Question about HP C4680 All-In-One Inkjet Printer
Fix carriage jam
Carriage moves both ways and sticks on right
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 544 Answers
Unplug the printer.
Move the carriage to the center of the printer.
Wait at least 3 minutes.
Plug printer back in.
Posted on Dec 31, 2013
4 Suggested Answers
SOURCE: Carriage jam
There's a small locking mechanism that holds the carriage in it's home position. This needs to be slightly sprayed with WD-40 or a similar lubrication (small amount). Problem solved.
Posted on Dec 30, 2008
komguy
  • 2306 Answers
SOURCE: carriage jam
Sorry about the B.S., you can move the carriage by hand, and all you need is to clean the encoder strip that runs across behind the carriage assembly. You can wipe the strip gently with an alcohol swab or a Q-tip moist with alcohol. The bars on that strip tell the carriage where it is and grease or ink on it will give the carriage jam error. No calibration necessary after moving the head or cleaning the strip.
Posted on Jan 15, 2010
I have a Hermes 3000 typewriter. Once I set the left margin, it's not sitting there. It moves fast to the right margin. I am not able to type a single word because of this. Is the mainspring is bad? ...
The mainspring is not bad or the carriage would not move that way. It sounds like and escapement problem either from the carriage release sticking, the escapement itself needing adj. which you probably cannot do, the escapement rack is bent or maladjusted, or the tab function is sticking or maladjusted. Check the carriage release levers to see if they are sticking. Also make sure the tab function is knocking off so the carriage is not in constant tab mode. Hope this helps.
Oct 07, 2013 | Royal Office Equipment & Supplies
The error 6A81 comes up on the sml screen of my canon PIXMA MG5150 It suggests to turn it off and on again which I've done but the same error comes up????
This is a purge unit error. There maybe something jamming the purge unit or just a absorber out of place which is picking up on the carriage preventing it from moving correctly. if you can move the carriage away from the purge (its where the printhead/carriage parks its self on the right side of the machine) with no resistance then you can shine a torch into the machine and look at the purge unit. there maybe crumpled paper jammed in the purge. If all looks well then the purge may need replacing. Lastly the wiper on the purge may have stuck. It slides back and forth and they have been known to stick. just push it with a long screwdriver to see it it moves.
Good luck
Jun 04, 2011 | Canon MG5150 AllInOne Printer
HP Pro 8500 printer has carriage jam. I have opened every door and there is no paper jam.
Sometimes the paper gets caught inside the printer all the way to the right (or left) of the print carriage. You will miss seeing it because the print carriage has moved the jamed paper to the right (or left) out of view. Carefully and manually move the print carriage to the opposite side and you might find small pieces of jammed paper there.
Jul 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP 2500CM displays mech carriage jam 415 msg after power on. There is no jam, encoder strip replaced, PCA connectors and ribbon cable okay.
Is the carriage rail clean, and lightly lubricated?
Cheat the door switch and observe the carriage moving at boot up.
(Keep your fingers out of the way!)
See if you can spot where it sticks.
Sometimes the printhead capping unit / service station seizes up, and the carriage cannot leave / return to the home position.
This model was not one of their best.... Good luck
Dec 09, 2009 | HP 2500 CM InkJet Printer
Cartridge Jam
hi
i assume you have got the correct cartridge for this model of printer.
i also assume that you have correctly synchronized the cartridge heat to its coupling structure in the printer.
if you have fixed it correctly and it still sticks out, the cartridge could be defective, in which case try and replace the cartridge from the vendor.
cheers
Jul 26, 2009 | HP Officejet 5610 All-In-One InkJet...
Carriage jam on hp photosmart printer
The print carriage may get stuck on either side or in the middle of the printer. The Carriage Jam: Open Door, clear carriage jam, and then press OK to continue error message may display on the front panel of the all-in-one.
Solution
The print carriage is the device which contains the print head and moves left to right during printing.
Figure 1: Carriage Assembly
To resolve this issue, follow the steps below in the order presented.
Step one: Print a Self Test
Follow the steps below:
1. Press the Setup button.
2. Select Print Report and press OK .
3. The self-test page should print. If it prints a test page, there is no need to follow the remaining steps, as the error message may be false. Make sure the printer now prints from the computer (if installed on one). If it does not print, proceed to the step two.
Step two: Clear the paper path
Follow the steps below to clear the printer of any jammed paper and reset the printer.
1. Leave the printer on and then disconnect the power cable and the USB or Ethernet cable from the back of the printer. Do not reconnect them until instructed to later.
NOTE: Make sure the printer is on before disconnecting the power cord. Failure to disconnect the power cord from the rear of the unit can cause damage when removing jammed paper.
2. Open the top access door.
Figure 2: Opening the top access door
3. Make note of where the carriage is stuck and look for jammed paper. A paper jam can cause the error message and the carriage stall. Some paper may be jammed in different locations than those shown in the photos below.
Figure 3: Paper jammed on the left side
Figure 4: Top view of paper jammed on the left side
Figure 5: Paper jammed on the right side
Figure 6: Top view of paper jammed on the right side
NOTE: Do not use any tools or other devices to remove jammed paper. Always use caution when removing jammed paper from inside the unit.
If the carriage is stuck on the right side:
a. Check for any paper or object that may be restricting the carriage.
b. Move carriage all the way to the left side.
c. Check the paper path all the way to the right side and remove any paper still in the printer.
If the carriage is stuck on the left side:
d. Check for any paper or object that may be restricting the carriage.
e. Move carriage all the way to the right side.
f. Check the paper path all the way to the left side and remove any paper still in the printer.
If the carriage is stuck in the middle:
g. Check for any paper or object that may be restricting the carriage.
h. Move carriage all the way to the left side.
i. Check the paper path all the way to the right side and remove any paper still in the printer.
j. Move carriage all the way to the right side.
k. Check the paper path all the way to the left side and remove any paper still in the printer.
4. Remove the rear access door or duplexer (if installed) from the back of the printer.
5. Check for and remove any paper still in the printer.
6. Replace the rear access door, and close the top access door.
7. Reconnect only the power cable. If the printer does not automatically turn on, press the Power button.
NOTE: The printer may go through a warm-up period of up to two minutes. Lights may flash and the carriage may move. Wait until this warm-up period is complete before going to the next step.
8. If the Power light is on steady, print a self-test page as done in Step one.
If the Power light is not on steady and the carriage is still in a stalled position, proceed to the next step.
Step three: Plug the printer directly into a wall outlet
Verify that the printer is properly connected to a suitable power source by following the instructions below.
1. Verify that the computer and the printer have a three-prong power plug.
2. Remove the printer cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
3. Try the print job again to see if this step resolved the issue.
NOTE: If the printer prints when plugged directly into a wall outlet while disconnected from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
4. If this did not resolve the issue, proceed to the next step.
Step four: Service the product
If you have completed all of the steps listed above and are still experiencing a problem, service your product.hope this helps
Jan 05, 2009 | HP Office Equipment & Supplies
Carriage cradle stuck on right side!
Carriage system is broken. Uneconomical to repair. Sorry
Dec 27, 2008 | HP Officejet 5610 All-In-One InkJet...
My printer have carriage jam
try to move the carriage manually left and right...will fix the issue.
Nov 24, 2008 | HP Office Equipment & Supplies
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP C4680 All-In-One Inkjet Printer Logo
63 people viewed this question
Seeker5211
Seeker5211
