Question about Masterflex Cole Parmer L/s Pump Drive 77301-21, 0-250 Hz,3 Phase,10-600 Rpm
Display "OPN", Motor dont run
The start/stop button dont work. "OPN" shows on the screen. Tried to re-start, not work.
  • steven
    steven Dec 25, 2013
    07528 series
  • Anonymous Aug 27, 2015
    Hi Steven! Did you fix the pump? I have exactly the same error and would appreciate your help!
How do I over come a problem with my Ricoh Aficio 1515MF, whenever I try to power on the device the device display screen says Functional error SC:322. power off then on if problem persists call servi
Service manual & troubleshooting says this error related to laser unit but this is final solution. To my experience this error mostly because of Micro Door Switchs. Try it by changing Micro Door Switch. I am sure it will help you
Dec 24, 2014 | Ricoh Aficio 1515MF All-In-One Laser...
Jazfit Running Machine
reset the machine, follow this steps and fix it. God bless you
However RUN the software calibration for easy diagnostic goes under the HOOD motor and follow the steps.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 06, 2013 | Exercise & Fitness
Rebok i run RE14301, plain blue screen. It was working until my son played with all of the buttons! We have tried turning it on and off and pressing the reset button but this does not seem to have worked
Instructions 1.
    • 1
    • 3
    • 4
    • 2
Oct 15, 2013 | Exercise & Fitness
Why won't my vision fitness simple T9500 run? I tried holding down the stop button for 3 seconds. It did clear the screen. Then when I hit start it puts 6000 in the screen and will not run. It beeps as if...
With the safety key in place, press and hold “ELEVATION UP” and “SPEED DOWN” for 5 seconds. The software version will appear in display window shortly before model number appears. Press “ENTER” to accept correct model number IF YOU CANNOT GET INTO CALIBRATION EITHER UPPER CONSOLE ELECTRONICS OR OVERLAY CONSOLE ASSEMBLY HAS FAILED.
• Press “STOP” to enter “ENG1”. Press “ENTER”. PLEASE NOTE: HR Window = “0” for miles, “1” for kilometers, treadmill will calibrate in kilometers if set for kilometers. STEP 2 MINIMUM SPEED • Press “ELEVATION DOWN” button, “P0” will appear in display. • Press “START” button, the running belt will begin to move at minimum speed. • The display window should read approximately “.49 - .51”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “.49 - .51”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P0”. STEP 3 1/4 SPEED • Press “ELEVATION UP” button, “SP1” will appear in display. • Press “START” button, the belt will move 1/4 speed. • The display should read approximately “2.71 - 2.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “2.71 - 2.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP1”. STEP 4 1/2 SPEED • Press “ELEVATION UP” button, “P1” will appear in display. • Press “START” button, the belt will move at 1/2 speed. • The display should read approximately “6.72 - 6.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “6.72 - 6.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P1”. STEP 5 3/4 SPEED • Press “ELEVATION UP” button, “SP2” will appear in display. • Press “START” button, the belt will move at 3/4 speed. • The display should read approximately “9.41 - 9.43”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “9.41 - 9.43”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP2”.
STEP 6 MAXIMUM SPEED • Press “ELEVATION UP” button, “P2” will appear in display. • Press “START” button, the belt will move at maximum speed. • The display should read approximately “12.10 - 12.12”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “12.10 - 12.12”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P2”. STEP 7 MINIMUM ELEVATION • Press “ELEVATION UP” button twice, “P4” will appear in display. • The display should ready approximately “190 - 205”. • To adjust, press “ENTER” for value which should read “190 - 205”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P4”. STEP 8 MAXIMUM ELEVATION • Press “ELEVATION UP” button, “P5” will appear in display. • The display should read approximately “750 - 765”. • To adjust, press “ENTER” for value which should read “750 - 765”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P5”. REMOVE SAFETY KEY TO EXIT ENGINEERING MODE REPLACE SAFETY KEY AND PRESS START TO TEST TREADMILL
Jun 14, 2010 | Dmm Vision Fitness T9500 Treadmill
Display screen flashes "CHK" repeatedly
Hello.
From FixYa Support: The "ERR" message reportedly means a memory error.
Please NOTE: This solution will wipe out the memory.
Press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again.
Hope this helps.
Apr 03, 2010 | Olympus VN-3100PC Digital Voice Recorder
HCL Monitor Screen Display Problem with Contrast menu showing up.
my hcl 17inches monitor is displaying contrast,brightness etc automatically
in the middle of the screen.even if i press the menu buttons it
disappears for a sec and comes again and again.what should i do to
solve this?
Sep 13, 2009 | Computers & Internet
Couldn't register service provider. Display shows ''LTD. SERVICE''
Its purely network problem. Dont try again and again with the same solutions. Switch off the mobile for some time, remove battery, and sim card, and put them again after some time and switch it on. In samsung, while switching on, it will show the service providers name in the start up screen. if it shows, then it should work. If it doesnt work, some problem with the sim card. try to replace it. or otherwise general operation in selecting the network shud help.
Aug 10, 2009 | Samsung Cell Phones
Bosch Axxis problem
Thought these additional details might help as we are having a similar problem.
When the washer is turned on we get a blank screen, then after a bit we see the display flash. After sometime flashing then we see it go to normal and we can run it. It is as almost as if it need to warm up...
We can get the display to show faster, by playing with the knob. However, the machine still needs time before we can use it.
Any ideas?
Thanks in advance.
May 04, 2008 | Bosch Axxis WFL 2060 Front Load Washer
When the cover is lowered for an extended period, and then
when you close the lid it will hibernate, pressing any key does not work, you normally have to press the power button and it will power back up and show the screen and the running programmes, i think you are getting confused with sleep mode where the pc can wake opn keyboard.
Nov 05, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Masterflex Cole Parmer L/s Pump Drive 77301-21, 0-250 Hz,3 Phase,10-600 Rpm Logo
236 people viewed this question
Top Masterflex Science & Laboratory Experts
ray gallant
Andrew Taylor
Andrew Taylor
S J Parkin
S J Parkin
Are you a Masterflex Science and Laboratory Expert? Answer questions, earn points and help others
