Oracle 10g Database Standard
Font problem in oracle 10g
By Phoebe - usenet poster
hi i am using window xp 2004 and oracle 8i client (in my client machine)
.... i have designed an interface using vfp that connect to oracle 10g
database server in other machine......
now my problem is when i insert some character like ?? using designed
interface.. it insert some other character that is ?? intead of ??
this......... from my client side.
but when i use my server (install same window xp) there is no problem and
the records are retrived as it is......  at least i know that it is not the
oracle 10g problem.......
is this a problem of oracle client 8.1.6.0.0? can anybody tell me why is
that so....
Message posted via DBMonster.com
http://www.dbmonster.com/Uwe/F orums.aspx/oracle/200505/1
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Sep 21, 2007
FixYa! (100)
askanything
Rank:Wiz Wiz
Rating: 84%, 230 votes
Oracle 8i will not be supported for xp 2004.
You need to install XP sp2 for it.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on font problem in oracle 10g:
I don't want to Accept this solution
Best Solution
posted on Aug 09, 2005
FixYa! (100)
Beresford
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Who is Alison?
Thank You!
Solution #3
Not Rated (0)
Luisa_K
Rating: 0%, 0 votes
Alison manages the Oracle team responsible for SQL*Plus. She has posted
here from time-to-time. Google for Alison Holloway in this group.
Daniel A. Morgan
Relational theory is not something that is simply a nice-to-have.
http://www.psoug.orgdamor @x.washington.edu
(replace x with u to respond)
Thank You!
Solution #4
Not Rated (0)
kcw573
Rating: 0%, 0 votes
On Mon, 23 May 2005 08:38:30 GMT, "tri  dhungana via DBMonster.com"
Rhetorical question: Did Oracle 8i certify for XP?
So this is a YOYO.
Sybrand Bakker, Senior Oracle DBA
Thank You!
Solution #5
Not Rated (0)
Melissa
Rating: 0%, 0 votes
tri dhungana via DBMonster.com wrote:
Let me see if I've got this correctly.
You somehow have come to the conclusion that Oracle developers are
so good that when they coded the 8i client they knew all of the
specs and functionality for 10g ... put it into the source code
and tested it? Alison will be thrilled. I'll bet she didn't know
her team was that good.
Oh and Sybrand's comment too.
Daniel A. Morgan
Thank You!
Solution #6
Not Rated (0)
Cornish
Rating: 0%, 0 votes
Check if there is a mismatch in charactersets between your client and
server. It seems like thats the problem. Try to use a characterset that
is supported in 8.1.6 on your 10g database also.
Thank You!
Can you Help with these Business and Productivity Software problems?
i am doing a project on institution managment . but i have...
Can 2 different version of Crystal Report run on the same...
Oracle 10g Database Standard (ODBSEONUPP0)
This Oracle error keeps occurring Oracle Error :...
I get this sql error every time I try to connect to an...
How to writ the code in visual basic to create database in...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Find Business and Pro. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
