External hard drive can not be read by the computer
The hard drive was originally formatted for a PC and I was using it with Mac products. I had to delete all the information on the hard drive so that I could reformat the external hard drive to work with my Macbook Pro.
Dec 08, 2008 | Seagate (9W2041-337) 40 GB Hard Drive
Samsung 40 GB Spin Point Hard Drive problem
try to use some Hard drive recovery programes or try Paragon partition manager.
Sep 29, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Hard disk is read only
format your hard disk with disk manager software. (low level for formating). this software can remove bad sector of your hard disk
Oct 10, 2007 | Computers & Internet
HP Compaq nx6115 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
