Question about HP Office Equipment & Supplies
Hp printer c4680 carriage moves both ways then sticks on right
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 22 Answers
Try putting a wet rag against the side and wipe it off. Could be just something like a drink.
Posted on Dec 25, 2013
4 Suggested Answers
SOURCE: Carriage jam on HP C4680
Have you checked to see if you have a paper jam in the back entrance of your printer. Make sure there are no pecies of paper jamed on the roller.
Posted on Jan 21, 2011
SOURCE: HP Vivera printer won't print
I had a paper jam from a label coming off while it was printing. I was able to
clear the lable out by taking the pack panel off. Now the printer makes all the noises it should, but doesn't pull any paper threw. Help
Posted on Dec 10, 2011
Fix carriage jam
Unplug the printer.
Move the carriage to the center of the printer.
Wait at least 3 minutes.
Plug printer back in.
Dec 25, 2013 | HP C4680 All-In-One Inkjet Printer
The print cartridge carriage is stalled on HP PSC 1610 All-in-one Printer. Carriage won't go all the way to the right because of a small toggle pin.
If you are tec guy. Open flat bed assm.. check the movement of carriage assm manually, see the obstruction, check service station.ensure that carriage should move freely..close it & check...
Sep 10, 2011 | HP PSC 1610 All-In-One InkJet Printer
My C4680 ink cartridge thing is stuck to the extreme right. I can't budge it and the animated pictures are not helping. I don't have the manual to help me out. I pulled out the spent black one...
Hi, the description of your problem is little confusing. Did you mean you've already moved back the carriage to the center of is it still stuck to the extreme right? What if you turn it Off and turn back On again? Please let me know with more details so that I can assist you better. Thanks.
Jun 28, 2011 | HP Office Equipment & Supplies
My HP C5280 Printer has an error message "carriage stall". None of the suggestions made on the website have worked. Seems to be in a continuous loop. How can I get a hardware reset or local...
A carriage stall either means the carriage cannot move, or the printer THINKS the carriage isn't moving.
Most HP printers use a calibration strip to tell where the carriage is, and if that breaks, there's nothing you can do about the carriage stall message, the unit has to be serviced or replaced!
Here's a quick test though.disconnect the power from the unit. Reconnect the power, and while the whirring and so forth is going on, disconnect the power again.
See if you can move the carriage (the part with the printheads) all the way left, and all the way right.
if it sticks, find out what's obstructing it, because that's the problem.
If you CAN move it all the way left and right, chances are that calibration strip is broken.
Mar 19, 2011 | HP Office Equipment & Supplies
Carriage jam on HP C4680 printer after putting in new ink cartridges
Jan 20, 2011 | HP C4680 All-In-One Inkjet Printer
The carriage that holds the cartridges is stuck and when I open the front panel it wont move to the center as usual. I cannot print anything obviously
I have the same printer. Underneath the home position is a rubber "wiper" that cleans the underside of the cartridges. Ink buildups get dried out and can cause the carriage to stick. You may be able to " help" the carriage out of home position by GENTLY using the belt that runs from left to right to move the carriage to the left. U nderneath where the carriage previous sat you will see 2 rubber objects. Carefully wipe off any dried up ink. This is a messy job ! Good luck.
Dec 16, 2010 | HP DeskJet 845c Printer
HP Pro 8500 printer has carriage jam. I have opened every door and there is no paper jam.
Sometimes the paper gets caught inside the printer all the way to the right (or left) of the print carriage. You will miss seeing it because the print carriage has moved the jamed paper to the right (or left) out of view. Carefully and manually move the print carriage to the opposite side and you might find small pieces of jammed paper there.
Jul 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
How to remove the cartridge from hp photo smart 7960
Hello the manual way to release cartridge is
  1. Disconnect the power cord from the printer.
  2. Open the top cover.
  3. Look for the gray-colored carriage on the right side of the printer.
  4. Find the horizontal (bottom) edge of the carriage and follow it towards the back (or in) until it makes a 90-degree turn. Follow it down to the ¼ inch-high, black-colored capping station.
  5. Using a screwdriver or similar tool, push the capping station toward the back of the printer.
    NOTE: Do not pull on the ribbon cable when moving the carriage.
  6. Making sure to not push up on the carriage, move the carriage to the middle of the printer. If the carriage is still locked in place, push the capping station farther into the printer and try moving the carriage again.
  7. After the carriage is pulled out from the right-hand side of the printer, remove both print cartridges and store them according to specifications.
  8. Close the top cover.
Sep 03, 2009 | HP PhotoSmart 7960 InkJet Printer
When I turn on the power to the printer, the print carriage cycles to the right as normal then carriage sticks and begins to continually chatter.....at the same time the light bar on the scanner trys to...
There is usually a sensor on one side or the other of the carriage. When you power up the machine, the carriage will be moved to that end, setting off the sensor. Then it will move back and forth to test carriage motion. If the end sensor is faulty, the carriage will still attempt to move until it triggers the sensor, but when it gets to the extreme end, the motor will continue to attempt to move it, causing the chatter. After a time, it will stop with an error message.
Look at the carriage where the cartridges are, and you should see some kind of tab or ear on it. If it's broken, then you may get the symptoms I mentioned above. Also if you can see the sensor, make sure that it's not broken or moved out of place.
Mar 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How to change black ink cartridge of HP Deskjet 6980
Lift the cover up.
The ink jet carriage should park in the center of the carriage.
Gently lift on the front of the ink jet until it removes. Some you have to lift up and some you have to lift down on. Just be careful.
HP inkjet cartridges tell you on the front of the stick by a dot weather it is tri color or black.
Jun 13, 2008 | HP Deskjet 6980 InkJet Photo Printer
21 people viewed this question
Seeker5211
Seeker5211
