Question about Symbol LS 4278 Barcode Scanner
Enter function Hi I have programmed the scanner to add the enter function after the barcode is scanned. Is there any way to program another enter after that one? eg: we scan the barcode, the barcode is entered in the box and the enter function sends it to the next window ( this is where we need the next enter ) so it will then finish the entry and we can scan another barcode without having to run back and forth to the keyboard as we could be several meters away. regards Lee Jordan
  • 3 more comments
  • JordanL Oct 17, 2007
    thanks i will try this.
    regards
    lee
  • Anonymous Mar 17, 2014
    remove enter from the barcode scanner
  • Anonymous Mar 18, 2014
    I have two scanners. One worked fine until I tried to turn off the enter option, now it adds }w before every barcode. The second just beeps four times with a red light which stays on. I got it to work at one point, but it had the }w before barcodes. Now it just beeps with a red light again. I have tried defaulting both multiple times, and I even downloaded symbols program which doesn't even recognize the scanner. They are so out of date that the support center basically wished me the best of luck. I have run out of ideas.
  • Anonymous Mar 26, 2014
    will scan but need it to automatically press enter after each scan
  • Anonymous Mar 31, 2014
    I have tried scanning probably all of the programming menu to try and fix this problem but nothing seems to be working for me, i have also tried looking online for similar articles regarding this problem but don't see any. hope that you could help me.
Hi Lee,
It can be done by programming the scanning the 'Send Enter Key' barcode twice, from the owners manual.
eg
Scan the barcodes -
Send All Data, Send Enter Key, Send Enter Key, Save
Posted on Oct 17, 2007
  • Mohsin Bhatti Jun 23, 2013
    How can I make my Barcode scanner automatically press (Enter) after each scan?
When i scan a barcode why do i have to push enter?
Scan these three barcodes from the LS2208 Product Reference Guide:
Scan Options
Data Suffix
Enter
The scanner will then be programmed to send an enter after every barcode you scan.
https://atgsupportcentral.motorolasolutions.com/content/emb/docs/manuals/5880809a.pdf
Aug 11, 2014 | Symbol LS 4278 Barcode Scanner
How do i send a string of actions after scanning one barcode on symbol ls2208
You will have many issues doing this, the best way is to create a barcode with all this info in it.
Its normal to have 1 or 2 post amble events but not that many.
Mar 08, 2013 | Computers & Internet
Have an online manual for LS4004 I000. How do I get the scanner to transmit an enter key after scanning a barcode?
try reprogrammimg, it should default after it scans an item to enter whaT WAS SCANNED
Jan 31, 2013 | Computers & Internet
After scanning it is automatically not going to the next line
Symbol barcode scanners by default do not add a return after a scan. You need to program the scanner to add a suffix.
Download the manual from Motorola/Symbol here
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf&sliceId=&dialogID=219596399&stateId=1%200%20219598121
-Print Pages 224 and 225
-Scan the Barcode "Scan Options"
-Scan the Barcode " "
-Scan the Barcode "Enter"
Scan a barcode
Feb 26, 2011 | Symbol LS2208 Handheld
Need to have a barcode that when scanned will simulate an enter
There is not a barcode to simulate the enter key. You have to program the scanner to add the C/R (carriage return) to the end of the data that it sends. This is just a simple programming step. The users guide that came with the scanner will have a section in it with barcodes to scan to program the unit to perform differently. Each model scanner is a little different but the process is about the same. Enter programming mode, scan the C/R barcode, exit programming mode. Now when you scan the barcode the scanner will automatically add the "enter" for you.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 15, 2010 | Symbol MC3090 Wireless Barcode Scanner
How do I get my scanner to go to the next line/box when using Excel?
In your programming manual there is a barcode scan that needs to be scanned in that adds the carriage return function. To do this you will first need to scan the barcode to put the unit into program mode, then scan the carriage return barcode, then scan the end programming code. Now when you scan a barcode the scanner will add the return to the sequence it sends to the computer. If you can't find your programming book you can download the sheets from the Symbol web site.
Buddy
Corporate Computer
www.ccl-la.com
Apr 14, 2010 | Symbol LS2208 Handheld
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
I want to my m2004 to enter barcode scan after each scan automati
Print Adobe pages 128 and 129 of 302 of the M2000 Series Product Reference Guide and scan the "Scan Options" "Data Suffix" and "Enter" barcodes. The scanner will give two beeps after the first barcode, two beeps after the second and a warble after the third programming (Enter) barcode.
The manual can be downloaded from this link: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3969605apdf&sliceId=&dialogID=114420706&stateId=1%200%20114410949
Jul 12, 2009 | Symbol M2004 Barcode Scanner
Transfer info from the digital weight scaleto quickbooks
You would need to add an criteria or the rule, like barcode length or type. Than is the the scanner able to understand which barcode should be handled by the specific rule.
Dec 03, 2008 | Symbol LS2208 Handheld
Problem with scanner
Yeah, from the manual, scan the following settings:
Scan Suffix
7
0
0
9
Scan Options
<DATA> <SUFFIX>
Enter
It's best to copy the necessary barcodes from the manual at 200% zoom, into a Word document and print it out.
Feb 07, 2007 | Wasp WWS800 Handheld
Symbol LS 4278 Barcode Scanner Logo
3,159 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
