Question about Sansui HDLCD3210 32 in. LCD TV
Digital tv suddenly no signal
The set is just over a year old, have never had any problems. Signal strength has always been good, picture quality great. Two days ago I watched it til late, no problems but when I turned it on the next evening all I got was a black screen with a blue square containing a message 'no signal'. We've unplugged all cables and leads, checked all fittings and re connected them all. Still the same message. We have an outside Ariel which appears to be fine. There hasn't been any strong winds etc... Help!
    New Friend:
Might have been a power spike that flashed channel memory. try rescanning for channels. And make sure physically that you antennas wiring is good and anywhere on it. post what you find good luck...
Posted on Dec 25, 2013
  • Kevin Tennyson
    Kevin Tennyson Dec 25, 2013
    oh and if you dont wanna get on roof to check you can always just barrow an antena from a neihbor or friend and eliminate that potential problem all together just a thought merry christmas
SOURCE: TV is hooked to cable; we have audio but screen is
Well then it MUST be covered by a Warranty, as you get at least 12 months manufacturers defect protection. (If it spontaneously fails, inside that period, it is assumed to be a manufacturers fault, unless external influences could be proved, IE: Lightning strike, power surge, etc)
What you need to do, is contact the place you purchased the unit from, and ask, demand? that it be REPLACED. NOT repaired, and indicate that it is unacceptable for this to occur but you do understand. You are just exercising your consumer rights,
The consumers guarantee act, allows you redress from the actual SELLER, THEY must remedy, by replacement OR repair at the CUSTOMERS discretion.
So, go and get you new, replacement set. Don't give up until you do, get a replacement.
You may find on contacting the seller that they are aghast this has happened and will ship a new one to you immediately.. well it could happen..?
If you do not get satisfaction get in touch with Sansui direct, that will get things along. Contact link below.
http://www.sansui-global.com/english/contactus.php
Posted on Oct 31, 2010
  • 8457 Answers
SOURCE: TV is connected to cable;
Return it to Amazon.com.Get a replacement tv.This tv have problems with it 1 or 2 long LCD inverter boards,it dying going to be dead.That why u have only a flashes of a picture only a few second,than died,just black screen lelf and have sound.Or talk to Amazon.com customer serviced to get ur tv a warrenty repair.
Posted on Nov 14, 2010
bugoy31
  • 1238 Answers
SOURCE: Sansui HDLCD1908B Television
call you digital cable provider
Posted on Jul 23, 2012
SD Tech
  • 14553 Answers
SOURCE: I have a 42" Plasma Sansui and just recently there are now multiple lines running through the screen. This makes it impossible to watch. I've tried the power, cords, stations, etc. Any ideas of pr
Ten years is two lifetimes for a Plasma, it most likely is either the display panel itself or a main board, in either case not cost effective to repair or smart but the real problem would be parts, I bet almost zero is available for this.
Posted on Dec 11, 2012
  • 8 Answers
SOURCE: there is no sound with black screen
depending on how much you leave your TV on, it could be that internal chips could have fried and needs a tech to replace parts for picture and audio from manufacture.
Posted on Dec 18, 2012
Antenna not working anymore?
talk with a tv technician as to the capabilities of the tv set but you may need a better outdoor antenna if the signal has changed from am to digital or fm in your viewing area
Jan 20, 2016 | Westinghouse Televison & Video
Why i can't receive dtv
It is difficult to give you an accurate answer as there are so many things involved.
If you were getting a good TV signal before digital then there is every chance the aerial you have will pull in a reasonable digital signal.
The trouble can start from there. You must have good quality quad shield coax cable all the way from the aerial to the back of the TV. Old coax cable used with analogue TV won't do it for you. Even a short length of old cable can ruin the signal.
Then, you might need a digital signal amp if the cable has been split anywhere to different rooms.
It is possible on your TV to display 2 coloured bars, one to indicate signal strength and the other signal quality. They are not graduated with numbers, but should generally be about 3/4 along minimum for a decent picture. You can therefore see what is wrong in a gross way.
See p122 here http://downloadcenter.samsung.com/content/UM/201201/20120128144251913/LX5ATSCA_LX9ATSCA_ENG_US.pdf
and
https://www.youtube.com/watch?v=JWFteLOroSw
https://www.youtube.com/watch?v=TzHgKh9Xqnw
Jul 29, 2014 | Samsung 32 LN32D450 32 LCD TV
I have a lg model 42px5d tv which will not tune to all digital channels I have been told there maybe a fix for this but not sure where to find it
Usually, with this problem, it's due to low signal strength. Digital TV needs a good quality DTV antenna. GOOD QUALITY cables and connectors are also a good idea. If you live in a low signal strength area, u may also need an amplified antenna.
Aug 02, 2011 | LG 42PX5D 42 in. Plasma HDTV
Watch tv properly with JVC DVD off
Some philips tv's have a built in aerial amplifier, perhaps if you bought a digital aerial booster it will improve the picture quality.
Apr 05, 2010 | JVC DR-MV1S DVD Recorder/VCR
LG 42LB5D-UC cannot find channels when scanning
No,Ur Digital antena not getting a good signal,because of lanscape like hills or big buildings,blocking the signal,that why u not getting good signals,or no signals at all.Buy another name brand digital antena with a stronger signal amplifier.Or buy a digital roof antena,well help or solved these problems.
Mar 20, 2010 | LG 42LB5D 42 in. LCD Television
Loss of Digital Shows??
U have cable's or dish's boxs?unplug,replug the box for the software to down load to upgrade.Unplug,replug the tv.Go to the menu set for Air or Cable then rescan all channels
Oct 26, 2009 | iLO V27DMBX Television
Tv set just lost its ability to display digital channels
Your problem is definitely the input signal source to your tv. It is extremely rare where a new tv has a tuner signal sensitivity problem. The best thing to do is to replace your current set of rabbit ears with a different set of powered rabbit ears that have a higher gain rating with a variable gain control. Please note that the gain control setting is critical when setting up your tuner for auto-programming. If the gain control is set too low or too high it will result in your symptom.
If you still can't get it to work you could try buying a line amplifier which you would install to the rabbit ears before the tv. If you still can't get it to work you'll have no choice but to purchase an outside antennae as a result of your being in a weak signal area as signal quality changes by such things as the switch over to digital upcoming and environmental changes.
Apr 27, 2009 | Televison & Video
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Qualia and Sony XBR 4 TV
wow. mostly all new set from the last few years have a dual tuners
NTSC and ATSC and that would depend if or which set will get the better signal. Also remember that off air is analog and the sets are now design for digital.
Feb 09, 2008 | Sony QUALIA 005 46 in. LCD Television
Sansui HDLCD3210 32 in. LCD TV Logo
473 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
