Question about DeLonghi EO1258 - Stainless Steel Toaster Oven with Convection Cooking
Delonghi toaster oven won't turn off - DeLonghi EO1258 - Stainless Steel Toaster Oven with Convection Cooking
SOURCE: My delonghi toaster oven knobs broke! as
try this site. I ordered two yesterday. cheapest i found, shipping cost more than parts.
http://www.delonghi-accessories.com/
Posted on Jun 25, 2009
SOURCE: Delonghi AS690 toaster oven lower element won't turn on.
Cactus Bob Is WRONG. I've had these replaced; and then, when it happened subsequently, bought the part and replaced it myself. You have to take the entire thing apart. but it can be done.
Posted on Nov 14, 2009
grbullets2
  • 53 Answers
SOURCE: Dead Delonghi toaster oven
Your timer switch burned out. The timer is manual and will tick even unplugged. Delonghi switches are available at The Gourmet Depot website or search "small appliance parts" for other places that sell the switches.
Posted on May 20, 2010
toolkits
  • 1099 Answers
SOURCE: how to change the lower element on a delonghi AD
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Posted on Jul 07, 2010
    SOURCE: How do you set the clock on the delonghi DO400
    1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
    2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
    3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
    4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
    5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
    • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
    • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
    Posted on Feb 24, 2011
    Delonghi xr640 toasting-finished chime not working
    follow this steps and fix it. God bless you
    f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
    If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
    Location of the typical toaster oven's thermal fuse.
    If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
    Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
    How do you set the delonghi convection toaster oven to cook chicken nuggetts?
    Try this:
    Thermostat knob - Toast/ broil
    Time - 18 minutes
    Wire Rack Position - Upper
    Turn after 10 minutes.
    For other recipe programs, you can download owner's manual at http://www.delonghiusa.com
    Regards.
    Jun 16, 2011 | DeLonghi EO1251 Toaster Oven with...
    What does the asterik with the tear drop on the middle control mean on DeLonghi AR690 Retro Toaster Oven?
    Here is contact info for DeLonghi if no one else can answer you.
    EMAIL
    Our consumer service representatives strive to respond to all e-mail inquiries within 24 hours of receipt. help@delonghi-csservice.com PHONE
    To speak directly with a consumer service representative, please call 1-866-Latte- Best (1-866-528-8323). Representatives are available 8:30 am - 5:00 pm (EST) Monday through Friday.
    <a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
    Feb 18, 2011 | DeLonghi AR690 Retro 1500 Watts Toaster...
    How to clean the inside walls of a delonghi alfredo toaster oven?
    pour water in the pan with little detergent for dish,and heat it on 30 deg Celsius for about 30-50 minute,and wipe the walls with cotton rag.
    Jun 29, 2009 | DeLonghi XU620 Alfredo Ultima Bake 'N'...
    Hi, you can purchase them on amazon. Here: Amazon com delonghi knobs. I think this was helpful, Have a nice day
    Jun 12, 2009 | DeLonghi EO1260 1400 Watts Toaster Oven...
    Mar 23, 2009 | DeLonghi EO1258 - Stainless Steel Toaster...
    Mar 13, 2009 | DeLonghi AS690 Airstream Stainless Steel...
    Toaster/oven
    Could be the timer switch. They will suddenly stop working all at once or work intermittantly. Unless it's a Delonghi you may have a very hard time finding the part you need. If the switch is a DKJ/1-60 you will not find one but there is a Delonghi switch that you can use which you can find at www.thegourmetdepotco.com or www.applianceparts.com . The Delonghi part # is 5218104600 to replace a DKJ/1-60
    Mar 05, 2008 | DeLonghi EO1258 - Stainless Steel Toaster...
    DeLonghi EO1258 - Stainless Steel Toaster Oven with Convection Cooking Logo
    85 people viewed this question
    Top DeLonghi Toaster Ovens Experts
    Dave
    Dave
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you a DeLonghi Toaster Oven Expert? Answer questions, earn points and help others
